Skoda Fabia VRS 2012. Auto lights retrofit OEM
VASILEIOS1972
- Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Re: Auto lights retrofit
Good morning Fernando, today is the day .
One last question.
In screen shot 3c in blue connector you wrote facilate the installation, what do you mean by this?
The wire isn't connected with this connector?
Forgive me for the foolish question, but I have to be sure.
Best regards
Vasileios
One last question.
Best regards
Vasileios
If one day in the future you need to uninstall the wiring looms for automatic lights or BCM adaptation, the blue connector will make it easier for you to remove the wiring without having to disassemble the steering wheel, airbag, etc. ... because the black wire is connected to the T41 connector and the T2 connector of the image will be fixed / connected to the original harness with the T17/1 terminal ... or it also serves not to have to remove the contact terminal from black connector T2 with terminal removal tool.
Blue connector is Plug & Play, easy.
For the installation, when you are doing the installation you will realize the utility the blue connector, it facilitates the placement of wiring looms.
I hope you understand what I mean
, it is a simple connector to separate wires/wiring if necessary.
This blue connector must always be connected for everything to work properly.
3c image.
I added this black wire thicker than the original to avoid possible problems if you change the headlights (you made a comment about it), and other technical reasons that I prefer not to explain, I don't want others to be angry with me.
This electrical installation was changed/modifyed in SK Fabia models after yours (2013 ->), by adding a relay.
My wiring looms always have to work 100%, I cannot allow them to fail.
3c image.
VASILEIOS1972
Hello Fernando the installation completed , but I do not have headlights , plate lights and I have lamp error in dash board , but I have daylights and taillights
my autoscan above , help my wife is gone kill me
Friday,30,August,2019,20:22:18:38567
VCDS Version: 19.6.1.0
Data version: 20190529 DS308.0
www.Ross-Tech.com
Dealer/Shop Name: MT SKODA SERVICE
Workshop Code: 231 44700 072242
VIN: TMBEP25XXXXXXXXXX License Plate:
Mileage: 61800km-38400mi Repair Order: bcm max errors
Chassis Type: 5J-SK25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 56
VIN: TMBEP25XXXXXXXXXX Mileage: 61800km-38400miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 CE HW: 03C 906 027 CE
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 53850 001 1048576
ASAM Dataset: EV_ECM14TSI01103C906027CE 001013
ROD: EV_ECM14TSI01103C906027CE.rod
VCID: 66C3ED1499F16A7F03-8032
Readiness: 0000 0000
Part No SW: 0AM 300 060 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6563
Revision: 00043014 Serial number: TFK01108310139
Coding: 0000020
VCID: 285FA32C9B65BC0FF1-807C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AL HW: 6R0 907 379 AF
Revision: --------
Coding: 410148DB437300B3822712E9C2D200411700
Shop #: WSC 13765 790 00049
VCID: 081FC3ACBFA59C0FD1-805C
Serial number: 25021504650800
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3A574E161D2BFEB-802A
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 C HW: 5J0 907 044 C
Component: Climatronic H08 0103
Revision: K0000000
VCID: 2A5B592445698E1FE7-807E
1 Fault Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 132
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.20
Time: 00:04:19
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 7A980B3848010000013806B03EEB9BC052C0621F60002041200400020000
Shop #: WSC 00046 648 00255
VCID: 2B555C204A9397171C-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230714 05 54 0403
Coding: 0330AD
Subsystem 2 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3211
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 4 - Part No SW: 3T0 959 537 E HW: 3T0 959 537 E
Component: E221__MFL-URO H07 0012
Serial number: 2164426
Coding: 810000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3211
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3211
Coding: 020000
3 Faults Found:
01516 - Terminal 30; Left
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 132
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.20
Time: 00:04:54
00927 - Terminal 30 (Right)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 132
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.20
Time: 00:04:54
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 132
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.20
Time: 00:04:54
Address 10: Park/Steer Assist (J446) Labels:. 7E0-919-475.clb
Part No SW: 7E0 919 475 S HW: 7N0 919 475
Component: PARKHILFE 8K H06 0210
Revision: -------- Serial number: 28261530202208
Coding: 108101
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParkAssis8K 001011
ROD: N/A
VCID: 428B1184D519765FCF-8016
No ASAM data for: "EV_VW75XParkAssis8K" (SK25)
Component: VW10AirbagT20 H09 0020
Revision: -------- Serial number: 003GX00UUUCP
Coding: 003230
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9B39A4ED29AE1F07-801E
Serial number: 3495RRB40590NHDIJH62
Serial number: 3505RRB40590NHDIAOG2
Part No SW: 5J0 920 841 F HW: 5J0 920 841 F
Component: KOMBI H04 0305
Coding: 120C01
Shop #: WSC 44700 231 72242
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 2D5152387C87992702-8078
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 032204
VCID: 68DFE32C9BE57C0F31-803C
Component: IMMO H04 0305
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB99248DE94E1F27-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 5JA 035 193 E HW: 5JA 035 193 E
Component: RNS315-EU H85 0501
Serial number: SKZAZ2R0659899
Coding: 040004110400000000000000
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3A7B6964BDC93E9F97-806E
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V11 0073
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 13765
VCID: 2F6D4830EA8BEB3730-807A
End-------------------------(Elapsed Time: 02:56)--------------------------
www.Ross-Tech.com
Coding: 0000020
Revision: --------
Coding: 01
Revision: K0000000
1 Fault Found:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 132
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.20
Time: 00:04:19
Coding: 0330AD
Coding: 020000
Coding: 020000
Coding: 810000
Coding: 020000
Coding: 020000
3 Faults Found:
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 132
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.20
Time: 00:04:54
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 132
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.20
Time: 00:04:54
Fault Priority: 3
Fault Frequency: 2
Reset counter: 132
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.20
Time: 00:04:54
Coding: 108101
ROD: N/A
Coding: 003230
Coding: 120C01
Revision: B9082001
Coding: 032204
Data medium:
Coding: 11241
Shop #: WSC 13765
VASILEIOS1972
plus I don't have reverse light , fog light
best regards
vv
best regards
vv
VASILEIOS1972
There is only one fault that causes all the others.
The power does not reach the BCM!
Red wires - green fuse 30A. viewtopic.php?f=41&t=73355&start=45#p559179
To insert the terminal of the red wire into the SB20 slot, it is necessary to move the PINK locking mechanism.
Have you done this before insert the terminal?
In your fuse box it's something like this:
VASILEIOS1972
Exactly the same my friend
Check the green fuse.
VASILEIOS1972
I am happy that the problem is so simple
I will check it tomorrow because I am very tired
I was working on fabia for four and a half hours
With the help of a very good friend professional
Mechanic and electrician on Vag group
I have two days to complete the installation with success only Saturday and Sunday
Best regards
Vasileios
Best regards
Vasileios
VASILEIOS1972
Good morning Fernando, you have absolutely right about fuse 30 and red wire everything works great!!!
But dimmer switch dimming by himself and no other light in interior, look the auto scan above
Saturday,31,August,2019,09:09:22:38567
www.Ross-Tech.com
Mileage: 61800km-38400mi Repair Order: dimmer switch fault
Coding: 0000020
Revision: --------
Coding: 01
Revision: K0000000
1 Fault Found:
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 173
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.21
Time: 09:02:48
Coding: 0330AD
Coding: 020000
Coding: 020000
Coding: 810000
Coding: 020000
Coding: 020000
1 Fault Found:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 173
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.21
Time: 09:04:03
Coding: 108101
ROD: N/A
Coding: 003230
Coding: 120C01
Revision: B9082001
Coding: 032204
Data medium:
Coding: 11241
Shop #: WSC 13765
End-------------------------(Elapsed Time: 02:52)--------------------------
what must do my friend
Best regards
vv
www.Ross-Tech.com
Coding: 0000020
Revision: --------
Coding: 01
Revision: K0000000
1 Fault Found:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 173
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.21
Time: 09:02:48
Coding: 0330AD
Coding: 020000
Coding: 020000
Coding: 810000
Coding: 020000
Coding: 020000
1 Fault Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 173
Mileage: 61801 km
Time Indication: 0
Date: 2014.01.21
Time: 09:04:03
Coding: 108101
ROD: N/A
Coding: 003230
Coding: 120C01
Revision: B9082001
Coding: 032204
Data medium:
Coding: 11241
Shop #: WSC 13765
Best regards
vv
You already know that your dimmer is not for your Fabia, but we will try to make it work.
Faults in 08, 09 Addresses are for that reason... wait a moment please.
Try this new BCM coding:
7A980B3848010000013806B03EEB9BC052C0621F60022041200400020000
Please report the result. Thanks. I'll wait.
VASILEIOS1972
nothing my friend the same issue , no interior dimming and the same fault
