Re: iichels Polo 6R 1.6TDI DSG Bluemotion --> OEM++ R-Line conversion
+1
We want many more images, with all possible functions!
Some info: OEM QI charger for MIB systems (not RNS), R265
Charger module: 5NA980611
Connector: 4B0971978B
T12g = grey quadlock connector, with canbus
The purple plug can be connected to the roof aerial, so the QI charger also acts like an antenna amplifier
Coding is dependent on the system. In my case (5C0 PQ MIB), it was in the long coding. On MQB, it is probably in the adaptation channels, look for 'wireless' and
Some info: OEM USB hub, R293
USB hub: 5G0035953D
Connector: 1K0972704F (red)
Wiring:
T4/1 = +12V terminal 30
T4/2 = GND
T4/4 = signal = T12/3 (green quadlock, with AUX)
Coding is dependent on the unit. In my case, PQ MIB 5C0, it was coded in the long coding.
USB hub: 5G0035953D
Wiring:
T4/2 = GND
OEM QI charger in action:
Cool!
Many thanks!
Many thanks!
And, as promised, a long video for you with plenty to make screenshots of haha
- Shadow109
- Drives: Vw t5.1 2013
Nice, thanks for sharing
Thanks a lot Michel! a very thorough review. Many functions to be a PQ25.
In essence it works the same as for our Golf Mk7.5. Including that the voice control does the same nonsense, it does not understand us in Spanish or English, we end up being defeated by the machine. We even run competitions to see who is able to enter a full address by voice.
Logically in our Golf 7.5 all the menus work, although the same thing happens with the bluetooth symbol in the IC (AID), it is missing, and I miss it.
If you are ever lucky enough to have an MQB or higher you will like the settings for the Driving Assistants.
Enjoy it!
The updating of maps can be done on the VW website, Maps Update.
You don't need to download the Discovercare program, or have an Original VW SD card.
Thanks Michel.
Enjoy it!
Thanks Michel.
- JUUL
- Drives: 6N 1995
Been a while, missed a lot. Congrats on registering the new engine, big milestone. You sir are a genius...and the updates keep on coming
Info on the heated steering wheel:
The slip ring is in! It's the 5Q0953569B that is a bolt on upgrade to the current slip ring (remember: Polo AW stalks with Polo 6C clip ring).
Small modification:
The wiring is not very difficult either, just used factory positions:
T14 (black) = 5Q0972726
T14/1 = positive for the heating
T14/8 = negative for heating
T14/2 = +15 contact for MFSW
T14/4 = GND for MFSW
T14/14 = LIN for MFSW
T4 (yellow) = 4H0972133
T4/1 = airbag from T16/5
T14/2 = airbag from T16/6
All working:
Heating will probably work too
Small modification:
All working:
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Golf Mk8 R multi function steering wheel with heating: 5H0419089CB
Wow.... its beautiful. Can't wait to see it installed with the lights.iichel wrote: Tue Nov 30, 2021 8:21 pm Golf Mk8 R multi function steering wheel with heating: 5H0419089CB
+1Kr1s wrote: Wed Dec 01, 2021 5:17 pm Wow.... its beautiful. Can't wait to see it installed with the lights.
F1@Michel, who do you think will win at the new Jeddah circuit (حلبة شارع جدة)?
I'm looking forward to the race.
My heart goes out to Super Max, my passion goes out to Super Lewis, very difficult to explain. LOL!
