Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
Re: Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
Pave, you have all the information on the first page of this topic. viewtopic.php?f=56&t=68178#p509260
Headlight connectors (like most connectors) have a terminal lock mechanism (pink).
The control unit can be installed wherever you want (but the right place is near the glove compartment), connected to the CAN-lines power train. It can be connected to wires that reach the BCM but it is easier to connect it to another location.
The easiest thing for you is in the CAN lines that you had to isolate in the instrument cluster. T32/28, T32/29.
Pave
Drives: 1.2 Tsi Highline 2011
Post by Pave »
ciclo wrote: Sat Jul 08, 2017 11:28 am Pave, you have all the information on the first page of this topic. viewtopic.php?f=56&t=68178#p509260
Yep, trying to read that million times....
I figured out that locking mechanism by accidentally after day or two wondering that connector ... :?
Just installed that control module so that all wires are long enough... don´t know why that harness isn´t made so that module could be installed at oem position... ?!?
I´ve also found that you made place to those can-lines to that wiring from Instrument cluster to bcm at my bcm max installation guide ... there is part "for new mods in the future" :D
You are amazing!!
I routed the power wire to fusebox... I think correct place is terminal 15... so fuses between 9-16 ?!? Am I right ??
I placed that wire at pin 10 because it it only available there...
What size of fuse that afs system needs?
I think everything is almost done now. Just waiting for that bracket for sensor so I can install it.
Thanks ciclo for help again!
+15 5A I think is ok.
Pave wrote: Sat Jul 08, 2017 12:17 pm
You are amazing!!
But you have to connect the CAN lines of the xenon control module to the old and original CAN lines (ISOLATED) that they belonged to the instrument panel.
Never to the new CAN lines that I sent you for your new BCM.
Extremely obvious and simple.
Original diagram (Elsawin).
Pave
Post by Pave »
iichel wrote: Sun Jul 09, 2017 1:43 am +15 5A I think is ok.
Thanks!
Pave
Post by Pave »
ciclo wrote: Sun Jul 09, 2017 2:30 am
You are amazing!!
Thanks for the correction!!
Obviously I was wrong... maybe it is wiser to forget all those installations...
Eduard
Drives: 6C
Post by Eduard »
Hei gents!
I plan on going for xenon installation ( OEM ) with the AFS, Autoleveling and so on. So far I bought the original headlights, and I am thinking of ordering this kit here: https://kufatec.de/shop/en/volkswagen/p ... vw-polo-6r
I also have the Halogen to Xenon conversion cable ( 10 to 14 PIN ) with the additional wiring.
Basically I would like to know if there's anything else I would need to set this up, and, lastly ( but most important ) do you have any idea if I need to change my BCM ?
I will leave an autoscan here, though the BCM HW Number is 6C0 937 089 and in a wiki link at Ross-Tech it says it should support it.. though i'm not sure. ( link here: http://wiki.ross-tech.com/wiki/index.ph ... tting_(6R) )
Please let me know if my BCM supports xenon lightning or ... does it need to be changed, and, is there anything else that I need to buy before starting the procedure ?
BIG THANKS!
Chassis Type: 6R (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
Mileage: 27512km-17095miles
Address 01: Engine (J000-CUSA)       Labels: 04B-907-445-V1.clb
   Part No SW: 04B 906 027     HW: 04B 907 445
   Component: R3 1,4 DCM6.2 H07 8205
   Revision: 21003001
   Coding: 01114012432401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM14TDI03004B906027 003019
   ROD: EV_ECM14TDI03004B997027B.rod
   VCID: 5EB3F85D41E606B1BB-800A
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08503245140827
   Coding: 21DD2485892733C6091610720051842491CC90080007C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 336579E99AE4FBD924-8066
Address 08: Auto HVAC (J65)       Labels: None
   Part No SW: 6C0 819 045 C    HW: 6C0 819 045 C
   Component: Heizung       H02 0103
   Serial number:  1405291B-1136
   Coding: 201000000000000200
   ASAM Dataset: EV_HZGManueHMMValeoPQ26 001001
   ROD: EV_HZGManueHMMValeoPQ26_VW26.rod
   VCID: 275D9DB95E3C877988-8072
Address 09: Cent. Elect. (J519)       Labels: None
   Part No HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0047
   Serial number: 009458017422
   Coding: 000008404253005B4B8440004007038800005B0251010000000000000000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_BCMA0_004_VW26.rod
   VCID: 55A1E77134D0C5E9EA-8000
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU001091442441673
   Coding: 0400A0
   Front Passengers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU003091442468341
   Coding: 1400A0
   Drivers Door Rear Control Module:
   Subsystem 3 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU009091442525731
   Coding: 0400A0
   Passengers Rear Door Control Module:
   Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU010091442532611
   Coding: 1400A0
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag00Z 001 0330
   Revision: --------    Serial number: 003LM004MBGD
   Coding: 88C0C000000000005C000000000800000000
   ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 316973E160F8C9C956-8064
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 410 820 308 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00BB15739C1930N
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 410 820 308 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00062837AA1D2AO
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 442 150 609 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00C31725223B22Z
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 442 150 609 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C31725220B17.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 6C0 920 741 A    HW: 6C0 920 741 A
   Component: KOMBI         211 0290
   Coding: 472509002180000800083A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009040
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 214983A130187949C6-8074
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0047
   Revision: --------    Serial number: 009458017422
   Coding: 030100044F0A590071000000000000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 65C1D7B164B055697A-8030
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Serial number: 2411422172402137AD1B
   Coding: 280000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61247G58362821697892
1 Fault Found:
197175 - Control unit for battery monitoring
          U1050 00 [008] - No Communication
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 47
                    Reset counter: 14
                    Mileage: 27320 km
                    Date: 2017.06.26
                    Time: 00:00:02
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: OFF
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PE9J0052
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 326B7CED65FEF2D12F-8066
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-ENT2.clb
   Part No SW: 6C0 035 869 B    HW: 6C0 035 869 B
   Component: MU-E--ER      820 6220
   Serial number: 26081400010666
   Coding: 02620000BE00000041110001000000001F0004840000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 2A5B648D4D2EBA1197-807E
End-------------------------(Elapsed Time: 02:54)--------------------------
Eduard
Drives: 6C
Post by Eduard »
Bump ... if anyone can help ..
I'm sorry but I don't know anything about the Polo 6C. Keep in mind that you have a 6C that is massively different from a 6R
Eduard
Drives: 6C
Post by Eduard »
iichel wrote: Wed Jul 12, 2017 4:27 am I'm sorry but I don't know anything about the Polo 6C. Keep in mind that you have a 6C that is massively different from a 6R
That is what I was afraid of ... so after all I have a 6C, could have never made a difference because it doesnt look like it ( only the interior does ).
Outside it is exactly the same as Polo 6R ( without the small front skirts / rear bumper ) .. like this and the interior looks as follows: http://carplace.uol.com.br/wp-content/u ... terior.jpg
So I was never able to figure out if it is a 6C or a 6R. Do you, by any chance, know someone i could email for help ? For a price, of course... I would really like to get this done, now that I have purchased everything.
At least simply instaling the new headlights without autoleveling or AFS.
Hm difficult one. Maybe you could try Ross tech forum, if you have genuine vcds.
Otherwise, maybe a crazy idea, why not become an expert yourself. ;)
Some others you can try to contact:
http://www.polo6rfreunde.de/index.php/U ... -Lukas962/
https://www.mypolo.nl/xenforo/threads/o ... ost-185715
Eduard
Drives: 6C
Post by Eduard »
Hehe! Thanks for the reply,
Don't get me wrong :D I am very handy with removing and installing parts, improvising on the fly, the only issue is I suck at is the electric part. I will have to start learning how to read those electric diagrams for that matter :lol:
Thanks for the two new forums, will try and do some research in those as well
The one is the German forum but they have a bit of a strange policy for posting. The other is 'my' Dutch forum.
For reading wiring schemes, check these videos from Ross tech:
https://www.mypolo.nl/xenforo/threads/c ... ost-176192
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
ciclo wrote: Fri Apr 29, 2016 3:23 pm I sit in this topic to help if necessary.Image
1)I have few questions regarding full led headlamps
2)Is there any difference between afs and auto level sensor or afs is module and auto level sensor is connected to Afs
3) if auto level sensor and afs is different and these headlights supports only auto levelling do I need only sensor to fit ?
4)my car is equipped with bcm 6RU 937 087M will this bcm support auto levelling sensor ?
Thanks in advanced.
2) the AFS system contains the level sensor on the rear axle, the AFS module and the AFS motors. The motors are integrated in the headlight. You'll also need the wiring.
3) you'll need to fit the entire AFS system.
4) AFS will work with any bcm since it's a separate system. It's operated by the powertrain CAN. But for the LED headlights of the Polo 6C, you need a different bcm. It is the 7E0 937 090 Z4Y. I have the same BCM and it works well.
