Locked
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Achso!. Noted.
But FYI, I've never get the coming home function work at all. I've tried switch of ignition, and pull the high beam stalk once, and nothing happen. :(
but will ofcoz try to do some research anyway!tq
benzinkopf wrote: I've tried switch of ignition, and pull the high beam stalk once, and nothing happen. :(
After that, you have to open the driver's door. (I guess you do it this way)
PRCode: 8K0 = Without special headlight activation
PRCode: 8K1 = Separate daytime running lights
PRCode: 8K2 = Daytime driving light mode for urban driving
PRCode: 8K3 = Separate daytime running lights with low beam assistant and Coming Home feature
PRCode: 8K4 = Separate daytime running lights NAR
PRCode: 8K5 = Low beam assistant with Coming Home function NAR
PRCode: 8K6 = Separate daytime running lights and Coming Home function
PRCode: 8K7 = Automatic headlight activation
PRCode: 8K8 = Low beam assistant with Coming Home function
PRCode: 8K9 = Separate daytime running lights with low beam assistant and Coming Home function
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
Startet my Bonnet strut project today. ;)
Painted VW Candy White to match the car and look as OEM as possible ;)
Excellent. Increasingly perfect. Image
We expect to see installed soon.
Mart!n-GTI-DK
ciclo wrote:Excellent. Increasingly perfect. Image
I'm just waiting for the gas strut to arrive. :)
But that gives the parts a chance to cure some more before I install them. :)
Better that way.
Today I cleaned the car and engine after a couple weeks of bad weather.
Mart!n-GTI-DK
My engine bay really needs a GOOOOOOOOOOD cleaning...
But... Have done some manual labor today. ;)
Good job Mart!n-GTI-DK. Image
What is the reference number of your gas strut?
Mart!n-GTI-DK
I ended up buying an aftermarket strut. The OEM one was quite expensive.
damnn you high tax on cars and carparts in Denmark. :|
chrispy.
Post by chrispy. »
Would have tried to have painted the strut White to match the car :) obviously not the hydraulic shaft.
None the less.. Will be copying this soon! How much was this strut?
Mayhem
Drives: 2010 polo 1.2 tsi
Post by Mayhem »
I got a strut from eurocarparts for £18. Works fine. Its designed for a vw mk4 golf bonnet
As I'm tired of read some nonsense for three years on other places... :lol:
Hidden in Elsawin Image. By VOLKSWAGEN , no by others...(2010)
Image Image
For savvy boys Image: these diagrams also resolve questions of Coming Home. Image
Super ciclo, savior of Polos, god of customization (no really, good work),
May I ask you for a small favor?
I know you are (more or less) an expert on coding etc.
The case is:
I'm working on retrofitting OEM xenon with 10 to 14 pin adapters.
The car is a 2011 Polo 1.2TDI bluemotion with start/stop.
It's not completely standard (for exampe OPS front/back and GTI tacho) in case that's relevant.
I am therefor looking for a coding that makes them work.
You probably need an autoscan which is attached:
Saturday,14,February,2015,16:37:54:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ6RZBY123456 License Plate:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56 61 69 77
VIN: WVWZZZ6RZBY225654
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3416F00B7842B24E782D500521300
Shop #: WSC 00788 648 00255
VCID: 8717035C32D37526559-80D2
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326102886DD1A08E527-8067
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 D HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0322
Revision: BU046001 Serial number: 0379 028111968
Coding: 3CB02BB808210000002809F07D2B9CD9DF80611F7EA60001A00000000000
VCID: 3F875BBCAE837DE6AD9-806A
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 1611
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1611
Coding: 48BC30
Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 820000
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231422402620
Coding: 310001
Shop #: WSC 12345 123 12345
ROD: EV_VW75XParkAssis8K.rod
VCID: 3B7F2FACB29B61C6811-806E
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00EPNH2
Coding: 003232
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A917A68ED41C84E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40650BI7U48C8
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405J09RECEOUJ
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB405T0BTBEF9G7
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB405R0BTBEKPFQ
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H03 0505
Coding: 540A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 336F078C9ACBA986591-8066
Address 19: CAN Gateway (J533) Labels: 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H38 0025
Revision: H38 Serial number: 040211F1003097
Coding: 2500C2
Shop #: WSC 00000 000 00000
VCID: 336F078C92CBA986591-8066
Address 25: Immobilizer (O334) Labels: None
Part No SW: 0K0 953 264 HW: 0K0 953 264
Component: LMMO % H53 0005
Serial number: % %
Coding: 000500
Shop #: WSC 00000 000 40960
ASAM Dataset: @V_ImmoZUDS_VDA_RM09 D03009
ROD: N/A
VCID: E8D520E0138D9A5EBC3-80BD
No ASAM data for: "@V_ImmoZUDS_VDA_RM09" (VW36)
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7666620365
Coding: 020100
VCID: 2B5F1FEC4AFBF146111-807E
Address 37: Navigation
Cannot be reached
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F670BFCEAE38D663D9-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H23 6270
Revision: AB001001 Serial number: VWZ6Z7N7364037
Coding: 00000440010000810005
Shop #: WSC 01357 011 00200
VCID: 3D7B21B4A48F6FF6BF5-8068
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V12 8195
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0025
Coding: 030B1A5A
VCID: F4ED449057456EBE00B-80A1
Subsystem 1 - Part No SW: 6R0 915 181 B HW: 6R0 915 181
Component: J367-BDM H07 0150
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Towbar module H09 0100
Revision: 3A001001 Serial number: ¿¡006789000000
Coding: 0100000100000000
VCID: 3065088063DD929E243-8065
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 N HW: 7P6 035 730 N
Component: TELEFON H15 4217
Revision: 1B001001 Serial number: 00007699999999
Coding: 0210000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3D7B21B4AC8F6FF6BF5-8068
End ---------------------------------------------------------------------
May I thank you for taking a look and if you know what to do... would be awesome.
Gracias.
Gannu
Drives: 6R 1.6 TDI 105 PS
Post by Gannu »
Ciclo, need some help. What is the easiest way for routing a thin wire through the firewall/bulkhead? I saw the rubber grommet for the hood release cable but it is located a bit inside and may have to remove the wipers and the plastic trim to gain access. Is there another point?
Thanks in advance!
iichel wrote: I'm working on retrofitting OEM xenon with 10 to 14 pin adapters.
The car is a 2011 Polo 1.2TDI bluemotion with start/stop. I am therefor looking for a coding that makes them work.
Gracias.
New coding:
3CB02BB808210000002809F07F2B9CD9DF80673F7EA61001A00000000000
Also I recommend you read here (Crave89): http://www.uk-polos.net/view ... 95#p483778
Note to others:
The process of retrofitting xenon headlamps with 10 to 14 pin adapters for Bluemotion is not the same as for non Bluemotion.
Locked
