UPGRADING BCM 6R
govindsharma
Drives: polo 1.2 petrol HighLine
Re: UPGRADING BCM 6R
Post by govindsharma »
Dear PDC is there and it is in auto scan.
govindsharma
Dears
can anyone tell me the part no of small and large fuse terminal connector.
Thank you.
Standard Power Timer --- SPT
Junior Power Timer --- JPT
iichel wrote: Sat Nov 11, 2017 3:47 pm if the PDC is on the autoscan, it's connected to CAN :)
Image :lol:
viewtopic.php?f=56&t=69603&start=75#p526944
govindsharma
Dear Sir
Is it mandatory to align tires after placing new tpms sensor or its ok.
thank you.
- Wheel balancing should be done whenever a tire is disassembled.
- Checking wheel alignment is a process that must be done regularly but not specifically when the tires are disassembled.
WHEEL ALIGNMENT AND BALANCING ARE IMPORTANT FOR SAFETY AND MAXIMUM MILEAGE FROM YOUR TIRES! Image
...and comfort
govindsharma
Thank you Dear.
govindsharma
Dear Ciclo Sir
Good Evening I had installed TPMS Antenna in my car today and found that there is inbuilt tire measurement is 16 17 and 18 and in my car it is 15 inch tire.Dear please tell me how can i get rid of this.
Thank you.
Use the rdks editor from Skoda pilot to make new config file and flash with vcp
viewtopic.php?f=56&t=58703&start=3645#p525012
govindsharma wrote: Sat Jan 13, 2018 10:23 am Dear Ciclo Sir
Thank you.
To configure the parameters to your liking it's necessary to generate a file with a RDKS editor and load them with the original VCP.
However, if any of the parameters already integrated has the wheel pressures that match your tastes or personal needs you can set that parameter. What matters are the pressures, the parameters denomination is only a denomination for your personal information in case you have different sets of wheels (summer / winter)... or other reasons.
Thanks for the images you sent me by email. 8)
You can upload them to the forum if it's your wish.
govindsharma
Dear Good Morning
Can VW Service Center modify its config file for 15 inch tire or its with only VCP pro.
Thank you.
I'm afraid that a VW dealer can't do this job with the ODIS on your 6R ... or should not, because this TPMS unit isn't considered as original equipment for your 6R.
Buy original VCP or find someone in India near you with the original VCP. Loading the file with the parameters to your taste for your RDKS unit doesn't take more than two minutes.
I can do it free for you if you send me the RDKS unit ... but it would take a huge amount of time (India to Spain and back), I don't think it is the best solution.
govindsharma
Dear Good Evening
Here is the final result in my car of TPMS.I had installed all parts of TPMS today with Antenna and tire sensors.I had given power to Antenna from fuse 17 which is vacant. CAN high and low from PDC unit.Dear all is working well. But please tell me if air is low in any of the tire then where it indicate either in IC with low pressure indicator or in four wheel figure which is in MFD.
Thank you.
i'm not sure about SB17, it's listed as the fuse for the windscreen washer pump.
it it can be OK. i think it should be a +30 (constant power) for the TPMS high.
