1300...still leaking from head , but new place
Posted: Fri May 06, 2005 6:28 pm
by steveo3002
i had a slight weep from the front driver side headgasket, so i changed the gasket and did a nice job , cleaned it all spotless and torqued up the new bolts as per the manual
now..its leaking from the front middle...quite a bit :evil:
any ideas..spose the head is warped,although if it wasnt before it shouldnt be now
is the oil gallery around that area pressurised or just a return
btw...i used a ecp gasket, maybe i shouldve got a better quality one????
Posted: Fri May 06, 2005 10:21 pm
by mk2keel
sounds like warping :(
Posted: Tue May 10, 2005 11:22 pm
by Phoenix
should have got the head skimmed if it was leaking in the first place.
doin mine at the moment but i'm getting it skimmed a bit extra to raise the compression :twisted:
More pick up and go here we come mwahahahahahaha
Posted: Tue May 10, 2005 11:28 pm
by bstardchild
Phoenix wrote:should have got the head skimmed if it was leaking in the first place.
It's always a risk putting a head back on without skimming and besides a skim ups the comp ratio and that means more power
Don't go mad tho find out what the deck height is and go to - 20 tho of that
Posted: Tue May 10, 2005 11:31 pm
by Phoenix
lol i'll go as low as i can the sooner i blow it up the sooner the H section rods, forged pistons and steel crank go in. :twisted:
Mwahahahaha bring on the nitrous and nurburgring
Posted: Tue May 10, 2005 11:52 pm
by bstardchild
Phoenix wrote:lol i'll go as low as i can the sooner i blow it up the sooner the H section rods, forged pistons and steel crank go in. :twisted:
Oh you won't have to worry about blowing it up just the pistons tapping on the cylinder head at then end of every stroke :shock:
Still you can just say it's a diesel :roll:
Posted: Tue May 10, 2005 11:53 pm
by Phoenix
i'll try to get as close as i can but i won't go so low that they hit, lol i'm not that mad :wink:
Posted: Tue May 10, 2005 11:56 pm
by bstardchild
Phoenix wrote:i'll try to get as close as i can but i won't go so low that they hit, lol i'm not that mad :wink:
^ three posts up + 10 thou is max but you have no more room for another skim so the head is scrap if the gasket ever blows
I'm still looking for a 1.3 Coupe S head with Hyd lifters - no one anywhere so it's a shame to trash a good head with no reason
Posted: Tue May 10, 2005 11:59 pm
by Phoenix
well the heads never been off the car till i took it off today :shock:
so i'll do a normal skim then just see whats left but i dobt its warped as it didn't run hot, the gasket has blown out the back rather thank between the oil ways and water ways. so the cars runs fine but it just pisses oil all over the ennine bay.
Only good side is the engine bay will never rust now :lol:
Posted: Wed May 11, 2005 7:39 am
by GroovyCarrot
bstardchild wrote: I'm still looking for a 1.3 Coupe S head with Hyd lifters - no one anywhere so it's a shame to trash a good head with no reason
There have been a couple of coupe s's being broken on porka recently.. worth a look maybe.
