BCM High to BCM Max, AFS, LED Headlights and HBA
federicodrdpro
Drives: White Polo 6R TDI
Re: BCM High to BCM Max, AFS, LED Headlights and HBA
Post by federicodrdpro »
ciclo wrote: Tue Jan 30, 2018 5:12 am
federicodrdpro wrote: Mon Jan 29, 2018 10:00 pm EDIT:
.. I have the same results of iichel coding and appear the lights check on the tacho.
IMPOSSIBLE :wink:
Good luck!!!
Bye.
I'm Sorry ciclo. I meant the same result for the high beam problem. thank you too for the Coding :!:
iichel wrote: Tue Jan 30, 2018 8:22 am ..
just to verify, the high beams are still via the high beam stalk and the fuse box SB34 15A, and both high beams work, and the fuse is intact?
The wiring is:
from T73a/62 to exSB34 (white/green original wire)
from exSB34 (white/green original wire) to SB34 terminal
Yes the SB34 fuse is intact.
EDIT:
When the engine is ON the high beam seem to work well.
okay so I think you'll need to do it a bit differently then, but I'm not 100% sure. It would be nice if one of the experts could give some feedback.
Stalks T41/39 to T73b/8 (this is the white wire going to SB34a, but I would recommend a new wire)
Stalks T41/40 T73a/62
T73a/1 to SB34a
T73b/1 to SB36a
SB34b to left headlight T14/11 and Tacho, you don't have to change this
SB36b to right headlight T14/11, you need to isolate the old wire in T14/11 and make a new wire.
SB34 -> 7.5A fuse
SB36 -> 7.5A fuse
federicodrdpro
If I remember, this is the way for AUTO lights and other.. I already passed a new wire for right T14/11 because HBA require it.
I can directly make the wirings for AUTO lights and HBA.
I could imagine, since you add the T73a/63 input signal for high beam to the BCM, but the output T73a+b/1 is not occupied, it detects an open circuit and therefore thinks the high beam bulb is defective.
And since you want HBA anyway, maybe fix it directly.
federicodrdpro
Ok, iichel which is the coding for DRL off when blinking for LED headlights?
byte 23 bit 7, but I believe ciclo already integrated that into your coding.
federicodrdpro
Ok, it was disabled. Now it work fine.
Finally I have VCP cable with the driver! It's time to reparametrization the headlights levelling unit. :D
Someone could help me? I never used VCP.
P.S. Now everytime I turn ON the ignition start the presentation mode of the headlights. If I remember, it should start when I turn on the engine. :?
federicodrdpro
My reverse tail light work fine without the wire T73b/12 - T6/5 reverse Tail light. Is it normal? :)
iichel wrote: Tue Jan 30, 2018 12:47 pm byte 23 bit 7, but I believe ciclo already integrated that into your coding.
No, I didn't do that.
I never set additional functions in the codings during the installation process.
Not is recommend having a unit installed (e.g the 55 address) without the sensor/s that make it work correctly.
federicodrdpro wrote: Tue Jan 30, 2018 2:55 pm My reverse tail light work fine without the wire T73b/12 - T6/5 reverse Tail light. Is it normal? :)
Works, but without diagnosis...
federicodrdpro
ciclo wrote: Tue Jan 30, 2018 5:24 pm ---
Ok, friday I will plug the sensor.
Ok, I will plug it Reverse tail light from BCM.
P.S. I downloaded the AFS Unit software with VCP. How can I edit the software?
Last edited by federicodrdpro on Tue Jan 30, 2018 5:47 pm, edited 2 times in total.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Yes. donot do this at home🤣[emoji23]
This is what happen when there’s part missing in action - No bracket still!
federicodrdpro
benzinkopf wrote: Tue Jan 30, 2018 5:39 pm
[IMG]https://uploads.tapatalk-cdn.com/201801 ... 6a.jpg[IMG]
Yes, I could do it. I thought the same thing last days :lol:
I have all materials but my mechanic can't install it before of friday.
benzinkopf
btw. im looking forward for the afs module parameterization as well. but ive no idea how to download that via vcp etc. hopefully u can share later how u did that. im waiting to meet the guy with vcp capability soon
federicodrdpro
Yes, you have to enter in Xenon Range 55 then click on Up/Download, then save as name.
But I don't know if a key is necessary and I don't know how edit this file.
