Page 52 of 331
Posted: Wed Feb 25, 2015 7:06 pm
by ciclo
Ugabista, it is a totally different problem that you says.
Your problem is with the Chinese module, and his problem "was" the BCM.
Posted: Wed Feb 25, 2015 7:14 pm
by Ugabista
ciclo wrote:Ugabista, it is a totally different problem that you says.
Ahh ok, thanks
Posted: Wed Feb 25, 2015 9:47 pm
by sambir
Alright...next step is to buy a gtd emblem to fit on oem gti grill. I decided to just leave the led brightness as is...only a new bcm will fix this...
The chinese set makes the fogs start I guess it only starts the fog lights and this is just how the set works...would be nice to see the drls go on also. It does give the possibility to make the headlights start instead of fogs but this is not advised for xenon headlights...but only the drl leds and fogs would look neat.
Again thank you dude this small coding change made the ch and lh look like oem and I also got auto light now...what else could I ask for..
Posted: Thu Feb 26, 2015 6:15 am
by ciclo
Posted: Thu Feb 26, 2015 10:07 am
by sambir
Aah would also be nice to fit the facelift taillights. Are you willing to build and sell me a pair of adapter cables?
Posted: Thu Feb 26, 2015 12:17 pm
by ciclo
Thank you very much for your confidence.
Long ago I have no parts to make wirings taillights. I am sorry sincerely.
However, you can buy here:
https://www.x2car.de/Adapter-fuer-VW-Po ... 1-Facelift
Posted: Mon Mar 02, 2015 9:08 am
by ciclo
Posted: Tue Mar 03, 2015 6:38 am
by ciclo
VCDS coding
DRL OFF with handbrake up.
Address 09: Cent. Elect. (J519)
Byte23 mark bit4
Remember, your binary or hexadecimal need not match those shown here.
I guess only be possible for xenon or BlueMotion.
A
good friend told me (by reviewing his BCM), but still I have to check.
Posted: Tue Mar 03, 2015 6:46 am
by iichel
Works on BM
Posted: Tue Mar 03, 2015 6:51 am
by ciclo
Perfect.
Posted: Tue Mar 03, 2015 1:23 pm
by jobbercete
Need to check that las vcds trick on my car, why do you think it will only work on BM or Polo's with Xenon?
. There's another byte/bit with that option but it's not working for me...
Ah, still pending the mod you sent me the parts...I'm looking for a drill you know...
Posted: Tue Mar 03, 2015 2:08 pm
by ciclo
Because they are the only ones with DRLs controlled by the BCM.
Do not worry, I have another "new" encoding for BCM that might work for all POLO.
I will post soon... when I solve some small problems with VCDS.
Snap a photo when you install my gift ...
Posted: Tue Mar 03, 2015 8:03 pm
by ciclo
VCDS coding
The two static cornering lights turn on with reverse
Light switch must be low beam. (or
AUTO
Byte21 mark bit3
Thanks to
wamba.
Posted: Tue Mar 03, 2015 10:19 pm
by iichel
Also works om BM :p
Posted: Wed Mar 04, 2015 2:19 am
by ciclo
Thanks for sharing your experience with
BlueMotion and the
best xenon retrofit (with all functions working perfectly),
not OEM.
The coding for static cornering lights should work on all VW POLO 6R with them.
