Help needed in using a chamois (yes, really!!!)
blades
I got one of these silicon blades a few weeks before I swapped my GTi for a TDi. They do an excellent job of getting rid of water, but I noticed a few scratches too - nothing a bit of Mer couldn't get rid of, but worrying nevertheless. I can only assume that my washing wasn't up to much and a few bits of grit got through the net and ended up being dragged across bits of bodywork Of course, my GTi was metallic black and showed every mark depressingly clearly!Speedlaw wrote:I've used the Autoglym aquablade as well, it actually does the job. Saves some serious time too, but it has one drawback-
No matter what anyone says- it does leave tiny scratches on my paint.
Use with caution I think.
Well, I followed everyone's advice on here and chamiosed my first car ever last night.
I used a real leather chamios which I'd left soaking in warm water for a couple of hours beforehand.
Everything went perfectly!! I can't believe how straight-forward it was. I think my mistakes before were not having a damp enough chamios and using too much pressure.
However, I'm now stuck with a new problem.
Sap and dead flys.
My zymol starter pack arrived this morning, but I can't use it until I've tracked down some Imperial Hand glaze from somewhere to fix the multiple sratches I've got.
In the meantime, is there somthing you guys would recommend to remove sap, dull spots left by removed flys, and actual, encrusted and won't shift for anything fly carcasses??
I'm guessing the zymol hd cleanse stuff will do that, but I can't use that until I've glazed it. I think??
My plan is:
1.
Sort out flys and sap (I guess whatever's used for this will also strip any polish in that area)
2.
Hand glaze to fix scratches and "polish" (sorta)
3. Full Zymol treatment (but won't the HD cleanese stuff just stip the glaze? It sounds as if it does pretty much everything a clay bar would.)
In that case, would a better appraoch be:
1. HD Cleanese
2. Glaze (would doing this at this stage screw the paint up??)
3. Wax.
Thoughts very much welcomed!!! (You've been so helpfull before and think of all the people reading those who are too embrassed to admit their shortcomings!!)
What's your routine / exepriences??
Deek.
Sap and dead flys.
My plan is:
1.
2.
1. HD Cleanese
3. Wax.
Deek.
Wash the car down then hd clense the car, DO NOT use a circular motion, keep the towel dry and wipe down the bodywork in straight lines, keeps possible scratches to a minimum, then polish the car.
For hd clense, removal, polish and removal you're looking at 4 towels, the Zymol one's are excellent, after use wash them in washing machine but do not use fabric softener.
You may not even need to use the glaze, see what you think!
I've been using Zymol for two years now and would not recommend anything else, let me know if you need any tips.
Des
Des
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
Right, I'll tell you my FULL routine (which I'm going to do tomorrow!)
* WAKE UP AND APPLY OLD CLOTHING, EAT SOME WHEATABIX
EXTERIOR:
* Wash with Zymol Clear and a decent sponge
* Clean the alloys with sponge and soap first, then Comma Acid and a horsehair brush
* Blade then Dry the car using a chamois
* DRINK SOME WATER
* If there are any REALLY stubborn tar/sap/fly spots, use Autoglym Intesive Tar Remover to remove them
* Clay with 3M Clay and soapy water spray (lube)
* DRINK SOME WATER
* Treat any major scratches to some 3M Perfect It III Rubbing Compound
* Go over the whole car (in sections - 1 at a time) with either 3M Imperial Hand Glaze or HD Clense then buff off
* DRINK SOME WATER
* Go over the whole car (in sections - 1 at a time) with Zymol Titanium then buff off.
* DRINK SOME WATER
* Clean the windows (external) with Autoglym Window Polish
* Apply Rain Wizard to all the external glass.
* 4 hours after applying the wax and buffing off, buff again after very lightly misting with clean water
* DRINK SOME WATER, HAVE SOME LUNCH AND GO FOR A SIT DOWN!
INTERIOR:
* Dyson the interior
* Use Autoglym Hi-Foam Interior Shampoo on the seats and any spots on the celing
* DRINK SOME WATER
* Use Zymol Vinyl on the dash, door cards, etc etc...
Use a very slightly damp kitchen towel (bounty) on the windows inside then finish with a soft terry towel.
* Spray some Autoglym Interior Freshener Stuff on the seats and carpet (not too much)
* Use Turtle Wax Extreme Tyre Gell on the tyres
* DRINK SOME WATER THEN GO TO BED!
Easy huh? Should "only" take about 6-8 hours!
EXTERIOR:
* DRINK SOME WATER
* DRINK SOME WATER
* DRINK SOME WATER
* DRINK SOME WATER
INTERIOR:
* DRINK SOME WATER
- Moderator
lolJosh_PoloGTi wrote:* WAKE UP AND APPLY OLD CLOTHING, EAT SOME WHEATABIX
Yup, that stuff works wonders!Josh_PoloGTi wrote:* If there are any REALLY stubborn tar/sap/fly spots, use Autoglym Intesive Tar Remover to remove them
I only ever do the front screen... I put it on my rear window once and it was horrible. Water wouldnt run off it as there was no wind pushing it (but that was on a mk2 Golf which have no airflow over the rear 'screen...)Josh_PoloGTi wrote:* Clean the windows (external) with Autoglym Window Polish
... dont forget to roll a big fat one too (or have a beer!!)Josh_PoloGTi wrote:* DRINK SOME WATER, HAVE SOME LUNCH AND GO FOR A SIT DOWN!
hehehe, very or slightly?? slightly or very!! haha.....Josh_PoloGTi wrote:Use a very slightly damp kitchen towel
Ok, so you don't have any plastic trim then?? bastid!
For plastic trim I find Halfords trye black does the trick very nicely!
- Josh_PoloGTi
Well, I decided to start this afternoon, so here's what I actually did:
EXTERIOR:
I couldn't be bothered to HD Clense/Glaze... It's not long since I did it, so the car is still pretty shiney.
I'll do the interior tomorrow.
It looks lovelly by the way!!
EXTERIOR:
