prtvrk
Posts: 24 Joined: Wed Jun 01, 2022 8:52 pm
Drives: 6C
Post
by prtvrk » Thu Dec 01, 2022 6:57 am
iichel wrote: Thu Nov 24, 2022 8:33 pm
Yep I had the same regarding pq35. On the T6 forum i read some positive outcomes for retrofits to pq platform.
I've successfully fitted 2q0 bsd on my pq46, it was all trial and error trying different datasets from vcp. I did do manual lc before for the radars to think they were in pq car.
My connectors are faced inwards, some datasets have them facing outside, mine calibrated within 60km and everything is working now.
Posts: 6689 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Thu Dec 01, 2022 7:35 am
Cool, thanks. What dataset and coding are you using?
Shadow109
Posts: 154 Joined: Sun Aug 16, 2020 2:59 pm
Drives: Vw t5.1 2013
Post
by Shadow109 » Thu Dec 01, 2022 10:31 am
Can you tell me from what car your radar came ?
“SW” number will help too
I think our radars just simply doesn’t have have data for pq cars
prtvrk
Drives: 6C
Post
by prtvrk » Thu Dec 01, 2022 1:10 pm
I want to say I ended up using vw36 dataset from vcp. There was one big pack there and I tried a few of them, first that enabled assistants in cluster I went with, it was late in the day and documentation was not a priority.
Don't forget the voltage changers and resistors for the side mirror leds.
Coding: 52 94 A4 20
One adaptation that made some difference, 'no ecu for draw bar', rest are self explanatory.
My radars came from Audi Q1 if i were to believe the seller.
2q0907686b, did not need to flash them to VW, only dataset.
Index C has CP-enabled.
Post
by iichel » Thu Dec 01, 2022 1:14 pm
thank you - highly appreciated. yes I've seen that the PQ radars use a 12V LED while the MQB radars are 5V. 100 ohms of resistor should be OK.
Shadow109
Post
by Shadow109 » Thu Dec 01, 2022 1:39 pm
Thanks for the info
benmet
Posts: 7 Joined: Wed Dec 14, 2022 10:04 am
Drives: Polo 6R 105PS TDI
Post
by benmet » Wed Dec 14, 2022 2:14 pm
Hi iichels,
sorry for my bad english
I saw that you installed the amrok speedometer in your polo. I also did the construction and took over the EEPROM data. Now the error in the brake control unit is displayed to me Wrong wheel speed from the Kombiinstrument(Tacho) cluster. I also get the message Check brake fluid log with a red exclamation mark symbol. Do you have to reconnect something on the cable? Do you have an idea what I might have forgotten or a tip for me? You can also send me a PM message.
Best regards
Benjamin
Post
by iichel » Wed Dec 14, 2022 8:39 pm
could you share your eeprom please?
Post
by iichel » Wed Dec 14, 2022 8:42 pm
In other news, the Polo (finally) has its MQB brother, A VW Passat B8 2.0 TSI DSG 4-motion from 2017:
https://imgur.com/a/Kxgf148
Wednesday,14,December,2022,19:00:45:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: WVWZZZ3CZJEiichel License Plate:
Mileage: 131667km-81814mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44
47 4B 52 5F 65 69 6C 6D A5 BB BC CA CF D6 D7
VIN: WVWZZZ3CZJEiichel Mileage: 131667km-81814miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CJXA) Labels:. 06K-907-425-V1.clb
Part No SW: 3G0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: 73B77959
Coding: 091D003A2476050B3004
Shop #: WSC 05311 115 00319
ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
ROD: EV_ECM20TFS0203G0906259B.rod
VCID: 2B03FAEDB387D593621-807E
VINID: 9E69EAAAA0D3A9A54008518520274044B7
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 018 C HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01706160335 CVN: 0000580D
Coding: 0014
Shop #: WSC 05311 115 00065
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1C612931E629222B1BB-8048
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 61907000000236
Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
VCID: 79AF10A5095BB703A0D-802C
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0448732144
Coding: 1F20000723
ASAM Dataset: EV_KessyHellaMQBAB 004041
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E25C3B950F5503BD5F-806A
Rear lid opener control module:
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 DQ HW: 5G0 907 044 DQ
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 1202002420411101111550000010192A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Humidity sensor: exterior:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 865829061700DO
ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 06556B5948A5C8FBDDF-8052
Wiper motor control module:
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170615 042 0607
Serial number: 170629234856
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y17M06D29H19M25S21
Coding: 00A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 14 04 2017 10001690
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1714382PB
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000070188699
Humidity sensor: interior:
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617172
Coding: 0271167951
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50F98D01FA61D64B373-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H04 0195
Coding: 320467DB59FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3537DC9565C39363045-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0121
Serial number: 25061741350001
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_001_VW48.rod
VCID: 3829D5A172D16E0B1F3-806C
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 BK HW: 3Q0 959 655 BK
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W6PCG5P2/
Coding: 98FCC0C0008000005C5400CF000800000065
Shop #: WSC 05314 000 00001
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 0849656142B1DE8BAF3-805C
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705 0031T01500
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G1857706G0185R01460
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 606 17
Component: SideSensor_Df 008 0887
Serial number: 357000000000507D3628
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 454 001 806 17
Component: SideSensor_Pf 008 0887
Serial number: 358000000008D140C62J
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 454 801 106 17
Component: SideSensor_Dr 301 0148
Serial number: 3510091305210000000U
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 454 801 106 17
Component: SideSensor_Pr 301 0148
Serial number: 352002F2F52100000009
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 454 801 406 17
Component: FrontSensor_D 304 0149
Serial number: 3550040279610000000%
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20170627200018
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 73B3228D2B37CD53EA1-8026
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 3G0 920 791 C HW: 3G0 920 791 C
Component: KOMBI 406 3193
Coding: 07A40898FE8C000801886B0F1001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 290F00E5B97BC78390D-807C
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 H HW: 5Q0 963 272 H
Component: STH-MQB 008 0075
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 3B23CAAD43E74513F21-806E
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000276932
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 06071710802132
Coding: 0B0300347F015900FB00025E9C0F00010001070000000000000000000000
GVL: 01DE3C0008000600C0DC80000006CC0010040000000200000000000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 3333E28D6BB78D532A1-8066
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170001407150107262
Coding: 2DFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Component: J367-BDMHella H10 9070
Serial number: 5131394104
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: U13DCAC H26 0780
Serial number: 0066181
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 3003201700010095
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Component: Haldex4Motion H52 7083
Serial number: HA1-00017.05.17
Coding: 0301
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4ACD9F691C3DEC9B797-801E
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000160250002
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71BF2885512BFF4318D-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H05 0022
Serial number: Y0006QFD15173
Coding: 001000020000050081C280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide.rod
VCID: 3A2DCFA94CDD7C1BE97-806E
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H20 0510
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
ROD: EV_RearRadarS1BoschVW48X_VW37.rod
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 190417EDJ1110A
Coding: 003F1A20D200028000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43D3B24D3B173DD3BA1-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9307
Shop #: WSC 00015 115 00319
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 465 HW: 3Q0 035 465
Component: MIB2_amp_P_VW H60 0440
Revision: 00000001 Serial number: VWZ8Z1HJD00RUVL
Coding: 1284020001AA0A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
VCID: 6B833AED73071593221-803E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 01071710801233
Coding: 000000060100035207004F01020000000000000000000000000000000000
Shop #: WSC 05311 000 00001
ASAM Dataset: EV_MultiModulContiVW48X 001010
ROD: EV_MultiModulContiVW48X_001.rod
VCID: 72BD2789542DC45BE17-8026
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo links H02 0003
Coding: E02400
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo rechts H02 0003
Coding: E02400
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 170617EFH29274
Coding: 003F1020DE00028200001000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42DDB749240D34DBB17-8016
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 042 A HW: 5NA 035 042
Component: MU-H-LN-EU H54 1121
Serial number: A847G0HB006263
Coding: 02840201000000005111000200080A101F0106E4012004009F
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT1915518
Data carrier:
Subsystem 2 - Part No SW: V03 959 809 PA HW: -----------
Component: ECE 2022 --- 0195
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000081630
ASAM Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3431E1916EB98A6B33B-8060
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0446947174
Coding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0184020163002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
VCID: 392FD0A549DB7703E0D-806C
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 31433445900000
Coding: 0288
ASAM Dataset: EV_DeckLidCONTIAU736 001014
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 41DFB845210B2FC3A8D-8014
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 14061711P11354
Coding: 000408020000040100222347C150A90094000E300040
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_001_VW36.rod
VCID: 3C21C9B146E9422BFBB-8068
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 070617EF614855
Coding: 000E10200100028000001000
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 45D7AC55352303E3945-8010
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 070617EF613546
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 208040748202
ASAM Dataset: EV_SunRoofCONTIAU736 006008
ROD: EV_SunRoofCONTIAU736_006.rod
VCID: 3D27C4B55DF34B23CC5-8068
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 E HW: 3Q0 907 590
Revision: --------
Coding: 14C002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
ROD: EV_RearRadarS2BoschVW48X_VW37.rod
VCID: 372BD69D7FCF6173169-8062
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 16753B191805787B2DF-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 02:50, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Posts: 1304 Joined: Thu Feb 06, 2020 7:57 am
Post
by amer6R » Thu Dec 15, 2022 4:40 pm
Is this the donor for the polo
mirceaculita
Posts: 271 Joined: Fri Aug 21, 2020 11:25 am
Drives: 6R 1.2TDI 75hp
Post
by mirceaculita » Thu Dec 15, 2022 5:22 pm
Imagine a 4-motion polo 6r
Post
by iichel » Thu Dec 15, 2022 7:05 pm
I think its easier just to put a polo logo on the Passat lol
Lucero79
Posts: 22 Joined: Mon Sep 23, 2019 8:26 am
Drives: Polo
Post
by Lucero79 » Fri Dec 16, 2022 10:04 am
Hi iichel. Just returning here quickly to ask. Do you think it's possible to fit the DSG gearbox to a CAYC Ibiza?
I'm still pulling parts together to bring it inline with the MQB platform, such as Dash, wiring, etc
Post
by iichel » Fri Dec 16, 2022 11:33 am
Yes I think so
til3tsio
Posts: 90 Joined: Thu Feb 11, 2021 10:53 pm
Drives: Seat Toledo KG
Post
by til3tsio » Sat Dec 17, 2022 2:59 pm
I am searching for info on how to activate gra high and acc on my cayc pcr2.1 ecu.
I saw in one of the above posts that you managed to activate gra high.
was it already active on the new beetle ecu or you did some king of software mod ?
