Debadging operation
Posted: Fri Aug 19, 2005 7:41 pm
by ck6uk
im just looknig to take the supercharged badge off my g40 but leave the polog40 one on, wat is the process of removing the badge without damaging the paint work if possible?
do i use boiling hot water? might be a bit hard to get to under the polo g40 bit!!
thx ck
Posted: Fri Aug 19, 2005 8:45 pm
by Krupa
A hairdryer and careful peeling should do it, unless someone's superglued it on like my Coupe badge.
The Supercharged badges come without adhesive, so be careful. If it looks like it's taking the paint off stop and leave it alone is the best advice I can give.
Posted: Fri Aug 19, 2005 10:42 pm
by Krupa
ck6uk wrote:its an actual badge though not a sticker
Yep, they're the same as the Catalyst badges, put some heat on it and it'll bend which makes it easier to peel away from the paintwork.
thank you
Posted: Sat Aug 20, 2005 4:01 am
by ck6uk
thanks m8 ill give it a go later n take a pic
