Just had my 6n2 lowered
Posted: Sat Oct 08, 2005 11:20 am
by BLK_POLO
I just got my 6n2 lowered on eibach sportlines and the steering wheel isn't aligned with the wheels, do i just need my camber sorted and wheels aligned to sort this out.
I just phoned a local garage and they said that on new polos you cant adjust the camber is this correct.
Posted: Sat Oct 08, 2005 12:14 pm
by mikegti
Try taking it to a garage that can do the 4 wheel laser alignment, that should do the trick!
Posted: Sat Oct 08, 2005 12:38 pm
by dubpolo
camber on the front is adjustable but on the back its not
Posted: Tue Oct 11, 2005 8:22 pm
by polopowah
most likely your tracking
-Ben-
Posted: Mon Dec 26, 2005 1:33 pm
by Ross16v
I have the same problem as this the garage have told me the car cannot be tracked until the camber on the front wheels is sorted is this s**t???
how can i sort the camber???
Cheers Ross
Posted: Sat Dec 31, 2005 12:20 am
by Ross16v
I have now sorted it. on the Fk coilovers there are two bolts on the bottom of the suspension leg, if you losen these you can adjust the camber then tighten them back up only took 5mins!!!
Posted: Sat Dec 31, 2005 12:40 am
by OMEGASUPR3ME
hey ross can u do a how to guide of that coz i have fk ones aswell and think i need to adjust my cambers. thanks
