Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Thanks for joining in. I'm not particularly interested in a MK60EC1 swap since I'm pretty happy right now with the ESP9.0i.
If I cannot make the 2Q0 radars work, I'll be happy to keep my 7E0 radars :)
I'll give it some tries and otherwise I'll try to get the guys at the T6 forum to help out. Sometimes they're a bit secretive and vague, but usually they are super friendly and helpful.
Fingers crossed!
MrCollayder
Drives: Polo 614 sedan (cave+dq200)
Post by MrCollayder »
Sure =) Fingers crossed!
If i find something else about 2q0 radars, I'll tell about it.
P.S. found, that DCC mode can be changed in adaptation channel 20 of the gateway.
0 = w/o DCC
1 = comfort mode
2 = usual mode
3 = sport mode.
prtvrk
Drives: 6C
Post by prtvrk »
MrCollayder, what's your coding and admap?
Is your esp error 33? Mine was caused by near empty battery and i disabled rta with braking.
It's also important to know what dataset is used, there are several for PQ cars. I read on the T6 forum that the MB12_VW32 was working for them (PQ, no EPB).
MrCollayder
prtvrk wrote: Sun Jan 01, 2023 10:17 pm MrCollayder, what's your coding and admap?
In 3 days I'll be near the car, so can send all the info. Also I'll try to play with the coding one more time.
Trying only the passat_usa dataset. It's still PQ-based and w/o EPB.
MrCollayder
iichel wrote: Sun Jan 01, 2023 10:20 pm It's also important to know what dataset is used, there are several for PQ cars. I read on the T6 forum that the MB12_VW32 was working for them (PQ, no EPB).
I saw the message from you, but can't reply. (Don't see any 'reply' button) If you share your e-mail or telegram, I'll send you info
Lucero79
Drives: Polo
Post by Lucero79 »
Lucero79 wrote: Sun Dec 18, 2022 9:51 pm
iichel wrote: Sun Dec 18, 2022 8:14 am You will also need a tool to read and transfer your immo data. It's not as simple as moving the eeprom.
Thanks, got any suggestions?
As to the list of mods at the start of this thread, I had some questions:
1. Was any of this completed pre MQB and if so, did you redo it as OEM once upgraded to MQB? I guess you've changed wiring looms along the way?
2. Re the engine, have you seen any noticeable improvement by upgrading to the 2litre air meter, filter, pipes, etc?
Hi iichel. Happy New Year. Would VAG EEPROM allow me to read my 2012 cluster so I can swap it over to one that has all the working lights?
I don't know to be honest, I think it will be more complicated than that. Immo data is usually encrypted and not easily read with just an eeprom reader.
Lucero79 wrote: Tue Jan 03, 2023 10:33 am
@ciclo saw on one of your post you had access to Abrites clone, can it swap the cluster?
Maybe this can help you in your question?
Lucero79
Drives: Polo
Post by Lucero79 »
iichel wrote: Tue Jan 03, 2023 11:05 am I don't know to be honest, I think it will be more complicated than that. Immo data is usually encrypted and not easily read with just an eeprom reader.
Oh, sorry. I thought you had swapped your cluster over in the Polo. Did you not face similar issues?
No but I went to somebody to do it for me. To avoid messing around haha
benmet
Drives: Polo 6R 105PS TDI
Post by benmet »
Hi iichels,
I wanted to gently ask if you've gotten around to looking at my EEPROM? :)
Best regards
benmet wrote: Thu Dec 22, 2022 10:29 am
iichel wrote: Thu Dec 22, 2022 8:14 am
benmet wrote: Wed Dec 21, 2022 9:46 pm
Hi iichels,
Here is the EEPROM file from my speedometer. Thank you for looking.
https://drive.google.com/file/xx
Thanks. I will reply by private message with your new eeprom to try.
Thank you very much. :) I am already despairing.
No, not yet. I'll use VDO editor but there is some server maintenance for the new licensing system so I have not been able to use the application the past weeks
https://forum.skodapilot.com/viewtopic.php?t=365
MrCollayder
So, I've finally done some tests with 2q0 BSD radars =)
Now I have only 2 errors in 3C: no warning lamps))
Parking exit assistant is now active, but BSD isn't yet because of these errors.
Long coding is 52 95 24 A0.
This coding is for PQ.
• BSD/SWA is ON
• WITHOUT ecu for draw bar
• left-hand drive
• BSD/SWA warning lamps via PWM
• WITHOUT pre-crash_rear
• RTCA is ON
• parksystem installed
• NO break intervetion
• WITHOUT lane assist
Next week I'll try to connect both lamps and activate RTA.
Hi iichels,
Hi, I had a look at your EEPROM but I'm afraid I'm not able to find anything wrong with it. I compared all the reference values that VDO offer with a stock 6R0 eeprom, and it seems well adjusted.
