Page 6 of 30
Re: My polo 6r bifuel
Posted: Thu Dec 14, 2017 8:44 am
by ciclo
It fits perfectly with the correct parts, in the ETKA you have the solution. Anyway it's a very popular modification, search on the forum or other forums.
I suppose that in a "near future" (relative time) all we'll have implanted a USB connection in the brain and we will have more free time.
Posted: Thu Dec 14, 2017 9:13 am
by benzinkopf
ciclo wrote:It fits perfectly with the correct parts, in the ETKA you have the solution. Anyway it's a very popular modification, search on the forum or other forums.
ouch.
Posted: Thu Dec 14, 2017 10:57 pm
by Franciswat
Thank you! I had a look on on-line etka but couldn't find R-line bumper, only normal and cross.
I tried different models / years but w/o result!
That picture above is a bit scary!
Posted: Fri Dec 15, 2017 3:13 am
by ciclo
PR codes:
2JP = R Line
2JE = BlueGT
2JD = GTI
2JQ = WRC
Example:
If you want the glossy black front grilles for R Line front bumper
viewtopic.php?f=56&t=58703&p=494022#p494022
Posted: Fri Dec 15, 2017 11:32 pm
by Franciswat
Thanks Ciclo I did not know about this code extensions.
Yes I want the glossy black covers you bought looks simply awesome
I suppose paiting those kind of plastic will not get nice result because this parts could be not paintable.
Posted: Tue Dec 19, 2017 1:43 am
by Franciswat
Hi guys, I am having some troubles with GPL: car auto switch to GPL and immediately switch back to petrol.
An extract from autoscan (full report below) shows that:
1 Fault Found:
013190 - Low Pressure Gas Sensor (G401)
4 months ago I had same problem which was solved replacing the GPL sensor named "Bosh 281002456"
I can't belive I have to replace it again after 4 months of use..
Any suggestions what's happening?
Full autoscan below:
VCDS Version: Release 15.7.1 Running on Windows XP x86
Data version: 20150904
www.Ross-Tech.com
Tuesday,19,December,2017,02:23:31:05031
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZCY543xxx Mileage: 64370km-39997miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CNKA) Labels: None
Part No SW: 03C 906 014 BD HW: 03C 906 014 BD
Component: CNKA-MM7GV-G H02 0561
Revision: --H02--- Serial number:
Coding: 00110014002400080000
Shop #: WSC 62297 001 1048576
VCID: 60C838AF7050043E3D-5072
1 Fault Found:
P3386 - 000 - Short to Plus
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 64378 km
Time Indication: 0
Date: 2012.05.11
Time: 02:09:06
Bin. Bits: 00000100
Load: 0.0 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 89.0°C
Absolute Pres.: 1005.8 mbar
RPM: 0 /min
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210224E3217100B5842524E484D700401300
Shop #: WSC 00788 648 00255
VCID: 0008182F9710A43E5D-8054
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397EB5CBB04A35F65A-806C
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 009122110
Coding: 3CB02BBF08E10600923808006D2B0CD100C0412F60860000200000000000
Shop #: WSC 124697 483 00190
VCID: 4586C93BCCB241162E-8010
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Coding: 820000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 08BC32
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 64378 km
Time Indication: 0
Date: 2012.05.11
Time: 02:20:47
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 20251528901029
Coding: 100001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParkAsssi4K 001004
ROD: N/A
VCID: 3A7CAAC7BD4C3EEE53-806E
No ASAM data for: "EV_VW75XParkAsssi4K" (VW25)
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX011W0JJ
Coding: 003232
ASAM Dataset: EV_AirbaVW10PBAVW250 A01001
ROD: N/A
VCID: 4A9CFA07EDACAE6EC3-801E
Subsystem 1 - Serial number: 3575HRB4059124B2F99H
Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaVW10PBAVW250" (VW25)
Part No SW: 6R0 920 871 A HW: 6R0 920 871 A
Component: KOMBI H03 0505
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 346084FF9F28C89E89-8060
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Coding: 140A01
1 Fault Found:
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Coding: 140A01
ASAM Dataset: EV_Kombi_UDSV_DD_RM09 A04113
ROD: N/A
No ASAM data for: "EV_Kombi_UDSV_DD_RM09" (VW36 *)
Coding: 140A01
ASAM Dataset: EV_Kombi_DUS_VDD_RM09 A04113
ROD: N/A
No ASAM data for: "EV_Kombi_DUS_VDD_RM09" (VW36 *)
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VD_DRM09 A04113
ROD: N/A
No ASAM data for: "EV_Kombi_UDS_VD_DRM09" (VW36 *)
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002200
VCID: 70E848EFA3B0B4BEAD-8024
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VD_DRM09 A03009
ROD: N/A
VCID: 6ADC5A878D6C4E6EE3-803E
No ASAM data for: "EV_Immo_UDS_VD_DRM09" (VW36 *)
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6A8B93EA0EEB46F4-807A
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 HW: 6RD 035 187
Component: Radio 517 5124
Revision: RB101000 Serial number: VWZZZ4Q5034465
Coding: 00000400040005
VCID: 0400143F8708B81E79-8050
End-------------------------(Elapsed Time: 02:54)--------------------------
Posted: Tue Dec 19, 2017 7:23 am
by ciclo
Maybe it's not a G401 sensor fault.
1 Fault Found:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 64378 km
Time Indication: 0
Date: 2012.05.11
Time: 02:09:06
Bin. Bits: 00000100
Load: 0.0 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 89.0°C
RPM: 0 /min
If the pressure in the gas fuel rail rises above the value 10.5bar or if the sensor signal fails, the vehicle will switch to back-up petrol mode.
http://www.volkspage.net/technik/ssp/ssp/SSP_373_d1.pdf
or search for leaks in the gas fuel rail.
If you want different results, do not do the same things.
Whatever you do, be careful, the gas injection system is dangerous.
There is a leak check tool for this job.
Posted: Wed Dec 20, 2017 12:20 am
by Franciswat
Thanks Ciclo will try to replace the sensor and see if it will solve the problem.
If not I will make it check by my dealer.
Anyway I do not understand why vcds shows "low gas pressure" error if pressure is too hight (above 10,5 bar).
Should not be the contrary if there's a leak?
Posted: Wed Dec 20, 2017 11:06 am
by ciclo
I do not know.
I guess the sensor/switch G401 goes "short to plus" due to one of these reasons. (high/low pressure)
Take a look at the wiring that reaches the sensor.
For possible tests:
Note (according Elsawin) that the engine always starts in petrol mode. The changeover to gas mode takes place automatically. Prerequisites are engine temperature of 30°C and engine speed from 1,200 rpm.
Posted: Wed Dec 20, 2017 11:26 pm
by Franciswat
Hi ciclo, I checked wirings and are ok.
I will try to clean up the sensor with specific product and see If it works.
I'll let yoy know.
Ty
Posted: Fri Jan 12, 2018 5:03 pm
by Franciswat
Hi, i could finally replace the sensor and now i can confirm it was faulty!
Posted: Fri Jan 12, 2018 6:06 pm
by ciclo
Hopefully this time will last longer than the previous one.
Posted: Mon Jun 25, 2018 11:29 am
by Franciswat
Hello guys,
I need your help
does anyone know if gpl filter is the one in the picture below?
Thanks!
Posted: Mon Jun 25, 2018 11:50 am
by iichel
Yes that indeed is the gas filter.
Posted: Mon Jun 25, 2018 11:55 am
by ciclo
