Retrofitting of Cruise Control by MFS on Polo 6R, T5, T6
dnoermann
Drives: T5.2 and Polo 9N3
Re: Retrofitting of Cruise Control by MFS on Polo 6R, T5, T6
Post by dnoermann »
After
- changing TGS Coding from A1 to A3 on both
- changing BCM Coding Byte 3 bit 7 to 1
- re adaption of the "One Touch" window operation
automatic mirror folding by pressing Close Button is working.
Adam87
Drives: T5.2
Post by Adam87 »
dnoermann wrote:
Adam87 wrote: Tue Jan 01, 2019 10:10 pm Following with interest, I have a T5.1 (2015) with the aim to fit ACC, I have a T6 ABS unit with look and plug (which I think when I last checked only had a larger + wire), I have a radar, steering wheel with ACC buttons (already installed) and T6 BCM (already installed)
Adam, i finalised my ACC retrofit, contact me if you still like to retrofit your's.
Brilliant work, well done!
Yes I definitely want to get this all installed, could you send me some detailed photos of bumper work?
I already have T6 MFSW with Acc, BCM and cluster fitted. Just the radar, wiring and ABS module. How did you do the ABS? Was there only a larger +v wire to install and repin?
dnoermann
Post by dnoermann »
So for everyone who does not have a Bosch EU5 ECU which can be patched.
Or who is not abel to patch the Firmare.
I just saw that some russians did a Translator Box, to use MFSW in PQ25 with any EU5 ECU.
Only work for CCS.
It looks like it translates the LINBus Signals to emulate the Buttons on the Stalk.
Original in russian: https://www.drive2.ru/l/546511156148177688/
GoogleTranslated: https://translate.google.ie/translate?h ... &sandbox=1
Hehe, just saw that Ciclo already posted it here :) viewtopic.php?f=56&t=58703&start=4725#p563434
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Firegrafik video for CC
https://youtu.be/JOi3wmnO5F4
dnoermann
Post by dnoermann »
open source Steering Wheel Adapter:
https://github.com/v-ivanyshyn/mqb-stee ... el-adapter
