Rear axle alignment
Posted: Fri Apr 22, 2005 8:10 pm
by GroovyCarrot
Is it possible for the rear axle to be misaligned? Just, I noticed today when I was checking over my new tyres that the nearside rear wheel has acres of clearance, it's practically trying to go into the middle of the car, whereas the offside rear wheel has just about enough clearance to get by. I've never had a rear axle off before so I don't know how it's fitted, but is it possible for it to have been mounted a bit over to the right?
Posted: Sat Apr 23, 2005 5:03 pm
by k4lps
theres only 1 way that rear beam will go in theres no room for ajustment
could it be that your wings a lil bent???
Posted: Sat Apr 23, 2005 5:04 pm
by Gareth_GT_Hatch
there is probably 1 or 2 mm of adjustment in the 6 bolts that hold the pivots on the car. You could try adjusting them but the bolts are threadlocked and very tight. none of the cars ive had have had perfect allignment. Ive always had scrubbage on one side an not the other (never both) so if its not causing any problems with the new tyres youve got then its probably not worth worrying about
Posted: Sat Apr 23, 2005 5:14 pm
by k4lps
did't think of that one
Posted: Sat Apr 23, 2005 8:32 pm
by GroovyCarrot
Well, haven't had enough of a load in the back yet to make really sure.. it just shocked me quite how different the two sides are. One side looks like it'll just clear, the other one's got about an inch and a half of clearance. Fingers crossed though that it won't be a problem with the new tyres though.
Posted: Sun Apr 24, 2005 1:58 pm
by Gareth_GT_Hatch
that sounds like quite alot of clearance the inch and a half side. maybe its had a bump and the stub axle is bent? On my gt and my mk2 theres a few mm either side max.
Posted: Sun Apr 24, 2005 11:30 pm
by GroovyCarrot
No signs of rear end accident damage, and I haven't noticed anything bent under there, but I'll check it out next time I find a reason to go under the car. Hope it's nothing like that
Might just be an excuse to find a GT rear axle if it is buggered though
Posted: Tue Apr 26, 2005 10:04 am
by mkoprulu
Groovy, can you post a picture of it from the back so that we can have a look at it too?
Posted: Tue Apr 26, 2005 3:53 pm
by GroovyCarrot
Will do when I get a chance. It isn't that noticable most of the time, just if I stick the wheel up on a ramp you can see it has an awful lot more clearance one side than the other.
