Polo 6C Rain Light Sensor DIY Help
n4s
Drives: 1.2 TSI Alive
Re: Polo 6C Rain Light Sensor DIY Help
Post by n4s »
to all people that had difficulties with the BCM coding, if nothing is connected to the BCM C15, means that the LinBus on that Pin is Off and it is necessary to activate it.
BCM byte 20, bit 1 - Roof_lin (in VCDS) needs to be active to enable that LIN BUS.
SelmanAkts
Drives: 6C
Post by SelmanAkts »
Hello,
On 6C, where is the cable going from pin 2 of the Auto difference sensor switch (10 pin) to the BMC connected to? I searched everywhere, please help
SelmanAkts
Drives: 6C
Thank you for your help. The schematic says t73a/43. Isn't the T73a component 24 pin?
T73 = 73 pins
T73a is one of the three connectors on the 6C BCM (J519), you can see its location in the PDF (at the end, pg 493).
Use the PDF tools for a more comprehensive search.
Tinman
Drives: Polo 6C 1.0 Litre R Line 110hp
Post by Tinman »
Hi, Did you check the harness going into the rotary switch to see if pin 2 is wired (I think, I cant remember if thats the wire for auto function, is been awhile since i did the auto/rain sensor mod). On my 6C is was already wired, I'm not sure if this standard or only specific trim (Mine is Rline Trim).
