Page 1 of 6
bigger injectors?
Posted: Mon Jul 18, 2005 11:38 am
by forbezGti
hi guys was wondering if anyone knows or has put bigger injectors into there polo.
mate has a cossie and he was saying that he put bigger injectors in and it made a hell of a difference. would that be because its turbo'd or would this work for any car i.e the polo Gti.
any help please..
Posted: Mon Jul 18, 2005 11:41 am
by Tigz
You shouldnt need bigger injectors really unless you have upgraded the induction.
Only really needed for Turbo'd and TB'd cars really.
Posted: Mon Jul 18, 2005 11:53 am
by forbezGti
cheers. what do you mean by induction??
Posted: Mon Jul 18, 2005 1:39 pm
by Tigz
If you cant get anymore air into the mixture, theres no point putting more fuel in.
That make sense.
Posted: Mon Jul 18, 2005 4:03 pm
by forbezGti
o ok. well im getting a shed load of air in. got cold air intake with the filter behind the fog lamp and from the filter its just a pipe fitted straight onto the throtle body.so there is enough air i think. so do you think i could put on bigger injectors???
cheers for the help.
Posted: Mon Jul 18, 2005 4:09 pm
by Tigz
No mate.
No matter how big your filter is your TB is still the same size.
Im expecting the standard injectors will be fine with an ajustable fuel regulater, even with twin 40 throttle boddies.
Bigger injectors on a stock engine is over kill imo.
The stock injectors are not max'd out so upping the pressure would do the job fine.
But remember add more fuel, and you need to remap the ECU.
Posted: Mon Jul 18, 2005 4:14 pm
by forbezGti
ok cheers. i have a fuel regulater for a 1.8 20vt would that up the preasure??
Posted: Mon Jul 18, 2005 4:18 pm
by Tigz
Is it ajustable?
Just be carful not to max out the injectors.
As I say, the ECU doesnt have enough self ajustment to cope with a huge increase in fuel.
so you run the danger of adding one of them ebay 'tuneing boxes' by running the engine too rich.
Its a tricky one mate, I dont think your gonna get any gains, without fitting a larger throttle boddie (I have heard of someone useing a larger mk4 gold tb.) and mapping the ECU.
Posted: Mon Jul 18, 2005 4:25 pm
by forbezGti
im not sure if its adjustable, the mk 4 golf tb would that be a straight fit on??? sorry for all the questions
Posted: Mon Jul 18, 2005 4:43 pm
by Tigz
Ive no idea mate, dont know anyone who has attempted it.
Be a trail and error job to be honest.
But again, I dont know if the benifits would be even worth the time/money.
What about a tbs conversion?
Only real way of getting any power outr of a GTi engine without the use of a turbo.
Posted: Mon Jul 18, 2005 8:24 pm
by forbezGti
had thought of that but then again i have not really looked into it. what would be the price for them be??
Posted: Mon Jul 18, 2005 8:42 pm
by Tigz
Depends how much you want to spend really.
The biggest cost is the ECU and mapping time.
I think Ive spent £560 so far on the Throttle boddies, air horns and fuel rail.
Linkages are £80, manifold will cost between £80-£200 depending who you know, although I am trying a spacer plate a friend of mine is making for me, to allow a direct to head (ish) fitment.
This should cost no more than £50 (again, another 'ish' here)
The standard injectors may be fine, like I say, but replacments shouldnt cost no more than £30 off ebay.
Then you'll need to change your flyby wire throttle, to cable.
You'd need to mount a trigger wheel (around £50 for the bits) to the crank for the timeing, and a bunch of sensors.
ECU can cost as little as £160 with a loom, if your able to map it yourself, or up to £600 for a DTA unit that most tuners will be able to map.
Mapping should cost between £300-£450
Im no where near ready for it all to be installed yet, so if we say there may be another £500 for problems I dont know about
If you have the cash, and give Mr Bill Badger5 a call.
He offeres a supply and fit service.
I forget how much it is, I think it may be around the £3500 mark.
Should be good for 180hp on a GTi lump Id imagen
Posted: Tue Jul 19, 2005 3:18 pm
by forbezGti
cheers mate. my brother is going to email bill about it. so ill have to see what happens, thanks for the info..
Posted: Tue Jul 19, 2005 3:36 pm
by Tigz
Cool keep us imformed.
Intrested to see how a 1600 preforms on them.
Posted: Thu Jul 21, 2005 9:05 pm
by forbezGti
hey, i got the low down from bill, at badger. i was shocked at the price. the price he gave was about £2000-£2500 for parts and that was without fitted i think and defo without the remap. not going to go for the trottle bodys, going on hols with the bird so that drains the pennys away. but on the look out for a 1.8 20vt out of a right off, so ill see what happens.
