Page 1 of 2
Fitting two double carbs on 1.3 GT
Posted: Tue Apr 12, 2005 10:14 pm
by TheFog
As I'm fitting two double carbs (Solex 40) on my '81. 1.3 (polo mk1), I encountered one problem....or doubt.
What should I do with this exhaust holes on cylinder head that lead exhaust gasses through inlet manifold and as I found out are used for heating inlet and prevent carbs icing: close those holes on head as well as on exhaust pipe or should I connect them like there were with some pipeing?
One guy told me that closing these channels on their exit from head will create rough vortex of exhaust gasses and bad work of that two cylinders and that I should weld them right behind exhaust valves inside cylinder head.
Please help! Thanks!
Here are some pictures to give a better view of what's bodering me:
Posted: Wed Apr 13, 2005 7:18 pm
by D4V1D
get a head from a mk2?
on another note though, have you not found that the 1st carb doesnt clear the brake master cylinder.
this has been my problem and is making me think about selling it
Posted: Wed Apr 13, 2005 8:37 pm
by TheFog
I would like avoid buying any additional parts, expeciali such as engine head since this is pretty well "tunned"-polished channals, lowered, etc.
Oh come on, someone must have done this already, I don't belive I'm the first one!!!
Don't quite understand what you're trying to say about brake servo
If you're thinking about the first picture, that's only choke hose stucked inside servo so it ain't in my way while taking that apart. My servo is broken anyway.
Posted: Wed Apr 13, 2005 10:00 pm
by ste mk1lx
TheFogDon't quite understand what you're trying to say about brake servo
your car is a LHD mk1 which is fitted with a servo as standard, the uk mk1 Polos did not have one fitted and clearance near the uk master cylinder is minimum hence D4VID's problems when fitting his carb set up
Posted: Wed Apr 13, 2005 11:13 pm
by TheFog
there is enough space for both carbs if that's what you're trying to tell me
Posted: Thu Apr 14, 2005 12:17 am
by ste mk1lx
looking at your top picture yes there should be enough clearance to fit both carbs.
Posted: Thu Apr 14, 2005 9:59 am
by TheFog
ok, we solved that, now we can return to THE PROBLEM
Posted: Thu Apr 14, 2005 12:01 pm
by GroovyCarrot
Are those two ports simply a takeoff from the exhaust on cylinders 2 and 3?
Posted: Thu Apr 14, 2005 2:45 pm
by D4V1D
weld a plate over the holes?
your certainly not the 1st but youve got it alot easier with a lhd car u lucky bugger.
is the car in england?
check out some german sites and see what theyve done...
Posted: Thu Apr 14, 2005 2:56 pm
by ste mk1lx
you should be able to block them off IIRC they are inlet ports for spent exhaust gases used for the inlet manifold heating to be reburned in the engine (some body correct me if I'm wrong please)
Posted: Fri Apr 15, 2005 4:42 pm
by TheFog
ste mk1lx wrote:you should be able to block them off IIRC they are inlet ports for spent exhaust gases used for the inlet manifold heating to be reburned in the engine (some body correct me if I'm wrong please)
I lurked on some German sites and forums but it's all in german (and I'm weak with it)
I'm from Croatia (D4V1D: this answers your question) and I don't uderstand some english terms that you're using like IIRC(???)
D4V1D: why am I lucky, because of the brake servo?
ste mk1lx: you're right about the purpose part (heating inlet) but intake air channels and these "heating" channels are totally seperated, and direction of flow of these gasses are from engine head through inlet manifold towards exhaust, not the other way around as you said it (if I understood you corectly) - and this is where the problem is: I'm afraid that simply closing these two channels at their exit from engine head would crate eradical creating vortex of exhaust gasses inside engine head -> questionable work of that 2 cylinders... One bloke told me to weld these channels at their beginning right behind exhaust valves, but I'm in a search of a simlier, cheaper solution that I can do myself.
Posted: Fri Apr 15, 2005 8:16 pm
by bstardchild
TheFog wrote:I'm from Croatia (D4V1D: this answers your question) and I don't uderstand some english terms that you're using like IIRC(???)
IIRC = If I recall correctly
TheFog wrote:I'm in a search of a simlier, cheaper solution that I can do myself.
Just plate over them - it'll be fine
Posted: Sat Apr 16, 2005 2:16 pm
by TheFog
you seem were sure there....
(had an experience with it or just a speculation?)
I'll do that and if it behaves weirdly, then I'll take some other measures.
Thanks!
Posted: Sat Apr 16, 2005 8:06 pm
by bstardchild
Thanks!
No experience on VW - but I've stripped an awfull lot of exhaust gas recirc systems over the years to know it will 99.9% make bugger all difference to the gas flows and 110% the car will run a whole lot better without it....
OK this isn't exhaust gas recirc it's using exhaust gases to heat the manifold but the gasses will always find the easiest route so it probably doesn't do that much anyway......
Posted: Sun Apr 17, 2005 10:06 am
by TheFog
bstardchild> ok, thanks
yes, I thought the same that exhaust gasses will simply go to out through exaust manifold more because these channels are much thicker
Just hope that there will be no vortexing to decrease the performance
