UK-POLOS.NET - THE VW Polo Forum • 13's
Page 1 of 2
13's
Posted: Mon May 09, 2005 12:03 am
by ZOMBIE
Does anyone know if you can get a tyre that is 175/65 r13 or 185/65 r13?
its just I want my wheels to look phat!! without looking like a monsta truck! :lol:
Posted: Mon May 09, 2005 12:07 am
by Gareth_GT_Hatch
you can get both those sizes id imagine. Iva had a set of 175/65s in the past. 185/60s would be good...
Posted: Mon May 09, 2005 9:15 pm
by ZOMBIE
I wish..... I priced up some falkens and for 4 175/65s it would cost £140, so I had to go with some 165/65 that only set me back £91 [they are cheaper tyres made by dunlop?!].
I am part of the gti 9 spoke club now!! so snap Gareth GT and G.C!!!
Ill get you some picks soon, ive sprayed them satin black and am waiting for the money from my 15s so that I can go 60mm rather than 40. :D
Posted: Mon May 09, 2005 10:16 pm
by gofasterpinch
i use 185 60 13s on my nine spokes cheap as
although the thought of falkens :oops: make sure you get the 512 over the 502
Posted: Tue May 10, 2005 11:20 pm
by Phoenix
ZOMBIE wrote:am waiting for the money from my 15s so that I can go 60mm rather than 40. :D
Lol go 70mm :D thats what i did
Posted: Tue May 10, 2005 11:44 pm
by GroovyCarrot
I've got a pair of 185/60's and a pair of 175/70's in the shed. Good tread on the 185's, the 175's are almost brand new. They're yours if you want them, gratis, I need them out of the shed..
Posted: Wed May 11, 2005 12:05 am
by Phoenix
just thinking then, i almost got 165/55/13's the other week and they look low as hell 8)
Posted: Wed Aug 17, 2005 10:42 am
by polock
Ive just taken delivery of some 13" 9 spoke alloys (like the one on GC's sig.
My question is, can i use my existing wheels bolts from the steelies or do i have to get some longer bolts to cater for the alloy thickness?
Edit:
Also, will the 175/70/13's that came with them be ok with a 40mm lowering?
Cheers chiefs!
Brian :)
Posted: Wed Aug 17, 2005 7:45 pm
by ZOMBIE
no mate- original bolts will be fine, im running terantulas with standard bolts :)
Posted: Wed Aug 17, 2005 7:46 pm
by polock
Eeexcellent!
Cheers for that, we must of been typing at the same time lol, ive added an extra question, lol (see above)
Ta :)
Posted: Thu Aug 18, 2005 9:06 am
by GroovyCarrot
The tyres will probably be ok on a coupe, but you won't be able to lower a squareback with them without some arch modification. You might also find that they scrub slightly on full right lock, to stop this you have to remove the plastic panel in the arch that covers the end of the gearbox as it protrudes slightly and catches.
Posted: Thu Aug 18, 2005 9:13 am
by polock
Bugger Bugger Bugger! lol
Alloys or lowering, hmmmmmmmmm
Looks like im gonna have to do some thinking.
Cheers! :)
Posted: Wed Aug 31, 2005 8:07 am
by polock
OK, thinking process complete and after reading this topic again and some very helpful advice from GC.........
I think ive decided to lower it 40mm AND put the 13's on....BUT change the 175/70's they came with to 165/65/13.
According to tyresave tyre calculator this will make the tyre diameter 1mm less than the standard & 20mm wider overall.
Will this still be ok without modding the arches or is it more of a case of 'suck it and see'?
Cheers guys!
Brian
Posted: Wed Aug 31, 2005 10:40 am
by GroovyCarrot
Should be fine, my 165/65's have acres of clearance. They look a bit skinny compared to the old 185's, but not so bad as to look silly.
Posted: Mon Oct 10, 2005 9:53 am
by polock
Well, i went and did it at the weekend. My wee green tank is now 40mm lower and sporting the 9-spoke alloys wrapped in 165/65/13's.
And the best bit about it, no rubbing, not even when going over rather large speeds bumps at more than the recommended speed limit :D :D
Pics to follow, when ive cleaned him up lol.
Next job, a weber carb replacement 8)
