wdoor mirror heat
Posted: Wed Nov 23, 2005 4:55 pm
by nickpolo
do the heated door mirrors come on when the rear windscreen heat is put on?
Posted: Wed Nov 23, 2005 5:31 pm
by cyhliu
I believe that is correct...mine seem to clear when I switch it on.
Posted: Wed Nov 23, 2005 5:36 pm
by nickpolo
mine just dont do anything v fast, but has not been really icy yet. does anyone know if the washer jets are heated?
Posted: Wed Nov 23, 2005 6:28 pm
by Si_GTi
The wing mirrors don't react very quickly on my car either, in comparison to the rear window. Still work though :wink:
I *think* that heated washer jets may have been a part of the optional Winter Pack, which also included heated seats. So I reckon if you've got heated seats, you'll have heated washer jets, and if not, then not :)
Posted: Wed Nov 23, 2005 6:45 pm
by Del_GTi
Neither of my wing mirrors heat up, not sure if it's the actual element or the connections are corroded, still to solve that one.
As for the heated washer jets, i have those but don't have heated seats. I thought all the gti's had heated jets.
Best way to check is remove the little plastic oval shaped cover on the under-side of the bonnet and see if there are any wires connected to the jet.
The only reason i know this is i had to replace one last year.
Posted: Wed Nov 23, 2005 7:50 pm
by Si_GTi
Oh right. Well I stand corrected (gladly!) :wink:
Posted: Wed Nov 23, 2005 7:56 pm
by Del_GTi
And, if i remember correctly, they work off outside temperature, so that the colder it gets outside, the warmer the heated jets get. 8)
More useless information. hehe
Posted: Wed Nov 23, 2005 10:07 pm
by mikegti
mine work fairly quickly, soon have steam coming off the mirrors!
Could do with tiny wipers to clean them though, absolutely filthy! :roll:
