Front Wheels shuddering/Vibrating @ high speed.
Posted: Mon Aug 29, 2005 8:53 pm
by PhilGTi
When im doing 90-120 ish there is a vibration/shuddering. Starts really mild at 90 then gets progressivly worse towards 120ish, ive not gone any faster since its started vibrating because i get skittish. It started when i had my new wheels fitted, what do i need doing? Wheel balancing? Tracking? Camber?
Also, wheels before hand where 5.5 wide, now 7" wide if that matters, same diameter and tyres tho.
Oh Polo GTi 2001 by the way...
Posted: Mon Aug 29, 2005 9:12 pm
by Redline
Speed limits 70 mate :P
I tend to get this a fair bit, most noticeably on very smooth tarmac.
Checked your tyre pressures?
Posted: Mon Aug 29, 2005 9:22 pm
by PhilGTi
Who said it was on a road ;). Ill have to give the tyre pressure a check, surely if i payed to have the tyres fitted and balanced they should sort them out again if they aint right?
Posted: Mon Aug 29, 2005 9:36 pm
by M@Turner
Have you checked that all the nuts are tightened correctly, or maybe check wheel bearings. They maybe on their way out.
Worth a try anyway.
Mat
Posted: Mon Aug 29, 2005 9:42 pm
by PhilGTi
Thanks for the input. The wheels where VERY hard to get off when i changed wheels, this might have something todo with it?
Posted: Mon Aug 29, 2005 11:03 pm
by moynas
Normally if the wheels judder at around 60-70mph its the balancing of the wheel thats out!! Sometimes it can be the toe which is if the wheels turned into each other!!
Maybe its what has been said before that you need to tighten up the wheel nuts!! Wouldn't have thought it would be the bearings because you normally hear the problem before you feel it plus you'd feel it at low speeds aswell as high speeds :roll:
Width of wheel had nothing to do with it!!
Posted: Tue Aug 30, 2005 6:35 pm
by PoloCornwall
balancing mate
Posted: Tue Aug 30, 2005 8:05 pm
by PoloGTi
polosilver wrote:Who said it was on a road ;)
Well it is a bit dangerous to be doing 90-120 OFF ROAD! That might be the juddering effect right there :wink:
If you wheels are hard to get of and need quite a good kicking to do it. Get some copper grease (I think its called that) it stops the aluminium wheels sticking on due the difference in metals (according to the RAC guy who had to get my wheels off once :oops: )
Posted: Tue Aug 30, 2005 10:10 pm
by poussou
1)Balancing the wheels
2)A possibly distorted tire
I had the same prob and when i took it for balancing the guy said it didn't need any...I was the tire that was the problem.
In the first case you should be fine, in the second, you need a new tire
