Cross Polo 6R Upgrading to BCM Max with Auto light switch
Re: Cross Polo 6R Upgrading to BCM Max with Auto light switch
MaDwArLoCk wrote: Wed Aug 23, 2017 9:23 am
ciclo wrote: Wed Aug 23, 2017 7:49 am
75x terminal works differently on 6R 7L3 and 7L6. (already commented)
You have a 6R 7L3 with a 7H0 BCM for 7L6. (doesn't help)
Now you have a 6R with a long start/stop period... evenings/mornings Image
Smile, life usually does not offer such fun opportunities.
So what does it mean for me?
It means absolutely nothing. Forget this.
Try to solve the wiring problems for your Climatronic.
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Post by MaDwArLoCk »
ciclo wrote: Wed Aug 23, 2017 10:25 am
After my morning manipulations (I've disconnected battery aprox for an hour to check Climatronic wires)
After I connected everything back, it working just fine...
MaDwArLoCk
Today again not working... 😪
Test with another BCM Max (7L3).
Tips
- Buy a 7E0 BCM Max, contact firegrafik, he maybe can help you in this regard...
e.g
viewtopic.php?f=56&t=58703&p=517343#p517343
viewtopic.php?f=56&t=58703&start=3480#p523245
they are the most updated.
- Buy the original VCDS cable for enthusiasts ($199). https://store.ross-tech.com/shop/vchv2_ent/
Your current cable is .... (define it yourself)
Note: I do not know if these two tips will solve your problems. ... you did three changes at once, from Climatic to Climatronic, BCM Max adaptation, Automatic Lights.
(and you still have to install Bixenon headlights)
where in the netherlands do you live? i'm there for a few days, i have a genuine VCDS cable with me and BCM 7E0 (not for sale, just for testing). we can have a quick look together...
MaDwArLoCk
iichel wrote: Fri Aug 25, 2017 8:14 am where in the netherlands do you live? i'm there for a few days, i have a genuine VCDS cable with me and BCM 7E0 (not for sale, just for testing). we can have a quick look together...
Thanks for offer, it would be nice!
I live in Tiel, Gelderland
MaDwArLoCk
ciclo wrote: Fri Aug 25, 2017 7:53 am I do not know if these two tips will solve your problems. ... you did three changes at once, from Climatic to Climatronic, BCM Max adaptation, Automatic Lights.
Thanks, I'll try to test with another BCM!
MaDwArLoCk wrote: Fri Aug 25, 2017 12:48 pm
Ah okay, that's still a long trip from here...150k's
MaDwArLoCk
iichel wrote: Fri Aug 25, 2017 1:18 pm Ah okay, that's still a long trip from here...150k's
Where do you live?
150 km - not so close but reachable :)
Well I live in Switzerland, but I'm visiting family and friends somewhere in the intersection Germany-Drenthe-Overijssel
MaDwArLoCk
Ohh, ok.
So you are here just for the weekend?
Or it's possible to reach you there at the workdays?
I'll be there until wednesday (actually thursday but that's my birthday, so don't come then...)
MaDwArLoCk
How about Tuesday approx at 17:00? :)
Pretty sure my mum gets mad if I miss (cooking) dinner. Let's see if we can find something by pb.
MaDwArLoCk
iichel wrote: Fri Aug 25, 2017 5:47 pm Pretty sure my mum gets mad if I miss (cooking) dinner. Let's see if we can find something by pb.
Thank you very much for your offer!
I think it's not necessary to make your mum angry! :)
Looks like I found a solution:
firegrafik wrote: Thu Dec 01, 2016 3:53 am
gti16 wrote:Hello ciclo
Here is the scan of my Polo 6r with the BCM 7H0
How can I get address 61? Appeared after installing the new BCM and my car does not have it.
I have absolutely the same issue. This is because the BCM was used,not new.
You should mark 61 control unit in the 19 Gateway's installation list. After than you should open 61 Battery Regulator and set the all bytes(at least 0 Byte) of the coding 00, after that exit from the 61 Battery Regulator, again to the 19 Gateway's installation list, unmark 61 Battery Regulator. Profit.
Thanks to firegrafik!
Now Battery Regul. is gone together with "High beam problems"!
I need more time for testing to be sure, but I think that was the problem!
Saturday,26,August,2017,13:24:01:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZAU000000   License Plate:
Mileage: 157160km-97654mi   Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 44 56 77 0B
VIN: WVWZZZ6RZAU000000   Mileage: 157160km-97654miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 D    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9851
   Revision: --------    Serial number:
   Coding: 001900D6202400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TFS02013F906070D 003015
   ROD: N/A
   VCID: 234234CE2A4EB859D4-8076
No ASAM data for: "EV_ECM12TFS02013F906070D" (VW25)
Readiness: 0010 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Revision: --------
   Coding: 210228E3227300BA842C14E844D600401300
   Shop #: WSC 31414 790 31414
   VCID: 020C514A99945151FF-8056
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3878F3A28BC8CB8111-806C
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 017140713
   Coding: 24B02BBF48E3240093300FB03DEB1ED001C0610E60042001200000010000
   Shop #: WSC 02756 790 00000
   VCID: 2D56D2F6748A7E2972-8078
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 210310 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU028.04.1013935
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU030.04.1010613
   Coding: 08BC30
   Subsystem 5 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Subsystem 7 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU026.04.1016866
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU020.04.1013618
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 A    HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0011
   Revision: --------    Serial number: 64531012301615
   Coding: 100003
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3C70EFB2B7F0E7A1F5-8068
   Component: VW10Airbag00K H08 0020
   Revision: --------    Serial number: 003GX002F4VI
   Coding: 00304B
   ASAM Dataset: EV_AribaVW10BPAVW250 A01001
   ROD: N/A
   VCID: 4A9CB96AED24491177-801E
   Subsystem 1 - Serial number: 3572SRB40000B53459C7
   Subsystem 2 - Serial number: 3582SRB40000B520C0C1
   Subsystem 3 - Serial number: 3515RRB405D6QGG0HO90
   Subsystem 4 - Serial number: 3525RRB405B6SD5OFPMN
No ASAM data for: "EV_AribaVW10BPAVW250" (VW25)
   Part No SW: 6R0 920 860 D    HW: 6R0 920 860 D
   Component: KOMBI         H03 0207
   Coding: 140800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   VCID: 3566FA9694DA36E90A-8060
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 002240
   VCID: 70E80B82A33853C119-8024
   Component: IMMO          H03 0207
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
   VCID: 6ADC19EA8DE4A91157-803E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H21 6270
   Revision: AB001001    Serial number: VWZ6Z7N8319084
   Coding: 040104020100002C0001
   Shop #: WSC 01357 011 00200
   VCID: 3D76E2B6A4EAEEA9C2-8068
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 D    HW: 7P6 035 730 D
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668399469
   Coding: 0A00000000010110
   Shop #: WSC 05314 115 12345
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 3362C48E9AAE28D924-8066
End-------------------------(Elapsed Time: 03:44)--------------------------
I am going to install Xenon headlights today!
