HEADLIGHT WASHERS
Posted: Thu Oct 20, 2005 4:42 pm
by tntuk
Anyone know whta to do if the headlight wash system does not come out? I just got the car and tried to test the light washers. But when I try to activate them(with the light on of course!) the washers don't come out and ends up emptying half the bottle in my washer and end up with a big puddle on the floor under the front bumper! Any ideas before i spend some cash to take it to the garage?
Posted: Thu Oct 20, 2005 7:21 pm
by Grum
the headlight washers didnt work on my polo either when i first got it!
check the fuses for a blown fuse, thats wot was wrong wi mine, just a blown fuse, replaced that and they have worked everytime now!
hope that helps?
headlight washers
Posted: Fri Oct 21, 2005 9:22 am
by tntuk
Cheers buddy, I will give it a go tonight. Are they normal size fuses or the mini type? also what ampage?
Posted: Fri Oct 21, 2005 10:32 am
by inder
The fuses would be normal blade type size, check your fusecard to find the exact one to check/replace
This sounds like the water pipe has come off the water jet, remove bumper and check the pipe is secure? Or try poke your head up from underneath and check
