ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
The appropriate connectors.
Golf7.5. Exit/warning/puddle light replacement by Volkswagen LED logo/warning light for door trim.
Note:
Under observation or until my wife tells me to remove these things from the car. :)
There is a shortage of puddles around here at this time of year, but it wasn't hard to find a place disgusting enough to simulate puddles and check out the effect of the VW logos.
At the moment only installed on the front doors.
1- They are relatively pleasant. The VW logo is too bright in dark places and just right in places with more outside light.
2- The warning light is more powerful than the one I had installed. I think this suits me.
3- The effect produced by the combination of colors is very striking.
They can be installed by hand without the need for any tools if the wiring is present.
Related information:
- viewtopic.php?p=571441#p571441
I think this is where the improvements begin for my future Fall 2024 project.
Golf 7.5. Heated mirrors. Blind Spot.
I currently have these Golf 7/7.5 mirrors available at home:
- I have several of the standard originals, I don't know how many (2 or 3 pairs).
- I recently bought the blue anti-dazzle mirrors since I really liked the blue anti-dazzle ones I installed on the 6R.😎
- I also recently bought the 'Original' VW mirrors with BSD warning light which I will keep as a spare. The BSD warning light in these new Original VW mirrors is improved - I think a new gel? or similar technology is applied - compared to the BSD warning lights on the old 'Original' VW mirrors that I have installed for quite some time.
Since I recently installed the mirror housings with the BSD WL from the Passat B8 (💎👌🧙‍♂️), I am going to install and enjoy for a while the blue anti-dazzle mirrors, and in the meantime I am going to try to improve the old original VW mirrors with BSD warning light, which is the real purpose of all this. A meticulous and detailed piece of work for the autumn/fall project.
When I bought the Golf 7 blue mirrors on Ali, I was forced to buy something of little value and spend a little more so that the order of the blue mirrors would get a very huge/magnificent discount on those special days on Ali when you can get extraordinary coupons (8, 12, 20, 40, etc.).
These caps for the joint of the door hinges.
I think it was 1.xx euros more... also for the fall project.🤭
Golf7.5. BCM 5Q0 937 084 DH (EC_upd) PINOUT.
Isn't it true that the rear door contacts are managed by the BCM? So I'm wondering why I would want to install a rear door module or something similar to manage a single light (W/Ex L) knowing that the rest of the rear door lights can be managed in different ways without an additional rear door module.
Let's allow the BCM to do its job.
Unused channels/pins dedicated to lighting... Free!🤭
While it is IMHO fairly easy to set the matching channel values ​​needed for each PIN, I recommend reading the excellent PDF work done by DV52💎🙏 explaining the MQB lighting, as well as reading the following Ross-Tech forum thread. :arrow: https://forums.ross-tech.com/index.php? ... ost-174422
Ein vs Aus.
https://www.youtube.com/watch?v=q8p-3bBxgpU&t=243s
Also for my fall 2024 project.🍂
Since I have to wire the rear doors for exterior handle illumination, I take the opportunity to wire the rear door warning lights "correctly" so I don't hear any complaints or whining about how I wired the rear door warning lights. :lol:
Note:
- If you wire the rear door warning lights like I did, you don't have to worry at all, it works and will work fine until the end of time.
viewtopic.php?p=583390#p583390
Without pointing out anyone in particular :lol: , someone will have to give me a 'convincing explanation' as to why it is not safe to connect the rear door exit/warning lights in this way. Please.🤷‍♂️
-The problem is that there are people who like to leave their car open all the time so that all kinds of bugs can get in (or out).👾🐛...😁
Related to the previous post. 5Q0937084DD
Despite being a BCM High (DD H38) it does not have pins 61, 35, 36, 37. It's not a definitive hell 🤭, but it is one more annoyance.
At least it serves as a starting point so you know from which Hardware these AMBL pins are available.
More precise information in the related links:
- viewtopic.php?p=576432#p576432
- viewtopic.php?p=573716#p573716
I remember that Slavik and I made this change (from 086XX🥔 or 084DD to DH) in our Golfs practically at the same time.
- DH with EC SW works lika a charm!!! 🧙‍♀️
- DH H40 has the same PINOUT as EC H44.
- I guess for us, the destiny and luck/magic have come together at this point.🤭
The only mystery of changing the original BCM to a 'NEW' one is removing the CP.
https://www.youtube.com/watch?v=MKXXczIocAA&t=19s
Golf 7.5 Flashing session. 5Q0937084DD BCM High for my mini test bench.
I also updated the datasets, but I want to find more recent ones.
Done.🔽
The BCMs I have:
- DA_H38. From factory. Updated to FW EC_0511, you get a BCM with FW_DS. With FW EC_1513 it loses the firmware name (----------).🤷‍♂️
- DD_H38. Second hand, from a Tiguan. When it was still possible to install used BCMs (it is no longer possible). Updated to FW EC_1513.👌
- DH_H40. New, currently installed in our Golf. Updated to FW EC_1513 (see last autoscan posted). Same PINOUT as BCM EC_H44.💎
H38:
DA, no pins for heated seats, no pins for coloured ambient lights and no 4 additional AMBL pins.
DD, missing 4 additional AMBL pins.
These two BCMs are no longer useful because second-hand BCMs can no longer be reused, they are junk/scrap, except if I use them for my mini test bench (Reduce, Reuse, Recycle ♻).
Since DD supports FW EC_1513 I intend to install the 4 additional AMBL pins by removing them from the DA BCM, this way I can do specific tests at home instead of on the vehicle, ...which is infinitely better.😊
Edit... 09/18/2024
Important note:
I don't know why I believed, thought, read, or was told by someone that it was not possible to install second-hand BCMs on the MQB platform, but it turns out that it is possible.
I sincerely apologize for spreading an idea that was totally false, I never had the opportunity to verify it personally. I'm very sorry... 😥 🙏
https://www.youtube.com/watch?v=yd3glcMV-2E
Golf 7.5. Protective caps for the door hinge joint installed.
Factory.
Ali.
The four protective caps installed.
Save this image, it barely weighs anything.😄
I had never paid attention to these details before, and as incredible as it may seem, the improvement is really nice (I'm not kidding).
No tools are required if you guide the retaining tabs of the protective caps cleverly.🧙‍♂️🤭
Golf 7.5. Anti-dazzle blue mirrors installed.
I will have these installed temporarily until I improve the BSD warning light on the old original mirrors.
They are not extremely perfect, but enough to make them look that way, nothing to point out on the negative side.
A bit nicer than the originals, but not as nice as the anti-dazzle blue mirrors I installed on the 6R.
At first I needed to get used to the fact that the passenger mirror is also convex to see the blind spot, I had to regulate this mirror a little differently than I'm used to.
I have not tested the anti-dazzle feature yet (at night).
Once the heated mirror function has been tested, I do an Autoscan.
Sunday,15,September,2024,10:15:11:32438
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: BLUE ANTI-D MIRRORS OK!
Mileage: 55851km-34704mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 14 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 55851km-34704miles
14-Susp. Elect. -- Status: OK 0000
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000    CVN: 92B19492
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92228D-807C
   VINID: 9E69EAAAA465A9B8000041051C011774D2
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA134202170477B060560CA2580562C84E26006A4733420F08A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DA75F-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00202735
   Coding: 000200032001100D1115004C0018542A
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 074B66607FAADF521E9-8052
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H05 0010
   Serial number: AAE88B8400PAG0MUFU05
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 1513
   Serial number: 72007150025702 Dataset Number: V03935315NT 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW37.rod
   VCID: 7DA704882D768582345-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M01D06H23M07S44
   Coding: 00A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY191251XZQ
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0313
   Serial number: 00002854456462182207
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000023032104400679
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0073
   Serial number: 000308417318277 Dataset Number: V03935313MC 0001
   Coding: 8271567841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 58E9751CE29480AA473-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V310
   Coding: 2B0D67E35DFFC728979C81A4614006800000000000B9C00024
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 47CBA6603F2A1F52DE9-8012
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 31051841350252 Dataset Number: V03935317XE 0001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392FD09879DE79A258D-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ Dataset Number: V03935272MG 0001
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA92208D-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A532807E8C000801887A0F5401000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B03FAD08382DB32DA1-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5502
   Serial number: 09012020001767 Dataset Number: SET_FPA_MOD 0001
   Coding: 030900047F085700FB0002FE880F00010001070000000000000000000000
   GVL: 014E3C100000000040CC800000024C0000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFE80277A9792269-802A
   Generator:
   Component: 5-01-14-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Component: MFL  H03 0219
   Serial number: 17036218123222100544
   Coding: AE2B00
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000587514012
   Coding: 52A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000587481913
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000417322781  Dataset Number: V03935341UB 0001
   Coding: 00150220D000048000001000
   Shop #: WSC 00030 935 00052
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 52FD8734C468AAFAB97-8006
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935287HR 0001
   Coding: 931F0000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B121AC1E3CC4CA4BB-8020
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0371
   Serial number: 01081930001280 Dataset Number: V03935292JZ 0001
   Coding: 00000005090016C206207F07620000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372BD6A04FCA6FD2AE9-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000423015792  Dataset Number: V03935341UE 0001
   Coding: 00150220DE00048000001000
   Shop #: WSC 00030 935 00034
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 51FF8838C16ED1E280D-8004
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0879
   Serial number:                Dataset Number: 5G0CV1v____ 0001
   Coding: 02731001FF0000004111010140880A231F0507E401200400CF
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFA997-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 ET    HW: -----------
   Component: ECE AS 24/25  --- 2210
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 30000000250801 Dataset Number: RDKS_TinyQ_ 1017
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3829D59C42D460AAA73-806C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: V03935246NT 0001
   Coding: 01040201C600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004213340 Dataset Number: V03935349WG 0001
   Coding: 0000018811EEC028889F2C801030004400438000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 3537DCA855C69DC2BC5-8060
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X_003_VW37.rod
   VCID: 6A8D3FD44CF8023AE17-803E
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:49, VBatt start/end: 14.1V/14.1V)-----------
https://www.youtube.com/watch?v=7hadytJ2OSE
Golf 7.5. MOT (ITV) passed successfully. FAVORABLE.🤸‍♂️
6 years.
Intense and hard inspection (not usual), which took more time than usual.
All the notes from the 'engineers' were positive evaluations of all the vehicle systems, both in visual inspections and checks with those torture devices for the undercarriage 😁, as other checks with other devices, ... it seemed to me that they were looking for something that they did not find and that they were not going to find.🤷‍♂️
The most striking thing was that in the section on the general condition of the vehicle they have rated it as normal but not good (as usual in my cars), which makes me suspect the intention of the 'engineers'. Our Golf is near to impeccable condition.
What is happening??? dishonest people everywhere...
Money, money, money... 💩
https://www.youtube.com/watch?v=95r-d3k7bgw
Connection points for the Entry Lights. (EIN 😊)
https://www.drive2.ru/l/661086589954314341/ Thanks! 🤗
I don't know when I will do the installation for the door handle entry lights, so I am converting my fall project into the fall-winter 2024 project. Now I am busy with another installation.
https://www.youtube.com/watch?v=To_yL5m7IIc&t=204s
VAS 6154A vs VNCI 6154A.
It is the same tool.
The VNCI 6154A can change the serial number if it is blocked 🤷‍♂️, the device manager program is required (available on the official website). Correct quality, but not exceptional, a solid 'toy' that will last for many years.
The VAS 6154A is seen to be of a slightly better quality, we could say 'more OEM', which also has a better '4 meter' USB cable (previous post). Operation LEDs on both sides.
I prefer it in case of use in wireless modes.
-Both have a button to switch the operating mode in case of wireless connection, WLAN AP or HOTSPOT.
-Both work with the 'Original drivers' and therefore with the different ODIS versions, including the most recent ones.
-They are not VCX tools, both are detected as VAS 6154A (USB ports, etc).
-Easy configuration and PERFECT operation in all possible modes.
As usual nowadays, ODIS programs are easily installed following the video tutorials, now it is easier because of the Drivers issue, a couple of small tricks (not important) at the end of the installation so that everything flows quickly (updates).
-OS 23/OE 17 and higher versions work much faster than OS 7/OE 12 versions.
-You can configure VAS 6154A and VNCI 6154A on the same device (laptop, etc.).
VNCI TEST. Golf 7.5. New BCM EC (HW).
Wednesday,30,October,2024,11:26:18:32438
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: NEW BCM EC TEST OK!
Mileage: 56259km-34957mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 56259km-34957miles
   VCID: 290F00D8897EC922285-807C
Readiness: 1110 0001
   VCID: 76B51BA40840D6DA757-8022
   VCID: 074B66607FAADF521E1-8052
   Air quality sensor:
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 EC
   Component: BCM MQBAB H   H44 0511
   Serial number: B2701012406040 Dataset Number: V03935315NT 0001
   Shop #: WSC 00000 000 00000
   VCID: 7DA704882D76858234D-8028
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   VCID: 58E9751CE29480AA47B-800C
   VCID: 47CBA6603F2A1F52DE1-8012
   VCID: 392FD09879DE79A2585-806C
   VCID: 094F605869BEA922085-805C
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   VCID: 2B03FAD08382DB32DA9-807E
   VCID: 7F5BFE80277A9792261-802A
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   VCID: 52FD8734C468AAFAB9F-8006
   Coding: 010000
   Coding: 931F0000
   VCID: 74B121AC1E3CC4CA4B3-8020
   VCID: 372BD6A04FCA6FD2AE1-8062
   VCID: 51FF8838C16ED1E2805-8004
   Coding: 090000
   VCID: 323DE7B4A4A88AFA99F-8066
   Data carrier:
   VCID: 3829D59C42D460AAA7B-806C
   VCID: 3537DCA855C69DC2BCD-8060
   VCID: 6A8D3FD44CF8023AE1F-803E
End----------(Elapsed Time: 01:49, VBatt start/end: 14.4V/14.4V)-----------
Coding: 0F4DFD
Coding: 00A8DD
Alarm horn:
https://www.youtube.com/watch?v=PlgloXoJOdM
Golf 7.5. New BCM_EC SW update. 0511 to 1513 (VAS 6154A).
Wednesday,06,November,2024,11:45:26:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: BCM_EC SW_UPDATE 0511_TO_1513 TEST OK!
Mileage: 57056km-35452mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 57056km-35452miles
   Air quality sensor:
   Component: BCM MQBAB H   H44 1513
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Data carrier:
End----------(Elapsed Time: 01:51, VBatt start/end: 13.4V/13.3V)-----------
https://www.youtube.com/watch?v=vySg8DtnXYo
... "become who you're afraid to be" ... -Carl G Jung-
:arrow: :mrgreen:
Happy New Year! 🎉🥂
Locked
