EPC !?! Help
Posted: Thu Apr 07, 2005 3:47 am
by HK6N2
what does it mean when my GTI's EPC light is going on once a while?
It turn off by itself after I turn off my car, but comes on once a while when I m driving
Posted: Thu Apr 07, 2005 1:22 pm
by Randall
This is usually the engine management system stating there is a fault somewhere - i took mine into VW wen this happened charge £50 for error reading and if u have the work done there and then they 'do not charge for error reading'
if anyone feels i missed a bit then please jump in...
Rich
Posted: Thu Apr 07, 2005 8:20 pm
by cuprabaz
get yourself vag com so you can view and erase the codes yourself. You can also watch whats happening, ignition timing, intake temps, rpm, engine temps etc etc etc. very handy bit of kit.
Posted: Thu Apr 07, 2005 9:10 pm
by toXXin
I'd get it up to a decent VAG dealer/independant that can plug it into the diagnostic equipment and find out the cause of the problem.
Posted: Thu Apr 07, 2005 11:25 pm
by M@Turner
I had the same problem about 10 months ago. I took it to my local VW dealer and they charged me £42 for changing a switch that had gone faulty. I think it was the brake pedal switch!
HTH
Mat
Posted: Fri Apr 08, 2005 3:41 am
by HK 6N2
Hello HK6N2,
you use the same forum name as mine (HK 6N2)wor..........
May be I should change to "old HK 6N2" la 8)
Posted: Fri Apr 08, 2005 4:01 pm
by HK6N2
thanks guys... i got it fixed already, just a code error, it was done for free at the dealership.
