interior light
Posted: Tue Jun 21, 2005 9:00 am
by bass mekanik
doesnt work when i open the door.
now cant be the bulb because when you switch the light on "permanent" while in the cabin its fine.
cant be the door switches otherwise my alarm would be going s**t.
cant be fuse because again- the light wouldnt come on if i flick the "permanent" on switch in the cabin.
driving me mad! any thoughts anyone?
Posted: Tue Jun 21, 2005 11:38 am
by mikegti
the light only comes on when the doors are opened, so the switch could have failed in the 'door shut' position? could be the earth connection is dirty/ corroded?
is it the same problem for the passenger door?
Posted: Tue Jun 21, 2005 1:37 pm
by bass mekanik
mikegti wrote:the light only comes on when the doors are opened, so the switch could have failed in the 'door shut' position? could be the earth connection is dirty/ corroded?
no i dont think thats the case as the same problem is on passenger side.
its wierd- doesnt really make any sense
will try cleaning up the connections and see if that makes a difference.
Posted: Tue Jun 21, 2005 3:47 pm
by mikegti
problem with the light unit then?
Posted: Wed Jun 22, 2005 6:13 pm
by live2themaxuk
you alarm wouldnt be going off if it was stuff on the 'closed' position eg 'no light on'
if it was 'open' the light would be on and the door would be in effect open thus resultsing in alarm gong spazz
probably door switch. also. does the light come on then you press 'unlock' on the key fob with all the doors shut. should be on for when you approach the car and unlock it
Posted: Thu Jun 23, 2005 12:43 pm
by ali
Had the same problem, the light was faulty, I think they are around £12
Posted: Fri Jun 24, 2005 9:26 am
by inder
I've got a light unit for sale if needed
