giannisbrendas
- Drives: polo 6r 1.2 tsi
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
hello can you give me some info about interior mirros switch? is this genuine volkswagen or aftermarket? thanks in advance
Do you mean the adjustment switch for the exterior mirrors? It is original VW, from the Polo 6C.
giannisbrendas
vento2013
- Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Iichel,
We are converting CLNA 1.6 tdi 105 hp manual to 1.6 TDI dsg.
There is no CLNA or any other 105 hp polo with 1.6 tdi dsg.
So i need to flash CAYB firmware. I will change power class in the cluster to match CAYB firmware.
Car have normal key start. Will it start considering all immo data is correct?
Or do we need to change something in starting system for dsg cars?
Any input
Iichel,
Any input
I think it should be ok. Firmware does not have the immo data. Only eeprom. So I think it will work but you never know....
what about audi a1 firmware?
It's the same only cayc instead of cayb
Hi, how is the coding for power folding mirrors via the key when locking. Thanks for the help
On PQ25, mirrors can only unfold with ignition on.
How is the coding for folding mirrors?
I see thats possible by locking the car
you can check the autoscan in my first post for all codings of all modules
Yes i have activate Byte 3 Bit 7
Left Door Coding is 0200A3
Right Door Coding is 1000AB
What is missing?
What is missing?
Perhaps a full scan would be nice to start with.
I dont have VCDS i only have OBD 11
More info --> viewtopic.php?p=529277&hilit=stalks#p529277
Preparing a 2Q0 stalk (Polo AW) for conversion to PQ25 (modifications to PCB of cruise control switch and intermittent potentiometer)
This customer will transform from the 6R0 steering column to the Audi A1 steering column with:
- Steering column and coupling from Audi A1 8X pre-facelift (passive steering column)
- 2Q0 stalks with T16 and T10 connector for stalks 5C0 971 975 and 5C0 971 974
- 6C0 slip ring with T16 connector for MFSW/Airbag 1K0 972 928
- 6C0 mount for steering column
- 6RA ignition lock with T7 connector 6RA 971 975
- 6C0 covers for steering column
- 7E0... F mirror with covers, T8 connector and 5K7 RLHS for HBA and auto lights (3G0 858 548 A 9B9 + 6C0 868 438 9B9 + 6C0 868 168 A 9B9 + 8K0 971 833)
- all
- all
