Page 50 of 51
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Posted: Wed Jun 25, 2025 6:21 pm
by ciclo
Golf 7.5. Maps Update 2025/26. V21.
Downloaded from the official VW website.
I think the V22 is already available on another VW group website, but for this summer vacation the V21 is enough.
https://www.youtube.com/watch?v=gx7GyiDZQms
Posted: Sun Jul 20, 2025 2:41 am
by ciclo
Golf 7.5 Parallel parking. Test. Park Assist feature with RVC Highline vs Park Steering Assist -PLA-
Video: :arrow: :arrow: :arrow: https://www.youtube.com/embed/Vxzv2MLbX ... autoplay=1
I took this video for reasons unrelated to parking, but I thought it was a good idea to post it as it will be useful in the future.
I bought my current RVC Highline (KA2) already calibrated, but this calibration isn't perfect for 'my' Golf 7.5. It's okay, but it's not perfect (IMO).
In the future (after the summer) I am going to recalibrate both the 6C and A5 with ODIS... in the meantime, I am thinking of making some improvements to the VAS 6350 dot panel that I bought on Ali for 6C calibration. For A5 it will be the Dynamic calibration.
erWin. 6.2 Calibrating reversing camera system. PDF. FREE! Request download!👍
:arrow: https://drive.google.com/file/d/1Y4t_Eb ... sp=sharing
Reference image 'before' Calibration.
I couldn't resist taking the RVC lens height measurement, just like I did with my POLO 6R. :arrow: viewtopic.php?p=608613#p608613
It was out of sheer curiosity because I'll be taking this measurement again on our Golf 7.5 when I begin the Calibration with the VAS 6350 dot panel.
Posted: Sun Aug 03, 2025 6:42 am
by ciclo
'Predictive' calculations (assumptions) of Dimension 'A' for RVC Highline Calibration.
For reasons unknown to me, if my RVC Highline has uploaded the Golf 7 Parameters/Dataset, ODIS does not allow me the calibration process 🤷‍♂️, but the Basic Setting fault would be present in such a case... (HW incompatibility? or who knows... even datasets are sometimes shared without proper specifications due to reduce the file name).
My RVC Highline, with Passat B8 Dataset. (the way I bought it)
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H18 0231
Dataset Number: V03935246NT 0001
Coding: 01040201C600201F000060
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 392FD09879DE79A2885-806C
Golf 7 vs Passat B8.
So I 'assume' that if I have an RVC Highline with Passat B8 Parameters/Dataset installed in a Golf 7/7.5 and I place the VAS6350 dot panel at a distance of 1900 mm, which is within the allowed range according to erWin (1400 to 2000 mm), I have to subtract 334 mm to enter 1556 mm as Dimension 'A' (also allowed range according to erWin). I 'suppose' this way I will achieve a correct RVC calibration for my Golf.
🤔 I will test the two dimensions - 1900 vs 1556 mm -. :lol:
UPD: Well, I have read other calibrations for Golf 7.5 and this RVC model, and it seems that the best way to calibrate this camera model with Passat B8 parameters is to Identify the vehicle in ODIS 'manually' as Passat B8, the difference (334) should be added to the real distance from the rear axle (G7.5) to the VAS6350 dot panel (Dimension A).
RVC Highline Calibration Instructions are in the previous post.
I've already located a couple of outdoor locations where the surface is completely flat and the conditions are ideal for RVC Calibration process. All I need is a cloudy day so that the sun's rays don't shine directly on the VAS6350 calibration panel.
It's highly likely that these '6C' RVCs only 'see' the grayscale for calibration, just like the 'A5' driver assistance cameras... that's why I wanted to do the calibration process after the summer. Damn sun...😁
Posted: Mon Aug 04, 2025 7:04 pm
by ciclo
Preparing the Calibration of my 3 RVCs Highline.
How to identify your vehicle in ODIS as a Passat B8 (sedan or wagon).
I received the package with the VAS6350 dot panel perfectly folded. To try to remove the wrinkles, I wrapped it around a broomstick and left it on the clothesline for a couple of weeks at 30-40ºC.
It's not miraculous, but it works 80% without making any special effort. Enough for me.😄
I don't know if the device called a clothes iron would work. I suppose this 'plastic' panel would burn on the first try.
...and other minor things.
Is the shortest distance between two points a straight line? Is a straight line an infinite circumference? If I go to the gym a couple of weeks after summer vacation, can I also become a superhero? 😁
Tailgate panels/trims/mouldings removed. Current RVC Highline.
Testing one of my other two RVCs Highline for reasons unrelated to calibration.
✅ :arrow: viewtopic.php?p=608613#p608613
Posted: Mon Aug 11, 2025 6:35 am
by ciclo
Golf 7.5. RVC Highline Calibration Process. ✅ ✅ ✅
Some information in previous posts.
Autoscan. (with RVC 4M0 HW and Passat B8 Wagon dataset)
Sunday,10,August,2025,09:56:57:32438
VCDS Version: 25.3.1.2 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250604 DS365.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: RVC 4M0 HW CALIBRATED OK!
Mileage: 62962km-39122mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 14 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 62962km-39122miles
14-Susp. Elect. -- Status: OK 0000
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000    CVN: 92B19492
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC922F87-807C
   VINID: 9E69EAAAA465A9B8000041051C011774D2
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA134202170477B060560CA2580562C84E26006A4733420F08A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DAA55-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00202735
   Coding: 000100032001100D1115004C0018542A
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 074B66607FAADF52CE3-8052
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H05 0010
   Serial number: AAE88B8400PAG0MUFU05
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 EC
   Component: BCM MQBAB H   H44 1513
   Serial number: B2701012406040 Dataset Number: V03935315NT 0001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7DA704882D768582E4F-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M01D06H23M07S44
   Coding: 00A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY191251XZQ
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0313
   Serial number: 00002854456462182207
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000023032104400679
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0073
   Serial number: 000308417318277 Dataset Number: V03935313MC 0001
   Coding: 8271567841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 58E9751CE29480AA979-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V310
   Coding: 2B0D67E35DFFC728979C81A4614006800000000000B9C00024
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 47CBA6603F2A1F520E3-8012
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 31051841350252 Dataset Number: V03935317XE 0001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392FD09879DE79A2887-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ Dataset Number: V03935272MG 0001
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA922D87-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A532807E8C000801887A0F5401000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 2B03FAD08382DB320AB-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5502
   Serial number: 09012020001767 Dataset Number: FPA_SL_ME_R 0001
   Coding: 030900047F085700DB0002FE881F00010001070000000000000000000000
   GVL: 014E3C100000000040CC800000024C0000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFE80277A9792F63-802A
   Generator:
   Component: 5-01-14-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Component: MFL  H50 0420
   Serial number: 17044958021162102894
   Coding: AE2B00
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000587514012
   Coding: 52A54640
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000587481913
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000417322781  Dataset Number: V03935341UB 0001
   Coding: 00150220D000048000001000
   Shop #: WSC 00030 935 00052
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 52FD8734C468AAFA69D-8006
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935287HR 0001
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B121AC1E3CC4CA9B1-8020
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0371
   Serial number: 01081930001280 Dataset Number: V03935292JZ 0001
   Coding: 00000005090016C206207F07620000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372BD6A04FCA6FD27E3-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000423015792  Dataset Number: V03935341UE 0001
   Coding: 00150220DE00048000001000
   Shop #: WSC 00030 935 00034
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 51FF8838C16ED1E2507-8004
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0879
   Serial number:                Dataset Number: 5G0CV1v____ 0001
   Coding: 02731001FF00000051110101C0890AA31F0507E401200400CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323DE7B4A4A88AFA49D-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 822 MM    HW: -----------
   Component: ECE AS 25/26  --- 2410
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 30000000250801 Dataset Number: RDKS_TinyQ_ 1017
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3829D59C42D460AA779-806C
   Part No SW: 5Q0 980 556 B    HW: 4M0 980 556 A
   Component: RVC Compact   H19 0231
   Dataset Number: V03935314JY 0001
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 J    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1423
   Serial number: E80320004213340 Dataset Number: V03935436AM 0001
   Coding: 0000018811EEC028889F2C801030004400438000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 3C21C98C76EC4C8A931-8068
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X_003_VW37.rod
   VCID: 6A8D3FD44CF8023A31D-803E
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:55, VBatt start/end: 12.4V/12.4V)-----------
---------------------------No fault code found.----------------------------
During the calibration process, I transferred a new dataset from the Passat B8 'Wagon/Estate/Variant' to the RVC Highline with 4M0 HW for experimental reasons. The calibration went just as well as with the 'Sedan' dataset.
This is the RVC Highline that I will probably install in my 6R, it is already removed from our Golf 7.5 where the recalibrated RVC Highline is already installed.
The other 2:
All three look great, but the best is the Converted.🧙‍♂️
Highlights, images:
Warning:
- I'm not a photography expert, so the angles used with the smartphone camera for taking pictures aren't perfect.🤭
- Sharpness. When taking pictures from a close-up screen, distortions occur. The images transmitted by the RVC lens to the HMI screen are good in real life for safe driving, although they can certainly be improved.
Those two white lines coincidentally were already there.🤷‍♂️
ODIS calibration completed.
My calibration panel is wider on one side outside the calibration pattern, but what matters is the calibration pattern.✅
Comparison with Before calibration.
Video (before calibration): :arrow: viewtopic.php?p=608553#p608553
After calibration.
More clarifying images After calibration.
8) 8) 8)
https://www.youtube.com/watch?v=58dxl3DC05s
Posted: Wed Aug 13, 2025 3:57 am
by ciclo
Golf 7.5. More images of the RVC Highline calibration process (what if...).
Since I didn't install the tailgate trims, and for personal experimental and/or learning reasons (what if...), the next day I reinstalled the Calibration Panel VAS6350 (15 min) to modify some calibration conditions and see the results.
Do you see what I see?
These images are with the RVC Highline Converted.🧙‍♂️
https://www.youtube.com/watch?v=bF563v8nkiw&t=185s
Posted: Tue Aug 26, 2025 8:21 pm
by ciclo
AutoScan
Tuesday,26,August,2025,09:49:07:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: 6C-5Q0_HW + A5_CALIBRATION-CORRECT_RESULT OK!
Mileage: 63090km-39202mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 63090km-39202miles
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. User\5Q0-907-379-IPB-V1.lbl
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Data carrier:
End----------(Elapsed Time: 01:54, VBatt start/end: 12.8V/12.8V)-----------
- 6C RVC Highline Golf 7.5.
- A5 camera calibration verified. ✅
- ODIS diagnostic protocol.
- Replaced the thermal paste, fans, and battery on my f laptop (f=fast). Faster read speed, less heat, longer operating hours, and finally, quieter fans for better diagnostics.🏎
Pending:
- Deep carpet cleaning and general cleaning after summer vacation. 🧹😊
- In the fall, I might resume some minor tasks I left unfinished, such as some door lights, etc.
https://youtube.com/clip/UgkxWSubm9OPsK ... p3SErmddAX
Posted: Wed Sep 03, 2025 6:38 pm
by ciclo
If the earth is not flat, how is it possible to calibrate the RVC correctly?
The Infinite Travel Assist is a real pleasure, especially in a Golf 7.5.😍
https://www.youtube.com/watch?v=Qru0ucDek_A
Posted: Fri Sep 05, 2025 8:16 pm
by ciclo
New cordless vacuum cleaner.
I finally bought a cordless vacuum cleaner that works! Ali. No brand.
It's powerful enough for decent vacuuming, but the batteries don't last long -about 10 to 15 minutes-.
I attached a hose with a blue adapter from other vacuum cleaners to make this arduous task easier.😄
With the best lighting (FREE sunlight) and good weather, I test the new vacuum cleaner.
It's not as powerful as the corded Dyson vacuum, but it's as powerful as a regular corded Bosch vacuum I used for these tasks.
I used four 6Ah batteries for the results of the previous images, including the trunk area.
New car!😊
Satisfied with the result, I did the same on my 6R.
https://www.youtube.com/watch?v=MfMFdakxVvQ&t=86s
Posted: Sun Sep 14, 2025 3:54 am
by ciclo
Golf 7.5 Info about flip rear emblem swap.
The emblem with axle structure (2020-->) for G8, etc... does not look good on the Golf 7.5 tailgate due to the horizontal rib.
Unfortunately, I had to return it because it was damaged, with swirls and small scratches. It seems that being meticulous is only for a select few on this planet. 🤷‍♂️🤐
In the unfortunate place where I was born, there's a saying that goes:
" Honey is not made for a pig's mouth "
... an approximate meaning in English would be:
" Pearls before swine "
https://www.youtube.com/watch?v=SGjLvfiKLuU
Posted: Sat Oct 18, 2025 3:27 am
by ciclo
...I reordered two of these special 2020--> VW emblems for the Golf 7.5 tailgate with that horizontal rib. One arrived perfect, but the other had minor damage... so I'm going to try to improve the damaged one.
1st steps:
Delicate work that will take a couple of weeks. Step by step, layer by layer with a long curing period between layers, we want it to last a long time...
If I can get the last layers of clear lacquer to shine like a diamond once polished, I'll install this special VW emblem on my 'converted' RVC Highline, which in addition to working perfectly (better than the originals) will have a nice unique-exceptional appearance.
The Aliexpress store for these special emblems no longer exists...😮
The worst part is over, the paint adherence is very good (VW Original), now it's time to put some tape on the fixing points and decide which will be the final colors.
There are still many layers ahead...
https://www.youtube.com/watch?v=7Y8SS5zDnWU
Posted: Sun Dec 14, 2025 2:15 am
by ciclo
Since I'm bored while patiently waiting for an appointment with the endocrinologist I requested online some time ago (1 month) ...
For many reasons, these are the best BSD side mirrors for the Golf 7.5 in the world. With technology infinitely better than the VW original mirrors.
- Blue Glass.
- Wide angle.
- Anti-glare.
- Heated.
- Powerful Blind Spot Light. 12V. Visible from any angle and in any condition. Related: :arrow: viewtopic.php?p=604794#p604794
https://www.youtube.com/watch?v=oGFiSfV3k-M&t=73s
... I guess I'm not profitable enough for the private 'German' company (******EU******) that manages a public health service in the unfortunate place where I was accidentally born.
Bye-bye! (4ever)😜
Monday,19,January,2026,10:50:22:32438
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20251020 DS365.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: 2026 OK!
Mileage: 65063km-40428mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 65063km-40428miles
   VCID: 290F00D8897EC922F9D-807C
   VCID: 76B51BA40840D6DAA4F-8022
   VCID: 074B66607FAADF52CF9-8052
   Air quality sensor:
   VCID: 7DA704882D768582E55-8028
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   VCID: 58E9751CE29480AA963-800C
   VCID: 47CBA6603F2A1F520F9-8012
   VCID: 392FD09879DE79A289D-806C
   VCID: 094F605869BEA922D9D-805C
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   VCID: 2B03FAD08382DB320B1-807E
   VCID: 7F5BFE80277A9792F79-802A
   Generator:
   Coding: AE2B00
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V2.clb
   Coding: 52A54640
   VCID: 52FD8734C468AAFA687-8006
   Coding: 010000
   Coding: 931F0000
   VCID: 74B121AC1E3CC4CA9AB-8020
   VCID: 372BD6A04FCA6FD27F9-8062
   VCID: 51FF8838C16ED1E251D-8004
   Coding: 090000
   Coding: 02731001FF0000005111010140890AA31F0507E401200400CF
   VCID: 323DE7B4A4A88AFA487-8066
   Data carrier:
   VCID: 3829D59C42D460AA763-806C
   VCID: 3C21C98C76EC4C8A92B-8068
   VCID: 6A8D3FD44CF8023A307-803E
End----------(Elapsed Time: 01:52, VBatt start/end: 12.7V/12.7V)-----------
Posted: Sat Jan 31, 2026 4:27 am
by ciclo
New friend.
Let's fine-tune our strings. https://www.youtube.com/watch?v=J7d9fchZeFE&t=153s
Posted: Tue Feb 24, 2026 5:42 am
by ciclo
Posted: Thu Feb 26, 2026 8:49 pm
by ciclo
USB, WIFI. ⚡📶🤸‍♂️
Even on my mini test bench, it's able to read my VW GW 3Q0907530AR...
Some 'pseudo-experts' in Piwis have generated some urban legends about procedures that even AI has believed.🤦‍♂️
My VNCI with a VM will do even better (usb, ap, wlan, PIWIS + ODIS).🧙‍♂️
https://www.youtube.com/watch?v=JJvd3vzJNDc&t=163s
Regarding PIWIS's operating procedures:
- The first impression is that it's like working on an 80s Spectrum. The interface is anachronistic.😄
- The function loading process is like those old routers that take forever to display results............ ⌛ ..... ⌛ .... :lol:
- Not at all intuitive, developed for 20th century mentalities. 🦍
Seriously, Porsche, is this your best diagnostic program for 'luxury' vehicles? What a monumental piece of garbage.💩
ODIS is 'infinitely better' in every way.💎
... and the Cupra Formentor... sorry, I got the model wrong, I meant the F Porsche Coupé. 😁
From LG LiFePO4 9Y0915105Q to EXIDE AGM EK950B.
LiFePO4
AGM
This is a top-quality installation.🧙‍♂️
If you search online, you'll find countless similar ones, but 99% are loser s**t. 😨
PIWIS is required for "PERFECT" coding.💎
Ask Porsche owners why they made this replacement...🤭
Happy weekend to everyone... without exception!
