UK-POLOS.NET - THE VW Polo Forum • Are You Using Oil? - Page 52
Page 52 of 70
Re: Using Oil!
Posted: Mon Aug 27, 2012 2:54 pm
by biff+
So pleased I got rid of this heap 8)
Re: Using Oil!
Posted: Mon Aug 27, 2012 5:44 pm
by skipster
biff+ wrote:So pleased I got rid of this heap 8)
No - The car is far from a heap! I still have confidence this will be sorted, but the car a far as I am concerned is brilliant to drive! Despite this, I would still buy another Polo!
Re: Using Oil!
Posted: Mon Aug 27, 2012 6:22 pm
by WatchcamGTI
It is a good car. Better than a lot of cars have paid far more for. Fun to drive, well built apart from the mirror switch and different.
Re: Using Oil!
Posted: Tue Aug 28, 2012 9:16 am
by tt509
mine is in to day for the fix :D
Re: Using Oil!
Posted: Tue Aug 28, 2012 12:19 pm
by skipster
tt509 wrote:mine is in to day for the fix :D
Good luck tt! I will await updates with interest :-)
Re: Using Oil!
Posted: Tue Aug 28, 2012 12:24 pm
by tt509
thanks mate we see how it is now they have just called to say its all done :D
Re: Using Oil!
Posted: Tue Aug 28, 2012 1:19 pm
by skipster
Cool! Yes - unbelievably I don't think it is a complicated fix.
Re: Using Oil!
Posted: Thu Aug 30, 2012 7:45 am
by kawabanga
I asked some news in a German forum about the breather modification, here's the answer:
After nearly 800 kilometers driven after the conversion, I can only see with a lot of goodwill and most exact measurement of an oil consumption might max ~ 100ml, say, it has helped!
From a software update was never mentioned, and it was not done at my local dealer.
Power is still enough there.
Here's a pic of the engine, no visible modifications to the pipe...
In the German forum they are talking about a different inner section of the pipe.
http://www.polovw.it/foro/viewtopic.php ... 12#p564781
Re: Using Oil!
Posted: Thu Aug 30, 2012 6:37 pm
by skipster
Many thanks Kawabanga for the update, 100ml per 800km(500 miles) sounds like a big improvement, in my book anyway!
Early days obviously with this and I have still yet to hear from my dealer about it, it seems that there are some reservations about the software update. I suspect its aim is to detune performance slightly, although in reality I would imagine it would not be noticeable anyway.
Thanks again,
Re: Using Oil!
Posted: Fri Sep 07, 2012 11:23 am
by kawabanga
gavs wrote:The oil capacity is actually 4.5 liters for a start.
Just changed now my oil (12.000Km) with this one (just to check for some improvements compared to Castrol Edge), and after letting drain the old oil for about one hour, I hadded 3.5 liters to reach max level on the dipstick (end of rugged area). Then I drove for about 5 km and checked again, I had to add other 0.3 liter to reach again max level (actually 2mm over rugged area)...
So I guess the standard capacity is 3.5 liters and letting it drain well you might have to add a little more oil (after one hour was still dripping, at warm engine).
Let's see if Bardhal is better than Castrol.
BTW, I also ordered the new VW breather pipe (no warranty for me having an oil consumption within tolerances): 63€
Re: Using Oil!
Posted: Fri Sep 07, 2012 1:47 pm
by stuart.cameron
Mines goes in today for the fix as it was recovered earlier today with a cracked radiator :(
Re: Using Oil!
Posted: Fri Sep 07, 2012 5:36 pm
by skipster
stuart.cameron wrote:Mines goes in today for the fix as it was recovered earlier today with a cracked radiator :(
How did that happen Stu?
Mine was checked yesterday and a new breather pipe ordered. Not sure how long I will need to wait for it though.
Re: Using Oil!
Posted: Sat Sep 08, 2012 8:26 am
by stuart.cameron
Not to sure... It happened before with a dodgy weld on the radiator :(
Lucky they have the parts in stock for the breather pipe so will get that fitted while they fit the radiator.
Re: Using Oil!
Posted: Sat Sep 08, 2012 9:14 am
by tt509
mine still not right :(
Re: Using Oil!
Posted: Sat Sep 08, 2012 1:54 pm
by skipster
tt509 wrote:mine still not right :(
Oh - still burning oil? How many miles have you done tt since oil breather change?
One course of action left, new engine!
