Becomes very interesting ...
Adam’s T5.1 GP
Re: Adam’s T5.1 GP
Re: Adam’s T5.1 GP
They are very useful for trips that cross icy climate zones. Especially at night.Bizmo wrote: Mon May 27, 2019 8:11 am I did the heated nozzles at the same time as the Climatronic, was only a couple more wires so very straight forward, will wait to see if they make any difference in the winter!
Adam’s T5.1 GP
Using VCP LoginFinder I have managed to find a new login for BCM PQ25 7EO
Completely unknown what for, but use at your own risk [emoji16]
(84244)
(84244)
Adam’s T5.1 GP
Fatigue detection enabled (MKE) T5.1
Thanks to all involved to make it possible [emoji41]
Bizmo
- Drives: Transporter T5GP
Re: Adam’s T5.1 GP
Good work!
Just need to find a copy of ODIS near me now, or wait for VCDS to catch up I guess!
Re: Adam’s T5.1 GP
Unfortunately VCDS won’t be able to do this, or at least not all of the process. I used VCP as I didn’t have ODIS-e, but had to convert to a VCP compatible file.Bizmo wrote:Good work!
Your not too far from me are you @Bizmo?
- CNK
- Drives: 6R
Re: Adam’s T5.1 GP
how you converted Odis ZDC/XML file to VCP?
Re: Adam’s T5.1 GP
There is Odis-VCP converter on VCP forum. Converts it to .XML file
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Re: Adam’s T5.1 GP
how how how. nice[emoji1360]Adam87 wrote:Fatigue detection enabled (MKE) T5.1
Re: Adam’s T5.1 GP
Adam87 wrote: Wed Jun 12, 2019 8:26 am Fatigue detection enabled (MKE) T5.1
https://uploads.tapatalk-cdn.com/201906 ... 8d17df.jpg
Your knowledge, time and effort were crucial to discover the BCM 'Bit' to enable the MKE menu in the MFD, the icing on the cake.
A beautiful cooperation project between "five" well-known users. The information provided by each of them/us has been very helpful to achieve it, and dedicate our free time to other projects in progress.
Re: Adam’s T5.1 GP
Thanks Fernando, I feel I had the easier part [emoji38], again you started me off by showing me something else that may be possible to do, just when I think no more can be done [emoji4]ciclo wrote:[emoji41]Adam87 wrote: Wed Jun 12, 2019 8:26 am Fatigue detection enabled (MKE) T5.1
A beautiful cooperation project between "five" well-known users. The information provided by each of them/us has been very helpful to achieve it, and dedicate our free time to other projects in progress....
benzinkopf
Re: Adam’s T5.1 GP
Adam87 wrote:Thanks Fernando, I feel I had the easier part [emoji38], again you started me off by showing me something else that may be possible to do, just when I think no more can be done [emoji4]ciclo wrote:[emoji41]Adam87 wrote: Wed Jun 12, 2019 8:26 am Fatigue detection enabled (MKE) T5.1
Yeah man! You guys rock! I thot the 6R and the forum is slowing down already moving into obsolete thingy. ! Looking forward for more snd more new stuffs! Great team and topic[emoji1360]
Re: Adam’s T5.1 GP
It would be interesting if the Output Test for "Pause recommendation" was also available in VCDS for the PQ25.
An example from a youtube video for the Golf MK7.
Currently not available for our GW, logically.
Re: Adam’s T5.1 GP
Maybe possible, I will have a look at adding it tonight to the output test of the BCM, just need to find the right code to write into the label file to make it happen (if possible)
- CNK
- Drives: 6R
Re: Adam’s T5.1 GP
Does the HBA work well after this change?
