Fuel Tank Capacity.
Posted: Mon Mar 14, 2005 1:53 pm
by DanW
Anyone got any idea what it is in the MK3? I can't get hold of my hanyes manual (I'm at uni and the books at home).
Thanks,
Dan
Posted: Mon Mar 14, 2005 2:05 pm
by polock
The only info i can find online at the moment suggest a 42 litre (9 gallon) capacity.
Hope this sounds about right and of some help.
Brian
Posted: Mon Mar 14, 2005 3:17 pm
by DelG40
Yeah, I also believe it's 42 litres.
Posted: Mon Mar 14, 2005 3:32 pm
by LogIK
Sure is.
by Steve_O
Yep indeedy - the magical 42!!
Posted: Mon Mar 14, 2005 4:22 pm
by ZippY
Yup, 'tis all true.
Don't put any more in or it goes all over your feet and the manager of the filling station asks some serious questions
That's how I found out the capacity of the tank before getting my Haynes
Posted: Mon Mar 14, 2005 5:22 pm
by Krupa
I thought it was 43litres, or 9.3 gallons, those are the figures I have in my head.
Not that it makes much difference...
Posted: Mon Mar 14, 2005 5:28 pm
by DanW
as you might have guessed I'm trying to estimate my MPG, someone of either here or porka wrote it and I can't remember who (was it DelGT?).
clicky
Posted: Mon Mar 14, 2005 6:37 pm
by GroovyCarrot
Why not just record the mileage between two top to top fills and how much you put in at the end of that mileage.. that way you don't need to drain the dregs out of the bottom of your tank, and you'll get a reasonably accurate measurement of volume of fuel if you just go top to top and read off the pump..
Posted: Mon Mar 14, 2005 7:06 pm
by DanW
GroovyCarrot wrote:Why not just record the mileage between two top to top fills and how much you put in at the end of that mileage.. that way you don't need to drain the dregs out of the bottom of your tank, and you'll get a reasonably accurate measurement of volume of fuel if you just go top to top and read off the pump..
last time I filled up it was nearly a full tank soooo. If I run it to the same stage or there abouts again. That'll give me a fair estimate.
Hopefully I'll get more than 320miles out of this tank
Otherwise that's less than 34mpg, on a fairly open route/high speed route, not just stuck in traffic.
Posted: Mon Mar 14, 2005 11:58 pm
by Tahrey1043
its officially 42 litres, but unless the petrol stations are fiddling the figures you can squeeze a litre or two more in there - if it's been run bone dry.
best to just fill it to the first click-off and measure how much you put in on each fill and how far you went. the cut off will vary slightly between stations, but not enough to cause significant error out of say 30 litres. (probably enough to cause big error if you only go far enough to use the minimum 2 litres though!)
Posted: Wed Mar 23, 2005 9:36 pm
by Fionadilston
think I am getting in the region of 350 miles out of a tank ...country and town driving not motorway where it may but I would never rely on it being a little more than that ...my polo is an early mk 111 h reg facelift model with nearly 72,000 miles on the clock
Posted: Wed Mar 23, 2005 9:44 pm
by dub envy
In the 5 years that I have owned my GT I've never actually worked my mpg out. I always fill it up too..
Posted: Wed Mar 23, 2005 9:58 pm
by metz
I get atleast 100 miles to a tenner..if i take it steady and don't try to race every car that passes me i get more.
