- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Wonder friend, thank you!
this link that your referer to is for automatich lighting did you mean a other link?ciclo wrote:Hi sanderb,
Yes, no problem. Just consider installing the wires correctly.sanderb wrote: bcm 6R0 937 087 D
Can the rainsor and automatic mirror can be installed with my current bcm? I found a new window of a polo bluemotion 6r with rainsensor will this fit on my polo (i don't have a bluemotion).
Please, click here http://www.uk-polos.net/view ... 97#p483697
No, it is to read the entire contents of the link.
rmps
- Drives: Polo 1.2 TDI Highline 75hp (6R)
Hello again, Fernando!
Próspero año nuevo!
Regards,
Rui Saraiva
I'm sorry, I can't send any PM yet. Could you please send your email in PM so that I can contact you directly?ciclo wrote:If you want a perfect wiring (only wiring)... contact me by PM. «I'm going to make you an offer you can't refuse»![]()
AS I said: you will save lots of time and especially money.
Próspero año nuevo!
Regards,
Rui Saraiva
Hi Rui Saraiva, you have a PM with my email address.
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Sounds great.ciclo wrote:I take this opportunity to tell you I bought a pair of LEDs for indicators and one for reverse gear. Just to test how they work.
Also I have another mod to test, but it will take a month of tests. After I will upload some pictures in my thread, but I will not say I've done.![]()
Just like last year: Glædelig jul og Godt Nytår 2015
Feliz Navidad y un feliz año nuevo para ti también
(Blame Google translate for any spelling errors.
It's the same that I think when I write in another language. Accursed google translator...Mart!n-GTI-DK wrote:
(Blame Google translate for any spelling errors.)
If anyone is interested, I posted a VCDS auto-scan of my R-line on the first page.
hey, how i can actually change the whole thing? Because i can not chance.ciclo wrote:New Mod. Safety switches for central locking with chrome strip.
Acknowledgements to peter_dk25.
The safety switch Polo 6C to close the doors does not work when installed in Polo 6R, to open the doors does it work perfectly.
Solution:
Change the top of the pushbutton. It is very easy.
Use a plastic tool for disassembly.
Remove cover of door handle to take out switch.
Images:
Click to enlarge:
Information about the safety switch on passenger door---> http://www.uk-polos.net/view ... 75#p473025
Hi, the problem is that the switch Polo 6C (electronic circuit) does not work if you install on Polo 6R.
Actually I do not really understand your question. Sorry if I was wrong in my answer.
I have one question for you:
Do you have automatic lights + ch/lh in your WRC? Just let you know that is possible with original parts and they works perfectly.
You only need these pieces on the picture: (Auto switch, relay, wiring that I make with original parts VW)
These pictures are from romingo's WRC, a good friend of the French forum. Click on pictures to enlarge.
How beautiful with so little! Awesome.
Then you only need to release the switch from the housing.
Swing the switch slightly to release the tabs. Be careful not to break anything.
Edited information for better understanding:
"In testing phase"
Image:
benzinkopf
- Drives: 1.2TSI 105HP DSG7
whats that?
J519= BCM
MX1= Xenon headlight
Remember that DRL (LED module brighter) only works when light switch is in "0" position, or with "AUTO" position and lights off.
LED module is less bright with parking lights (light switch in any other position).
What do you think?
What do you think?
- Mart!n-GTI-DK
Now we are on the subject of the TFL.
Have you figured out how to get them to dim instead of turning off when using the turnsignal?
I haven't had any luck with it I'm affraid.
I assure you I have searched extensively the damn dim of LEDs, also I had no luck. I think our xenon are less intelligent than xenon Golf VI or Jetta. (Elsawin)
Based on this, is the idea I have proposed.
Legal? Possible?
What do you think?
Legal? Possible?
What do you think?
