Andy Beats
Post by Andy Beats »
OomStu_ZA wrote: Thu Oct 22, 2020 1:03 pm And come to think of it, the Polo 1.0 TSI uses a dry clutch 7 speed too.
I guess they think the lack of torque of the smaller engine needs more gears, but the Gti definitely needs more.
Or a higher 6th gear.
It's not a relaxed cruiser.
MK7 Golf GTI and R have the 7 speed wet clutch gearbox, as does my 2019 Audi A4 Avant 40 TDI (190ps) - I suppose they need that 7th gear to squeeze under an emissions threshold.
Pretty much every VAG DSG car under 170ps uses the 7 speed dry clutch, the higher output cars would shred the dry plates in a much shorter time frame than would be expected for the wet clutch DSG boxes.
Even though my 31 mile each way commute is on a dual carriageway doing 75mph for 28 miles of it, my A4 is rarely in 7th gear. It is geared so high, the opportunities to be in 7th gear and not labour the engine are few and far between.
If you're on the flat at 75mph it will switch up to 7th, the slightest incline and it knocks down to 6th. Downhill it won't shift up to 7th until almost 70mph and can stay there down to about 58mph as long as you're still going downhill. If it's in 7th for even 10% of the time on a dual carriageway cruise, i'd be amazed.
I wouldn't say that the Polo GTI is droney in 6th at 70mph. 6th gear is pretty high, making 2400rpm at 80mph - barely higher geared than the Golf GTD (2250rpm at 80mph in 6th). My Manual Golf R was doing 3100rpm in 6th at 80mph.
From VW's point of view there'll be very little advantage in adding the 7th cog to a Polo GTI for emissions/fuel economy.
I don’t find my GTI+ droney at cruising speed. Compared to some warm and hot hatches I’ve owned throughout my 40+ years of driving, the Polo GTI+ is quite a relaxed cruiser.
Andy Beats
It's all relative, of course, but I do find the Gti a noisy and therefore tiring cruiser.
Even compared with my previous 'beats' , 80mph is a noisier affair in the Gti (exhaust and tyres).
I feel another gear would deal with the exhaust note, the revs seem to make the exhaust drone.
Then you get the wife's Evoque, which wafts along so silently that even she found herself doing a very illegal speed the other day. :D
But I didn't buy it to cruise, really, so not a huge problem.
Stuart_Rendall
Post by Stuart_Rendall »
Recently had an opf/gpf back Milltek exhaust system fitted to my car and I have also wrapped the painted part above the grill in gloss black. Subtle difference but imo looks much better. The exhaust us also noticeably better after only around 100miles. Not the best photos but not has much time to get out.
Looks good mate!
How hard was the wrap? Did you do it yourself?
Stuart_Rendall
S_94 wrote: Thu Oct 22, 2020 7:22 pm Looks good mate!
Yeah, did it myself. Took maybe 10minutes was a bit fiddly but worked out well.
fran_92
Drives: Polo GTI 200hp
Post by fran_92 »
Stuart_Rendall wrote: Thu Oct 22, 2020 7:32 pm
can you upload a video to youtube of the exhaust sound? Is it resonated?
Stuart_Rendall
fran_92 wrote: Thu Oct 22, 2020 7:48 pm can you upload a video to youtube of the exhaust sound? Is it resonated?
It isn't resonated. After hard drives there is alot of sound from inside and I get the occasionally fart or bang from it but they are very few and far between. I have heard it does take a while to get the full sound out if the exhaust.
https://youtu.be/rxh8AwKALWM
PMCK95
Drives: Polo GTI plus
Post by PMCK95 »
The badge looks good too. How did you do that?
Stuart_Rendall
PMCK95 wrote: Thu Oct 22, 2020 8:23 pm The badge looks good too. How did you do that?
Got it from Badgeskins, just a sticker that goes over the radar badge but doesn't interfere.
mjsaville
Post by mjsaville »
Stuart_Rendall wrote: Thu Oct 22, 2020 8:14 pm
Just listened to this... Sounds good, clear improvement over stock!! Thanks for posting.
MJ
Thanks mate. Could you share where you bought the material from please? :)
Stuart_Rendall
S_94 wrote: Thu Oct 22, 2020 9:41 pm
Just got a small role from Ebay, here is the link to the one I got https://www.ebay.co.uk/itm/174267008378
fran_92
Post by fran_92 »
It sounds really good.. the problem is that it is not legal without the middle resonator :(
