UK-POLOS.NET - THE VW Polo Forum • Budgie noises coming from engine
Posted: Fri Aug 08, 2003 7:53 pm
by Chief Mangosuthu Buthelez
i got a polo the other day (p reg 1.0) and noticed that when i start up the car the ignition makes a high pitched squeaky noise. the same happens then i turn off the engine.
is this normal or something that is easily sorted?
thanks in advance
Posted: Fri Aug 08, 2003 9:13 pm
by polo2k
ok start off by checking the oil and getting it serviced and get an oem filter put on as oem filters are about the only ones that have a non return valve in them so that when you start the engine there isnt an empty filter to fill before the top end gets "wet" if you ever start an old diesel engine (mk2 golfs are bad for this) you will see that the oil pressure warning light will stay on for ages because the old and work oil pump has to fill the filter and then get up enough pressure to get the oil up to the head
this lack of oil could be scoring your cam
while your in there check the tension of the alternator belt and any other accesioriy belts
if it continues then try and start her with the cluch depressed to eliminate any transmission isses
Posted: Fri Aug 08, 2003 9:32 pm
by jazzypolo
Chief
Sounds to me like your car has the dreaded Nnzomazoma fever.
Ask the Witch Doctor for some Tribal Medicine.
8) 8) 8) 8) 8)
Posted: Sat Aug 09, 2003 1:34 pm
thanks for the advice kidder.
oil pressure in the hydraulic tappets makes a noise apparently, but one of my mates said it could be that my belt is too tight. the sound comes from that side of the engine, so i'll go along with that.
i'll try startin with the clutch down
i get that 'IN 02' messgae when i put the keys in aswell, how the fook do you get rid of that? it only got its MOT a few weeks ago and theres no way im going to look for a vw dealership like it says in the book.
sorry for my lack of mechanical knowledge, i used to have a mini
thanks
Posted: Sat Aug 09, 2003 3:17 pm
starting up with the clutch down didnt work, bugger.
i had a listen before and it sounds like its coming from the cam belt rather than the alternator belt.
Posted: Sat Aug 09, 2003 6:28 pm
by polo2k
Posted: Sat Aug 09, 2003 6:33 pm
cheers mate
Posted: Sat Aug 09, 2003 6:38 pm
by polo2k
Posted: Sun Aug 10, 2003 5:13 pm
by jazzypolo
Chief
Sorry if I p****d you off the other day. I read your post after coming back from the pub and the alcohol got the better of me.
Having a sick motor is no fun especially when you just paid good money for it.
Hope you get it sorted.
Jazz
8) 8) 8) 8) 8)
Posted: Sun Aug 10, 2003 7:58 pm
nah you didnt p**s me off.
anyway my uncle says its proberbly my timing belt thats making the noise.
b****x
Posted: Mon Aug 11, 2003 11:06 am
by polo2k
ok people please make sure you donr wear out the shift and 8 keys i hope we all have the vocabulary to work out way around thees little problems so please try and keep it sensible as personally i find it annoying when half a post id
i.e.__________________________
hi **** ****** ****** ****** ******* engine ******** *** ***** ***** **** polo ****** ****** ****** ***** squeek ****** ****** ****** ***** **** **** *** ** * * and i only just **** ***** *** bought it
TIA___________________________
plus you can see that it takes a few reads so lets all try and rephrase things ok?
Posted: Mon Aug 11, 2003 1:21 pm
aye lad
