- Lee_Liu_Te
- Drives: 6R 1.2 TDI Bluemotion
Re: iichels Polo 6R 1.6TDI DSG Bluemotion --> OEM++ R-Line conversion
Iichel super mod
!!! I came up with something like this out of sentiment. Extra clocks from my former car (ibiza 6k2fl sport). Not connected yet and I don't even know if they will work
- FB_IMG_1636904121546.jpg (80.38 KiB) Viewed 14887 times
- FB_IMG_1636904155500.jpg (55.77 KiB) Viewed 14887 times
Someone wanted a GTI cluster with 240 km/h speedo, so I decided to put the left ofer tacho disc to good use...
+ VDO editor
+ VDO editor
- Lee_Liu_Te
Iichel how are you going to put on these additional scirocco clocks, it would suit your scirocco dials
! There is a person in Poland who makes such modifications. I have dials from Toledo IV that have the scirocco pattern
. https://allegro.pl/oferta/vw-tiguan-jak ... hQQAvD_BwE
- z2.jpg (4.39 MiB) Viewed 14809 times
- z3.jpg (3.79 MiB) Viewed 14809 times
- 6.jpg (4.83 MiB) Viewed 14809 times
That does look very good, but I'm pretty happy with my current setup
Great!iichel wrote: Sun Nov 14, 2021 9:00 am Santaclaus is early this year:
https://i.imgur.com/0oKE0ZP.jpg
Super Max vs Super Lewis
The better your opponent is, the sweeter the victory.
I want both of them to win ...
I feel like we're missing somethingciclo wrote: Tue Nov 23, 2021 7:33 am
I want both of them to win ...![]()
Someone from Spain
Someone named Fernando
Someone who played the game live a clever old fox
Someone who drove his heart out
Someone who, perhaps, got a bit lucky in the end
Someone with EL PLAN
Someone with EL TEAM
Someone with a teammate who DEFENDED LIKE A LION
Holy s**t, Alonso P3. That's a podium. Amazing.
- Lee_Liu_Te
Did you follow a tutorial somewhere for this? I need to do the same thing and swap the plates out from mph to kph.iichel wrote: Mon Nov 22, 2021 4:15 pm Someone wanted a GTI cluster with 240 km/h speedo, so I decided to put the left ofer tacho disc to good use...
+ VDO editor
No, I used the VDO editor software to adjust the eeprom and just swapped the dials.Kr1s wrote: Wed Nov 24, 2021 8:03 amDid you follow a tutorial somewhere for this? I need to do the same thing and swap the plates out from mph to kph.iichel wrote: Mon Nov 22, 2021 4:15 pm Someone wanted a GTI cluster with 240 km/h speedo, so I decided to put the left ofer tacho disc to good use...
Thank you. What adapter did you use to connect it to the laptop there?iichel wrote: Wed Nov 24, 2021 8:40 amNo, I used the VDO editor software to adjust the eeprom and just swapped the dials.Kr1s wrote: Wed Nov 24, 2021 8:03 amDid you follow a tutorial somewhere for this? I need to do the same thing and swap the plates out from mph to kph.iichel wrote: Mon Nov 22, 2021 4:15 pm Someone wanted a GTI cluster with 240 km/h speedo, so I decided to put the left ofer tacho disc to good use...
I opened the cluster, read the eeprom with CH341A + eeprom clip
https://www.amazon.nl/iHaospace-CH341A- ... B07PQQPS6D
mk2-stew
- Drives: MK2 Polo Fox (squareback / breadvan)
Wow you have a lot of skill and patience working on this car. I'm quite good at tech stuff, but not so much when it comes to cars. I like things simple - that's why I went for a MK2 86C Polo!
Nice work!
Nice work!
I started out as an absolute newbie to this and I did a lot of learning on the job and discovery-learning. If you try hard enough, your Mk2 Polo will be a great car. I'm sure.mk2-stew wrote: Thu Nov 25, 2021 9:47 am Wow you have a lot of skill and patience working on this car. I'm quite good at tech stuff, but not so much when it comes to cars. I like things simple - that's why I went for a MK2 86C Polo!![]()
Nice work!
