Skoda Fabia VRS 2012. Auto lights retrofit OEM
Forum to discuss the Skoda Fabia
Re: Auto lights retrofit
Try with:
7A980B3848010000013806B03EEB9BC052C0621F60022041200400000000
VASILEIOS1972
Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Post by VASILEIOS1972 »
with this coding I don't have errors either interior dimming
with yesterday coding that you send me ready the dimming switch has little light and dimming himself
I don't understand exactly what you mean.
Is everything working correctly with this last coding?
VASILEIOS1972
No Fernando I do not have interior dimming :oops: and don't have faults :D
Last chance to try that Dimmer to work.
Try:
7A980B3848010000013806B03EEB9BC052C0621F60002041200400000000
VASILEIOS1972
with this last coding I have the previous errors :oops:
and no interior diming :oops:
any idea
With what BCM coding of the previous ones do the interior lights work and there are no faults despite not having the dimming function?
VASILEIOS1972
VASILEIOS1972 wrote: Sat Aug 31, 2019 8:28 am 7A980B3848010000013806B03EEB9BC052C0621F60022041200400000000
Are you telling me that the interior lights (IC, HU, A / C, switches) are working correctly with this BCM coding?
VASILEIOS1972
you have right I do not have interior light in light switch , dimmer switch , power windows switches , central locking switches , esp, tpms , heated tear window ,pdc switch :shock:
Sorry to tell you that the Dimmer 1Z0 941 333 (the dimming function) will not work for your SK Fabia.
We have tried everything possible (wires and coding), but we have been defeated.
Now...
- BCM coding: 7A980B3848010000013806B03EEB9BC052C0621F60022041200400000000
- Remove the blue/black and black wires by removing T8/5 and T8/6 terminals from the Dimmer connector.
- Splice blue/black wire with black wire.
In this way the interior lights (IC, HU, A/C, switches) will work without dimming function.
VASILEIOS1972
wait Fernando I am now in a very dark place and I saw that
with first coding this with faults I have dimming function in very low light volume in
light switch
dimming switch
esp, pdc heated rear window
power window
tpms
and a/c , rns 315
but no dash
VASILEIOS1972
ciclo wrote: Sat Aug 31, 2019 8:56 am Sorry to tell you that the Dimmer 1Z0 941 333 (the dimming function) will not work for your SK Fabia.
Now...
Fernando I did what you told me but no light in all the switches I told earlier
tell me when splice blue black and black wire I isolated them and nothing else
am I correct ?
Yes, use a Butt terminal to splice the wires, this way they will be isolated.
VASILEIOS1972
bcm coding
7A980B3848010000013806B03EEB9BC052C0621F60002041200400020000
and blue-black + black wires connected give the result that you told me previous
for the history this is the first coding that you provide me with BCM
is there any difference if we tried with oem polo 6r dimming switch ?
