brake upgrades
Posted: Tue Apr 05, 2005 10:48 am
by M7
anyone know what uprated brakes you can get for the 9n?
i was thinkin about puttin TT discs and callipers on. i think they do 330mm discs or 250mm drilled and vented ones.
anyone know if these fit on? or what other brakes you can get that do fit the 9n.
cheers
Posted: Thu Apr 07, 2005 10:34 pm
by M7
someone must know!!
Posted: Thu Apr 07, 2005 10:37 pm
by dxg
Well, the S3 setup apparently fits the Fabia vRS, so presumably it would fit the 9N also. Ask Toxxin or Josh, they both have this mod.
Deek.
Posted: Thu Apr 07, 2005 11:13 pm
by Josh_PoloGTi
The TT/S3 setup only fits the vRS Fabia as all the rest use the type of brakes that are attached to the hub assy.
The vRS uses "normal" type brakes that have carriers and calipers that seperate from the hub, and therefore can be changed.
Posted: Thu Apr 07, 2005 11:43 pm
by M7
can you recomend any that i can use?
evetually planning on a engine transpant, but sorting brakes first, then suspension...then comes box and lump when i save up a hell of alot
Posted: Fri Apr 08, 2005 2:45 pm
by vwclub.gr
Ibiza Cupra's brakes must fit also. Check it out.
Posted: Fri Apr 08, 2005 5:53 pm
by SiDaBa
Josh_PoloGTi wrote:The TT/S3 setup only fits the vRS Fabia as all the rest use the type of brakes that are attached to the hub assy.
So does the normal rule apply to the polo GT as well? Or am i lucky it falls under the vRS? :roll:
