UK-POLOS.NET - THE VW Polo Forum • Radiator fan
Radiator fan
Posted: Tue Jun 28, 2005 9:58 pm
by cinder
Hi, after putting my car together again, i cant seem to make the radiator fan turn. When is the radiator fan suposed to turn, a friend of mine said it never turned on the polo 6n before the engine nearly cooked over.. but this seems strange to me. Would someone please take a look and see how your radiator fan is behaving ( suposed to behave) That would be great :D :oops:
Re: Radiator fan
Posted: Tue Jun 28, 2005 11:33 pm
by bstardchild
cinder wrote:Hi, after putting my car together again, i cant seem to make the radiator fan turn. When is the radiator fan suposed to turn, a friend of mine said it never turned on the polo 6n before the engine nearly cooked over.. but this seems strange to me. Would someone please take a look and see how your radiator fan is behaving ( suposed to behave) That would be great :D :oops:
Mine chimes in as soon as the temp goes over 90 (typically in traffic after a few mins) Doesn't sound right to me - new temp switch I think would be a good idea
Posted: Wed Jun 29, 2005 9:23 pm
by helios1
Mine never comes on, ever. Even after i rag it. Guess it only comes on when the engines about to melt.
Posted: Wed Jun 29, 2005 9:37 pm
by david burton
generally they won't come on unless the car is not moving.
it should come on if you park up after a drive and then keep the engine turning over for a couple of mins.
Posted: Thu Jun 30, 2005 3:46 pm
by AshBlueMk4
the cooling system on the mk4 is the best in the line. I noticed it only comes on when you rag the *&%& outta ya motor and it creeps over 90. Also when ur water level drops below max it heats ups faster. Also sometimes only comes on when you stop your car. You wont notice it in traffic if its on because there so quiet. As well if your temp creeps over 90 it can indicate problems with them like water pump failure. So if it stays where it is everythin is fine]
ash
