H & R coilovers
Posted: Mon Feb 28, 2005 11:45 am
whats peoples opinion on H & R coilovers are they worth the money???
Probably the Worlds greatest Polo resource
https://uk-polos.net/
So gas-filled then? IMO definitely worth the outlay if you have the funds to go for themPCS Coil-Overs
Coil over suspension is the ultimate expression of high-performance handling, and now H&R Special Springs takes this technology to the next level with its new PCS Coil Overs. Like H&R's original Coil-Overs, PCS Coil-Overs are engineered for street use, but have a number of new features designed for the enthusiast who desires a manual shock dampening feature.
In addition to state-of-the-art inverted damper technology and adjustable ride height, PCS Coil Overs feature an external adjustment knob that allows the user to simultaneously adjust rebound and compression. Nose-diving under hard breaking is virtually eliminated, which effectively reduces braking distance. And unlike traditional twin-tube shock absorbers, H&R's mono-tube gas shock absorbers eliminate foaming of the damper oil, even under extreme conditions.
