6R 1.6TDI 90HP CAYB 2009
Re: 6R 1.6TDI 90HP CAYB 2009
Easiest way is to drop the bumper and release the clips from the back and pop it out
It can be done with the bumper in place though - however the tabs will likely break on the old grill rendering it useless.
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Hmmm...It is not possible to make removing the fog lights, strip without the bumper?alexperkins wrote:Easiest way is to drop the bumper and release the clips from the back and pop it out
Or it is best to take the bumper?
Depends if you want to save the grill or not
If your not bothered, loop some wire around the grill holes on one side, and pull firmly, whilst reaching round through the fog grilles or from underneath and pushing on the back
- Ugabista
I have the advantage, it is to exchange with another person.alexperkins wrote:Depends if you want to save the grill or not
It's all arrested for fittings or have screws?
Not sure I get what you mean
The grill is held in with clips all the way around, they have to be released from the back if you want to get it out in one piece
- Ugabista
Okay, it's better not to invent and remove the bumper before it spoils the exchange with the other person.alexperkins wrote:Not sure I get what you mean
Thank you friend
ORiOn
- Drives: Polo BlueGT / Audi S5
It is easily removed without removing the bumper! Just remove the fog light covers and start pulling from one side, it will be easier...
- Ugabista
Re: RE: Re: 6R 1.6TDI 90HP CAYB 2009
Thanks friend [emoji106]ORiOn wrote:It is easily removed without removing the bumper! Just remove the fog light covers and start pulling from one side, it will be easier...
Good modifications
, enjoy them.
My mod (that you know) is on the right way, I hope to share more information soon ...
- Ugabista
Come her, friendciclo wrote:Good modifications, enjoy them.
- Ugabista
Hello guys, a scan I did the bit with the VCDS accused me this error:
Address 2E: Media Player 3 Labels: 5N0-035-342.lbl
Control Module Part Number: 5N0 035 342 E HW: 5N0 035 342 E
Component and/or Version: SG EXT.PLAYER H13 0240
Software Coding: 010000
Work Shop Code: WSC 12345 123 12345
VCID: 295F8B6340361469191-807C
1 Fault Found
03138 - Input AUX IN
009 - Open or Short to Ground
Freeze Frame
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 104
Mileage: 128080 km
Time Indication: 0
Date: 2005.14.29
Time: 21:08:58
My radio is a RNS 315. I can erase the error, that is, delete, and back afterwards. Apparently everything works fine. Does anyone have any idea what could be
1 Fault Found
Freeze Frame
Fault Priority: 4
Fault Frequency: 1
Reset counter: 104
Mileage: 128080 km
Time Indication: 0
Date: 2005.14.29
Time: 21:08:58
Have you got an aux in fitted on your RNS315?
- Ugabista
Yes, RNS315 it has direct entry.alexperkins wrote:Have you got an aux in fitted on your RNS315?
- Ugabista
[emoji651] This is normal[emoji780]Ugabista wrote:Hello guys, a scan I did the bit with the VCDS accused me this error:
1 Fault Found
Freeze Frame
Fault Priority: 4
Fault Frequency: 1
Reset counter: 104
Mileage: 128080 km
Time Indication: 0
Date: 2005.14.29
Time: 21:08:58
My radio is a RNS 315. I can erase the error, that is, delete, and back afterwards. Apparently everything works fine. Does anyone have any idea what could be![]()
