if you would like the front of your polo to feel more responsive then this may be the part for you and to top it off its oem
there are 3 different thicknesses (diameter) antiroll bars fitted to the mk5 and all can be swapped if the mountings are also swapped
the diameters are as follows
18mm
20mm
22mm
and the prices are reasonable hoever i feel it would be innapropriate to post them here so if you are interested then please ask in the vagparts forum
front anti roll bar
front anti roll bar
i just posted this in the mk5 forum after discovering it and it turns out that it is also applicable to the mk4 in the same diameters and te prices are still reasonable
a tie bar is bassically an anti roll bar
an anti roll bar is shaped a little like this
--\______/---
the 2 parts that are slightly raised ----- have a rubber mounting wrapped round them and are attached to the bottom arms the / and \ bits are simply levers and the lower part (___) it mounted to the sub frame via rubber mountings
now if you try and imagine that then i can explain how they work;
the front suspension is independant which means that if there were no link nbetween the two then one could go into full compression while the other culd fully extend (trounce) this results in a huge amount of roll so what an anti roll bar does is it links the 2 front struts together so that if one rises then so does the other. unfortunatly if it were completly solid then it could induce a fair deal or understeer as the car cannot shift any weight to the outside wheel by leaning out of the corner a little so they are slightly flexible (by slightly i mean still reall really solid but the forces in cornering can twist it a little) by fittign a thicker bar the 2 front wheels remain at a similar height, but vw design the bar so as not to go into the realms of understeer city, a larger oem bar will slightly increce understeer but at higher initiating speeds (i.e. its harder to get it to understeer but a little harder to recover as both front wheels have a fair ammount of weight on them [due to less body roll] wheras on stock bars the outer wheel will grip a little better due to the added weight) this isnt really too much of a concideration at street speeds so you can safely fit one without understeerign in the local safeways carpark (unless your playing hard~!!!)
the solid beam name is quite misleading as there is actually a bit of twist possible so a rear anti roll bar is actually a reenforcing bar that is "U" shaped and fixes to the rear beam meaning less twist on the beam however this can result in some oversteer for similar reasons as above
--\______/---
i put the 22mm gti bar on my 1.4 cl. took about half an hour. No problems. Body roll greatly reduced, really fun to drive now. Good upgrade for under £100 dfrom the main stealers. Funnily enough the 22mm bar is the cheapest by about a tenner at about £57. I have gone throuhg two mounting brackets in a year though, because the gti rides lower by 20mm, so it is under mre stress
ok imjust checked the prices and vag parts can do the 22mm gti bar for £29.72 + vat (dealer price £42.89+vat) however i recomend that you also replace the rubbers that it sits in as these may already be worn and the larger bar uses different rubbers any way
if you want the 22mm kit then you need
1x 6n0 411 309 f (22mm "gti bar") £29.72 + vat
2x 6x0 411 313 a (22mm inner rubber) £1.74 +vat each
2x 6n0 411 315 d (22mm outer rubber) £ 11.44 +vat each
so the total mod should cost around
£56.08+ vat
=£65.90 (if ive done the math right)
so it works out some what cheaper than the eibach kits that retail at about 200 quid and make the car a little uncomfortable in everyday driving
£56.08+ vat
