UK-POLOS.NET - THE VW Polo Forum • tyre sizes on 14's
Page 1 of 2
tyre sizes on 14's
Posted: Wed Mar 23, 2005 10:50 am
by lord_sharpy
ive just put some 14" bbs wheels on my gt, et38 it says on the rim and they have 185/60 14 tires on, they scrub really bad on the front on the inside of the arch, they are 6.5j x 14h2.
any help would be great or im off to get my 15's back :(
cheers
james
ps is there any other numbers on them to determine sizes etc?
Posted: Wed Mar 23, 2005 11:50 am
by LogIK
IIRC, The correct size should be 185/55.
Posted: Wed Mar 23, 2005 12:46 pm
by metz
I have 185/50/14's They read approx 2mph under the speedo so no worries about speeding by accident.
Posted: Wed Mar 23, 2005 2:29 pm
by lord_sharpy
will 185/50 cure it then? caus tis scrubbing on the back of the arch when you brake hard and top of the arch on bigger bumps.
Posted: Wed Mar 23, 2005 3:48 pm
by hayesey
how much is it lowered by? 185/60 is a bit too big but it shouldnt really be causing you problems.
Posted: Wed Mar 23, 2005 4:25 pm
by lord_sharpy
its lowered by 40, i thought they would go straight on being 38 offset and seeing as i was running 195/45 15's before i didnt think i would have any problems, its more the drivers arch catching than passenger.
Posted: Wed Mar 23, 2005 6:28 pm
by Nick101
how much would 195/45 effect speed?
Posted: Wed Mar 23, 2005 6:44 pm
by Petrified
I had to make this desicion a few months ago.
On a 14x6 wheel I went for 195/45/14's they look the part (lower profile) and were cheaper than 185/50/14's.
The wheels originally had 175/60/14 and were scrubbing quite bad on the GT with standard suspension. The G40 is lowered at least 40mm if not 60mm (not sure) and there is no problems whatsoever on 195/45/14
The only thing I noticed is that it sits slightly higher on the 195/45/14 than it did on the standard G40 13" alloys (175/60/13) not that you would really notice though, strange as I thought it would have been lower still...
James.
Posted: Wed Mar 23, 2005 6:47 pm
by metz
If the original tyres were 165/65/13 then your 195/45/14 tyres will put your speedo out by about 2mph..ie:- speedo says 60mph but your really doing 58..so your safe :-D
Posted: Wed Mar 23, 2005 7:03 pm
by hardhitter
185 50 14 is the correct tyre size. Use the tyre size calculator on the polo gt website is your not sure.
Posted: Wed Mar 23, 2005 9:00 pm
by lord_sharpy
yeh, i found the tyre size calculator just after i posted on here, il probably go for 185/50 i think.
cheers guys
Posted: Wed Mar 23, 2005 9:33 pm
by heartagram
lord_sharpy wrote:its lowered by 40, i thought they would go straight on being 38 offset and seeing as i was running 195/45 15's before i didnt think i would have any problems, its more the drivers arch catching than passenger.
Cause your sitting on the drivers side so its proabably lowering the car abit so it snatches more.
Posted: Wed Mar 23, 2005 9:56 pm
by metz
I have continental contisport 185 / 50 /14's theyve done over 10000 miles now and are showing little wear..and the grip is fantastic...even in the wet stuff.
Posted: Wed Mar 23, 2005 10:56 pm
by lord_sharpy
yeh the car has sagged over time, does anyone know where i can get some cheap 185/50 14's ive tried mytyres but there quite alot or does anyone have a part worn set?
cheers
james
Posted: Thu Mar 24, 2005 12:05 pm
by tainmrk3polo
dont scrimp on tyres, i did and ended up in a hedge :( :cry:
