Giannis20vt's Polo 6c 1.0MPI
Re: Giannis20vt's Polo 6c 1.0MPI
Yes in your case battery adaptation is done in the gateway
giannis20vt
Found it at Gateway as you said.
giannis20vt
Nice, well done. Looks very clean.
giannis20vt
This is a new scan with a VCDS cable.
Suddenly there is a CP for the Airbag module, i have to go to a garage with online connection to remove it, i don't know why this error came up.
Nor about the error with the communication with the HVAC module, I don't know what happened.
VCDS Version: 22.10.0.1 HEX-V2 CB: 0.4622.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WVWZZZ6RZGY------ License Plate:
Mileage: 65219km-40525mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY308378 Mileage: 65219km-40525miles
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 AB HW: 04E 907 309 CB
Component: R3 1.0l MPI H20 2496
Revision: 33H20000 CVN: DA6EEF6D
Coding: 01110012020400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
ROD: EV_ECM10MPI01104C906057AA_VW26.rod
VCID: 6597B189C5E238F3784-8030
VINID: 9E69EAAAA1A2A97A430080C720BAB66964
Readiness: 0000 0000
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08512057160424
Coding: 21DD2485492333C8091700700059842492CC90000005C9098F00
Shop #: WSC 49716 005 1048576
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 372B2BC12FCE7A631A8-8062
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 C HW: 6C0 820 045 C
Component: AC Manuell H03 0202
Serial number: 1605161B-0418
Coding: 200000000000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1F1BE361A73E2223F28-804A
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-090-V1.clb
Part No SW: 6C0 937 090 E HW: 6C0 937 090
Component: BCM PQ26 HiKR H10 0101
Serial number: 006738042497
Coding: 000008404053005B4F844000400703000000580051010000000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_BCMA0 006004
ROD: EV_BCMA0_006_VW26.rod
VCID: 2A0D02B5EC7CD78B956-807E
Driver door control module:
Subsystem 1 - Part No SW: 6R0 959 801 DG HW: 6R0 959 801 DG Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU012051661335260
Coding: 0000A0
Front passenger door control module:
Subsystem 2 - Part No SW: 6R0 959 802 DL HW: 6R0 959 802 DL Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU030041661212448
Coding: 1000A0
Rear Driver Side Door Control Module:
Subsystem 3 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU028041661198823
Coding: 0000A0
Rear Passenger Door Control Module:
Subsystem 4 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU002051661233279
Coding: 1000A0
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00A 002 0380
Revision: -------- Serial number: 003TH006KLNX
Coding: 88C0C000000000005C000000000800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A2D32F51CDC670BE56-806E
Subsystem 1 - Part No SW: ----------- HW: 410 820 305 16
Component: SideSensor_Df 151 0800
Serial number: 3575H00A520BDDD2520R
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 410 821 104 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A5209A1C310AF
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 442 152 204 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00AF1FACC94822/
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 442 152 204 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C12060D61520W
Coding: 2D2D2D
1 Fault Found:
15360256 - Component Protection
U1101 00 [137] - Active
[ATP Error Counter]
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 65177 km
Date: 2023.01.21
Time: 10:04:10
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 6C0 920 740 C HW: 6C0 920 740 C
Component: KOMBI 201 1420
Coding: 070409002100000811082A000000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 221DEA95944C0FCBDD6-8076
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 090
Component: GW MQB A0 H10 0101
Revision: -------- Serial number: 006738042497
Coding: 01010008200A640071000000000000000001010000000000000000000000
GVL: 01403C0000000000400000000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 2615F685F864F3EBB1E-8072
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT X03 X014
Serial number: 13/11/2013 PV000031
Coding: 2C0000
1 Fault Found:
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [008] - -
[Timeout Knoten 0x46 / 08 - Steuergerδt fόr Klima]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 65198 km
Date: 2023.01.24
Time: 10:38:58
Terminal 30 power supply: 12.2 V
Terminal 15: OFF
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: PG5Q1139
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6D87C9A91D1200B3304-8038
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 6C0 035 888 B HW: 6C0 035 888 B
Component: MU-E--ER 851 6490
Serial number: 19041600012060
Coding: 026200003C00000041110001010000001F0000840000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 2B0307B1E386CE836E0-807E
End----------(Elapsed Time: 00:36, VBatt start/end: 12.4V/12.4V)-----------Suddenly there is a CP for the Airbag module, i have to go to a garage with online connection to remove it, i don't know why this error came up.
Does it return after you clear it? Probably a left-over of your BCM swap?
giannis20vt
Yes is does. The CP is something i can't remove myself.iichel wrote: Thu Jan 26, 2023 5:22 pm Does it return after you clear it? Probably a left-over of your BCM swap?
It appeared some days after the swap.
giannis20vt
All right, i removed the CP error with an online connection.giannis20vt wrote: Thu Jan 26, 2023 5:23 pmYes is does. The CP is something i can't remove myself.iichel wrote: Thu Jan 26, 2023 5:22 pm Does it return after you clear it? Probably a left-over of your BCM swap?
Every time i scan for errors i find the some error
Address 09: Cent. Elect. Labels: 6C0-937-090-V1.clb
Control Module Part Number: 6C0 937 090 E HW: 6C0 937 090
Component and/or Version: BCM PQ26 HiKR H10 0101
Software Coding: 000008404053005B4F844000400703000000580051010000000000000000
Work Shop Code: WSC 12345 123 12345
ASAM Dataset: EV_BCMA0 006004 (VW26)
1 Fault Found:
206604 - Locking Unit for Central Locking; Passenger Side
B1680 29 [009] - Signal Implausible
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Mileage: 65639 km
Date: 2023.03.08
Time: 18:59:50
Terminal 15 status: OFF
Terminal 50 status: OFF
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
Stoerschutzzaehler: 19
Voltage: 12.5 V
Outside temperature: 14.5 °CThere is no problem with the operation of the passenger door, except for the error code. It is possible that this error first appeared after installing my front door light. I am not sure.
It is easy to check by disconnecting the led light
giannis20vt
Sure it is an easy try. I'll do it
giannis20vt
Hood strut. Done
I made the metal parts and i painted them at the same color of the car. Them i mound them.
One strut with length 48cm and 300Nm. Very good result, smooth opening.
https://youtu.be/FPFMB13mT6Q
- ag69
- Drives: 1.2TSi 77Kw 7DSG
giannis20vt --looks good.
What is ratings for these?
mine opens like a rocket
giannis20vt
Hi, 300Nm is the force for this gas strut. I have installed just one. A tip is that you have to put it upside down. The part with the thick diameter goes into the hood, the other with the thin diameter, goes into the fixed point.ag69 wrote: Tue Apr 11, 2023 6:24 am giannis20vt --looks good.
mine opens like a rocket![]()
Bravo! Looks good!
Hallo iichel
Wohne auch in der Schweiz (Aargau) wo bist du zuhause?
