UK-POLOS.NET - THE VW Polo Forum • Delayed reaction on acceleration.
Page 1 of 2
Posted: Thu Apr 14, 2005 12:18 pm
by clees
Help.. recently i've noticed that when i've been driving my 2001 polo GTi for a while it becomes a little sluggish when accelerating. So say for instance i give it a little boot at some traffic lights, it seems to think about it then breaks into acceleration.
Hard to explain, but hope it makes sense!!
Any help??
cheers Christian
Posted: Thu Sep 29, 2005 6:18 pm
by DNK69
Hey guys im having the same problem. Noone has replied to this post. Any help please??
Clees have u had any luck in sorting the problem??
Posted: Thu Sep 29, 2005 8:18 pm
by neilw
Mine does this, pulling away from something you think you should be much faster than, you get worried for like the first 2seconds of first gear as its still along side you, then it comes to life all of a sudden.
Posted: Thu Sep 29, 2005 8:32 pm
by DNK69
yea that happens plus with mine it happens in all gears. ive been beaten at the lights by much smaller engine cars cause of this problem. noone can tell me what is wrong.
Someone on here must know the problem??? :(
Posted: Thu Sep 29, 2005 8:52 pm
by Si_GTi
Is the "lack of acceleration" at low revs as you boot it and stay in gear? If so my reasoning would be that the delay in power is down to the torque not coming in strongly until higher revs, peak power is 152Nm (112 lb. ft) at 3300rpm I think? So below that there isn't as much pull maybe?
Just a thought!
Or maybe it's the ECU mapping that does it...?
Posted: Thu Sep 29, 2005 9:03 pm
by DNK69
no matter wat the revs there is still lag. :(
Posted: Thu Sep 29, 2005 11:03 pm
by Blackie
i had this problem and new spark plug leads fixed the problem.
Posted: Fri Sep 30, 2005 1:08 am
by inder
I replaced the airflow box and got my power back, the rubber seal inside had perished, could be same for you?
Posted: Fri Sep 30, 2005 9:28 am
by neilw
only happens to mine at low revs when flooring it. So is most likely to be like si says for me.
Posted: Fri Sep 30, 2005 11:48 am
by DNK69
I think i will get both checked out. I just hope one of these solves the problem. Car has been like this 4nearly a year :(
Posted: Fri Sep 30, 2005 6:39 pm
by andyg
Mine does this too!
I thought it was normal because all the power is really after 3000+ and when the VVT opens the valves more but it still feels sluggish at low revs, like it would rather not go.
which part is this? the bit that connects into the throttle body?
Posted: Fri Sep 30, 2005 7:41 pm
by ModifiedMadness
Mine is pretty impressive at low revs when I floor it, so hopefully it'll just be something simple that won't cost you a fortune.
Posted: Sat Oct 01, 2005 11:35 pm
by inder
No, not on the throttle body, on the air in-take pipe, here is a pic of the location:
Sorry, I deleted the pic of the worn rubber seal inside the part. Couple of screws and the jubilee clip, disconnect from pipework and its out, part can be split in two, has clips along the side, so you can see the rubber seal to check or just look down one end.
When I got the new one, VW had redesigned the seal on it, much more tougher - this could be a common problem/design fault. I actually found bits of the rubber seal inside the air filter box upon the throttle body! glad nothing went inside the engine lol
Once it was changed over, I felt a massive increase in power/reaction to the acceleration :D
If you need more help let me know, can get you part number etc.. :)
Posted: Wed Oct 05, 2005 12:15 pm
by DNK69
Inder that bit u got circled is not there in the GTI. There is piping there which is connected to the air filter but then there is nothing else. the piping jus goes down the side to bring in cool air.
Posted: Wed Oct 05, 2005 8:08 pm
by ModifiedMadness
Maybe someone could circle it for you on my pic (if they can see it)
