UK-POLOS.NET - THE VW Polo Forum • Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R - Page 7
Page 7 of 15
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
Posted: Sat May 19, 2018 7:53 pm
by MaDwArLoCk
High Beam Assist
I was following Fernando's manual https://uk-polos.net/viewtopic.php?f=56 ... nt#p503577 Thank you! 🙏
Necessary parts
Old mirror mounting
I used Firegrafik's stencil
Applied primer
New mirror mounting
Mirror on the place
New rain/light sensor
HBA -ON 😎
And all light indications are ON
To activate Front Fog Light indication is necessary to change Byte in eeprom
Byte 02D4 from 7C to 7E
And Fog light should be connected to BCM or a wire T32a/30 :wink:
Posted: Sat May 19, 2018 8:06 pm
by smg_shardul
Excellent job madwarlock...,,[emoji106]
U don't need to change stalk ?
Posted: Sat May 19, 2018 8:36 pm
by MaDwArLoCk
Thanks, Shardul!
I will do it in future, but HBA works with old stalks as well.
You just need to manually return it to middle position :D
Posted: Sat May 19, 2018 8:51 pm
by iichel
I think I got some spare parts to convert a 6R stalk to a 7E0 stalk, with CC. It's the internal slider board and the cover of the stalk.
Posted: Sun May 20, 2018 6:56 am
by ciclo
MaDwArLoCk wrote: Sat May 19, 2018 7:53 pm High Beam Assist
PICS....
Great Job!
- HBA 8)
- Front Fog Light indication 8)
Buy the stalks in new condition from the VW dealer, it's worth it. (ASAP :lol: and https://uk-polos.net/viewtopic.php?f=56 ... 90#p498666 :lol: )
Posted: Sun May 20, 2018 12:38 pm
by MaDwArLoCk
iichel wrote: Sat May 19, 2018 8:51 pm I think I got some spare parts to convert a 6R stalk to a 7E0 stalk, with CC. It's the internal slider board and the cover of the stalk.
Thank you for offer, Michel!
ciclo wrote: Sun May 20, 2018 6:56 am
Great Job!
- HBA 8)
Thank you, Fernando! 8)
I don’t want to hurry with buying new stalks because my next mod will be:
It’s a new steering wheel from Tiguan with heating 8)
To connect the “heating”, it is necessary to mix the MQB and PQ25 slip-rings.
Modification of the slip-rings will be almost the same like here: https://www.drive2.ru/l/462910064408134206/
Probably, later I will buy stalks without CC!
Guys from D2 developing solution for “CC on MFSW” for PQ25. (On PQ35 it’s already successfully working!)
So for now I will use old stalks!
Posted: Sun May 20, 2018 2:10 pm
by MaDwArLoCk
Fernando, could you please review my current coding
Sunday,20,May,2018,15:36:42:00006
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ6RZAU0   License Plate: HBA
Mileage: 164200km-102029mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 44 55 56 65 77
VIN: WVWZZZ6RZAU   Mileage: 164200km-102029miles
20-High Beam Assist. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 D    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9851
   Revision: --------    Serial number:
   Coding: 001900D6202400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TFS02103F906070D 003015
   ROD: EV_ECM12TFS_003_VW25.rod
   VCID: 234FB15E2AD5FE5C25-8076
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Revision: --------
   Coding: 210228E3227300BA842C14E844D600401300
   Shop #: WSC 31414 790 31414
   VCID: 0201D4DA990F17540E-8056
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0812
   Revision: V0000000
   VCID: 387576328B538D84E0-806C
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 109160060
   Coding: 26B02BBF48E3240093300F916EEB1ED85AC0676F600530F0200000030800
   Shop #: WSC 78134 026 411302
   VCID: 2A515C7A45FF2F1466-807E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 280415 03  37  0059
   Coding: 0288DD
   Subsystem 2 - Part No SW: 6R0 959 801 BF    HW: 6R0 959 801 BF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 8662
   Serial number: KU0KU021071552021861
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BM    HW: 6R0 959 802 BM  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 8662
   Serial number: KU0KU021081552334528
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Subsystem 7 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU026.04.1016866
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU020.04.1013618
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 A    HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0011
   Revision: --------    Serial number: 64531012301615
   Coding: 100003
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3C7D6A22B76BA1A404-8068
   Component: VW10Airbag00K H08 0020
   Revision: --------    Serial number: 003GX002F4VI
   Coding: 00304B
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A913CFAEDBF0F1486-801E
   Serial number: 3572SRB40000B53459C7
   Serial number: 3582SRB40000B520C0C1
   Serial number: 3515RRB405D6QGG0HO90
   Serial number: 3525RRB405B6SD5OFPMN
   Part No SW: 6JA 920 840 F    HW: 6JA 920 840
   Component: KOMBI         H16 0709
   Coding: 140801
   Shop #: WSC 00046 123 12345
   VCID: 3E79602AA177B3B42A-806A
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 164201 km
                    Date: 2018.05.20
                    Time: 01:08:35
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002200
   VCID: 68D5E6729B73DD04B0-803C
   Part No SW: 7E0 857 511 D    HW: 7E0 857 511 D
   Component: FLA           H09 Q028
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 01747 666 28888
   VCID: 2B5F597E4205361C9D-807E
1 Fault Found:
15466754 - Initial Adapation Not Performed
          U1117 00 [008] - -
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 164201 km
                    Date: 2018.05.20
                    Time: 00:59:35
   Component: IMMO          H16 0709
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD19C7A8D7FEF14A6-803E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H21 6270
   Revision: AB001001    Serial number: VWZ6Z7N8319084
   Coding: 08010402010000AC0001
   Shop #: WSC 01357 011 00200
   VCID: 3D7B6726A471A8AC33-8068
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F674D6EEA1D4A3CB1-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   Shop #: WSC 00788 648 00255
   VCID: 77F7B50ECECD42FC29-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 30000000006989
   ROD: EV_RDKBERU30_005.rod
   VCID: 3777750E8E4D82FCE9-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 D    HW: 7P6 035 730 D
   Component: TELEFON       H05 0570
   Revision: 1B001001    Serial number: 00007668399469
   Coding: 0A00000000010110
   Shop #: WSC 05314 115 12345
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 336F411E9A356EDCD5-8066
End-------------------------(Elapsed Time: 03:37)--------------------------
I have one fault in Address 17: Instruments it appears every time i turn on ignition.
VCDS doesnt give description however ODIS-E showing this:
No communication with TPMS? :o but TPMS working without any faults or problems...
What could it be?
I didn't desabled Indirect TPMS, could it be the reason?
And one more thing, How to enable Safe-Lock?
I thought it's on but after the car is locked from remote, i can open doors from inside...
Posted: Sun May 20, 2018 8:08 pm
by ciclo
Heated MFSW, is a good project. :wink:
24B02BBF48E3240093300F916CEB9ED85AC0670F600530F0200000030800
Check the Safe-lock.
I don't know how to solve the sporadic IC fault with priority 6. (direct TPMS)
6 = it's something you should not worry about.
Speculation: Could be due to the IC warning light for direct TPMS, which is not activated in ours IC if there is a warning, the warning is only with a "gong" and the information in the MFA +, "only" :lol: .
Nobody is perfect. Having both TPM systems working on our PQ25 is a luxury. 8)
New gen. of original VCDS interfaces provide the same information that ODIS-E.
Posted: Sun May 20, 2018 8:16 pm
by smg_shardul
Safe lock depends on coding ?
My doors also opening from inside when locked by remote
Which byte in central electronics we need to change for safe lock ?
Posted: Sun May 20, 2018 8:22 pm
by ciclo
BCM, Byte0 Bit1, enabled, central locking WITHOUT Safe function.
So...
Posted: Mon May 21, 2018 4:40 pm
by MaDwArLoCk
ciclo wrote: Sun May 20, 2018 8:08 pm Heated MFSW, is a good project. :wink:
Thanks for coding! Safe-Lock is working now :) 👍
I understand that this fault is not significant, but still it is appears.. and i don't happy because of it! :D
Could be because of warning light, but if so, I haven't seen this fault in your autoscan's, Fernando! :lol:
Does anyone with retrofitted direct TPMS have seen this fault :?:
Posted: Mon May 21, 2018 4:48 pm
by ciclo
Everyone who installed it. :wink:
I don't happy too with this sporadic fault.
Posted: Mon May 21, 2018 6:01 pm
by MaDwArLoCk
Okaaay, that explains everything! :lol:
I thought, i am the only one with that damn fault :roll:
Then probably we have to retrofit PQ35 dashboard to fix this fault :!: :lol:
Posted: Mon May 21, 2018 6:06 pm
by ciclo
MaDwArLoCk wrote: Mon May 21, 2018 6:01 pm
And you're still the only one who has that fault. :lol:
Therefore, if the warning light for TP is ON in IC the warning comes from the indirect TPMS.
Posted: Mon May 21, 2018 6:21 pm
by MaDwArLoCk
ciclo wrote: Mon May 21, 2018 6:06 pm
Please, Fernando tell me more! :D
I need to disable warning light for TP?
Or maybe reassign TP warning light in the EEPROM? :roll:
