☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼ --- NOT FOR SALE
Aquavalver wrote: Sat Oct 05, 2019 2:13 am Hello Fernando,
I have recently got a 2013 6R Blue GT, it has MFSW, full climatronic (not the dials) and rain sensor/auto-dimming rear view mirror. Which loom do I need and do you need any other info?
Thanks!
Hello Aquavalver.
You need the 'A' model on the first page of this thread, for Model year D, E.
+ BCM coding (easy :wink: ).
Aquavalver
Drives: 2013 Polo Blue GT
Post by Aquavalver »
ciclo wrote: Sat Oct 05, 2019 2:52 am
Thanks!
Hello Aquavalver.
Thank you! In the link you gave for the autolight switch, does the switch come with a wire and sensor to activate the lights, or does it use something already existing in the rain sensor/auto-dimming rear view mirror? I have seen some switches that have the sensor in the switch rather than using the wire and sensor
You need an original-genuine AUTO switch (like the link I provided or supplied by a VW dealer).
Those light switches you saw with a light sensor attached by a cable are not for genuine-original installations and do not work properly (all functions) on the Polo 6R.
Do not buy them, your BlueGT deserves a genuine electrical installation in which everything will work perfectly (you have all the information on the first page).
Aquavalver
ciclo wrote: Sat Oct 05, 2019 3:54 am You need an original-genuine AUTO switch (like the link I provided or supplied by a VW dealer).
Ok, thanks very much for your help! :)
Aquavalver
Thanks!
Hello Aquavalver.
My autolights switch has arrived, so if you could please pm me for how to purchase the 'A' model for model year D,E from you.
Many thanks!
VW_Polo
Drives: Polo 6R 1.2 TSI Highline
Post by VW_Polo »
Hello ciclo/ Fernando,
I‘m new at this forum and I have a question about the autolight and ch/lh function. May be this is Not the Right thread but I Can’t contact you in any other way. I drive an 2010 Polo 6R with H7 Halogen bulbs and an factory installed RLS. I want to get the autolight and ch/lh function in this Polo. I know that there‘s a difference in the wiring and bcm between xenon/start-stopp equipped Polos an mine, but may be you can help me to get it in my car. I don‘t really know where the difference between the wirings is located.
Many thanks in advance!
Hello, welcome.
Here is another 6R 2010 that made the adaptation of BCM High to BCM Max + automatic lights.
viewtopic.php?f=56&t=68980#p514546
viewtopic.php?f=56&t=68980#p514815
To consider:
- BCM Max model to install. There are several possible models.
- Factory wiring, there are several possibilities according to factory equipment.
It determines which wires to install and isolate.
I know it is difficult to understand at first, but everything becomes very simple if you understand that the BCM is the part that must control the necessary lights for automatic lights. You should ask yourself what lights in your car are not controlled by the BCM.
If you open a thread in the 6R section and provide the information from your 6R (images, autoscan), I may help you.
Under no circumstances will I manufacture your wiring looms because I no longer buy the necessary material to manufacture them.
VW_Polo
Post by VW_Polo »
Hello ciclo,
thanks for the fast response.
Is there any opinion to geht this wiring? Is may be any other user able to manufacture the required cables? Unfortunatly I’m not very experienced in this because I don‘t know what exactly to do :( .
Thank‘s for your help in advance.
VW_Polo
Post by VW_Polo »
Hello ciclo / Fernando,
currently I’m not home, but next weekend I will be able to write a own thread about it with further information about my cars technical specifications, pictures and a autoscan. I hope that this will help.
I also don‘t know which bcm I exactly have to buy because my current bcm is an highline 6R0 937 087 D HH46 S0207.
Thanks in advance.
Best regards and have a nice weekend!
Have a nice weekend too.
leroylobo
Drives: GT TSI
Post by leroylobo »
Hi Ciclo
I'm from India and I want to purchase your B- Wiring for BCM Max adaptation + Automatic Lights Wiring + CH/LH for my Polo 6r GT 1.2 TSI CBZB. Let me know how we go ahead with the purchase.
Regards
Hello leroylobo.
Please, in order for me to manufacture your wiring looms 'B' you have to provide me with the following information as specified on the first page ...
Requested information
-Pictures from:
Relais holder.
Lights switch connector wires (both sides), T17.
Dimmer connector, T6.
Fuse box.
New BCM.
Front of your 6R.
-VCDS Autoscan.
As recent as possible.
It is the previous step to the purchase of my wiring looms.
Please do not omit any of the requested information, in which case I will not be able to manufacture your wiring looms.
Example: https://drive.google.com/file/d/0B2nv91 ... k2Q1E/view Just as a reference so that you know the pictures I need.
You can post the information here in the following post/reply, but it is more advisable to open a new thread in the 6R/6C section.
Thank you very much.
leroylobo
Drives: GT TSI
Post by leroylobo »
Hello Fernando,
I have created a new thread as requested by you.
viewtopic.php?f=56&t=74044
Thank You
Thank you very much for informing me.👌
