Page 6 of 10
Re: App Connect
Posted: Tue Jun 19, 2018 10:59 am
by JaegerStriker
Dink wrote:JaegerStriker wrote: Mon Jun 18, 2018 3:44 pm
how long did they take to remove the CP and get everything sorted? im booked in with them on thursday
It took literally 10 mins to do.
They understand that they need to re-enabled bluetooth and everything?
I'm sure if they get it right they could get a lot more custom.
You getting app connect upgrade aswell?
I'm assuming that they realise they need to re-enable Bluetooth etc
Do you think I should mention it when I go down?.
Yeah I'm doing the app connect upgrade eventually. Just getting the infotaiment sorted do that when I can afford the unlock it's ready to go
Sent from my SM-N950F using Tapatalk
Re: App Connect
Posted: Tue Jun 19, 2018 11:46 am
by Dink
JaegerStriker wrote: Tue Jun 19, 2018 10:59 am
No I don't think they do realise they need to re-enable bluetooth that's why I had to pay vw to do it.
If they try to charge you for it (the bluetooth and not labour) then tell them no as vw did mine for an hour's Labour to get it sorted.
Re: App Connect
Posted: Tue Jun 19, 2018 7:02 pm
by JaegerStriker
Dink wrote: Tue Jun 19, 2018 11:46 am
they have suggested that i contact VW Retrofit instead. they have quoted £80 to get it removed and have everything set up. so ive booked with them instead.
Re: App Connect
Posted: Tue Jun 19, 2018 7:17 pm
by Dink
Yeah that's a decent price
It's a shame as I guess they could make some money by doing the full upgrade in one hit.
Re: App Connect
Posted: Tue Jun 19, 2018 7:26 pm
by JaegerStriker
Dink wrote:Yeah that's a decent price
Yeah it really is. Shame no one's figured out an app connect work around. Still have to go back to vw for that
Re: App Connect
Posted: Tue Jun 19, 2018 7:44 pm
by Dink
I thought they could do the app connect upgrade?
From what I've seen the price from vw may have gone up a fair bit since I first looked into it.
Re: App Connect
Posted: Tue Jun 19, 2018 7:55 pm
by JaegerStriker
Dink wrote: Tue Jun 19, 2018 7:44 pm
nah dont think so, from my emails with him hes said if the car didnt come with it then they cant add it on since its a retrofit.
Re: App Connect
Posted: Wed Jun 20, 2018 7:52 am
by Dink
JaegerStriker wrote: Tue Jun 19, 2018 7:55 pm
They offer it for the golf 7 so they should be able to do it.
I might ring them to see what they say.
Re: App Connect
Posted: Wed Jun 20, 2018 9:49 am
by JaegerStriker
Dink wrote:JaegerStriker wrote: Tue Jun 19, 2018 7:55 pm
Where did you see that? I Can't find it on the website
Let me know what you find out. I'm booked in on Thursday
Re: App Connect
Posted: Wed Jun 20, 2018 10:33 am
by Dink
Re: App Connect
Posted: Wed Jun 20, 2018 10:48 am
by JaegerStriker
Ohhh I see. I'm visiting someone else now.
Re: App Connect
Posted: Thu Jun 21, 2018 4:51 pm
by JaegerStriker
so ive went and got the CP removed and have the same issue as dink. bluetooth stopped working. unable to start message
having to go speak to vw at some point.
guy that removed my CP said that this is a common issue where everything is enabled but for some reason they wipe themselves off.
so for me everything worked, bluetooth, carplay untill i turned the car off and it reset itself. so now i just have radio, aux or usb for music.
he said its hit and miss on each car. he sorted it on a golf r and it worked for nearly 2 years before it s**t itself.
Re: App Connect
Posted: Thu Jun 21, 2018 8:04 pm
by Dink
JaegerStriker wrote: Thu Jun 21, 2018 4:51 pm
i took mine to vw and they sorted without an issue (well apart from the labour charge
all features are avaliable until CP is removed then it reverts back all locked down.
i don't know what vw did but if the retrofitters have full access to vw computers they shouldn't have a problem
Re: App Connect
Posted: Fri Jun 22, 2018 1:07 am
by edmountain98
Just reading the thread, so if the 3q0035842b is fitted it needs a security code activating, to make it work, then coding in aswell as paying the ~£200 for the CarPlay activating?
Thanks in advanced
Re: App Connect
Posted: Fri Jun 22, 2018 1:24 pm
by Dink
edmountain98 wrote: Fri Jun 22, 2018 1:07 am
Thanks in advanced
Yeah that's pretty much it.
The app connect code is what it is whether or not you have the right unit.
For me it was £40 For the unit, £60 For component protection removed then it was £80 For "coding" back to factory options.
