Yes.. The same error is on the old instrument cluster.ciclo wrote:I suppose that firstly was installed the instrument cluster and at this moment had no problem.![]()
What ring of steering column has installed, the original or the which was bought with the stalks?
Check the ECU connector, all the contact terminals must be firmly seated in its slot.
... also verifies that all cables for Cruise Control System (T41, BCM, ECU) are in the correct slot.
My friend made for me the same wiring as your: https://drive.google.com/file/d/0B2nv91 ... 90WHc/view
My ECU: https://www.dropbox.com/s/vxhf93r036rtp ... 2.jpg?dl=0 (PIN 24 - https://www.drive2.ru/l/6491454/)
I changed stalks and ring. I bought this stalks:
It's possible, that used ring is broken?
My old stalks: https://www.dropbox.com/s/9o4eqrkxfeiqb ... 1.jpg?dl=0
My old ring: https://www.dropbox.com/s/8tvbrjfs0kduq ... 7.jpg?dl=0
, two great improvements for your enjoyment.
