SuperCharge your dub :O
Posted: Wed Oct 12, 2005 3:07 pm
by Alex_6n2
Just found this whilst browsing the internet, dunno if any one has posted this before but do you reckon this acctually works?
http://www.akamoto.co.uk/electric-supercharger.asp
From what i gather its exactly the same as an induction kit but with an electrically driven fan to cram s**t loads of air into your engine... sounds like fun but im not hot on this kinda thing.... opinions?
EDIT: never mind lol, just found out you get like +6%hp and for £300 and much less mpg its a bit poo
Posted: Wed Oct 12, 2005 3:22 pm
by viceroy
Quite frankly, no little electric fan is going to be able to push in enough air to create a positive pressure. If anything it will be a restriction that reduces your power!
Posted: Wed Oct 12, 2005 5:32 pm
by Alex_6n2
hmm i dunno, the dual one seems quite powerful and spins considerably quickly but its expensive for the small gains it produces
Posted: Wed Oct 12, 2005 6:23 pm
by viceroy
belt driven superchargers and turbochargers have actual compressor blades spinning at 80+ thousand rpm, They are precision designed to withstand the forces involved.
These electric supercharger things will spin at 25 thousand rpm at their absolute maximum, and are spinning a plastic fan blade.
So I doubt these things even generate 0.1bar of positive pressure.
I live in Johannesburg, which is at a power sapping 1700m above sea-level. Normally aspirated cars lose anything from 15-20% of their power, even turbocharged cars lose 5% of their power.
Now don't you think if these things really worked all of us Joburgers would have them installed in ours cars. We don't, because these sorts of gimmicky things just don't work.
Posted: Wed Oct 12, 2005 7:28 pm
by bstardchild
viceroy wrote:Quite frankly, no little electric fan is going to be able to push in enough air to create a positive pressure. If anything it will be a restriction that reduces your power!
Saved me typing anything - thanks
by bstardchild
viceroy wrote:belt driven superchargers and turbochargers have actual compressor blades spinning at 80+ thousand rpm, They are precision designed to withstand the forces involved.
Perfect........ Waste of money all these bolt on gizmos
Posted: Wed Oct 12, 2005 9:59 pm
by Krupa
80+ thousand RPM? Are you sure?
G40 chargers spin at 1.6 times engine speed as standard, that's a high revving engine.
There's a full thread on the Pitstop Developments forum about electric superchargers, it's worth a read.
Posted: Wed Oct 12, 2005 10:56 pm
by Alex_6n2
lol i did think they were a bit poo
id try one if they were like £30 but for that sort of money its really just another scam i spose
a proper charger conv sounds like a laugh tho even tho pointless on my car lol
Posted: Thu Oct 13, 2005 12:12 am
by SteB
Krupa wrote:80+ thousand RPM? Are you sure?
Yes, your right about the G-lader (but other superchargers are available
), i think he was generally making the point about turbochargers, in which case, 80k is the norm, 150k+ is not unknown
Posted: Thu Oct 13, 2005 7:58 am
by Tahrey1043
file them under the same category as the "power boost valves" that give you up to 70 extra horse power (yeah, right, how big's the horse?), ready-made chips on ebay, and all manner of other dodgy "tuning" parts whose makers scam chavs out of thousands on a daily basis
seen a couple of rather chavvy cars being sold on the works messageboard with such things included in the description!
